Thread: Standards agma
    Standards agma
    Dear brothers some of you have AGMA standards. Please send the link can compatir ......
    standards applied are as follows
    1) AGMA 918-A93 Numerical Examples Demonstrating the Procedures for Calculating Geometry Factors for Spur and Helical Gears
    2) AGMA 923-B05 Metallurgical Specifications for Steel Gearing
    3) AGMA 925-A03 Effect of Lubrication on Gear Surface Distress
    4) AGMA 926-C99 Recommended Practice for Carburized Aerospace Gearing
    5) AGMA 929-A06 Calculation of Bevel Gear Top Land and Guidance on Cutter Edge Radius
    6) AGMA 930-A05 Calculated Bending Load Capacity of Powder Metallurgy (P/M) External Spur Gears
    7) AGMA 932-A05 Rating the Pitting Resistance and Bending Strength of Hypoid Gears
    8) AGMA 6013-A06 Standard for Industrial Enclosed Gear Drives
    9) AGMA 10064-5-A06 19 Code of Inspection Practice-Part 5: Recommendations Relative to Evaluation of Gear Measuring Instruments
    10) AGMA 14179-1 Gear Reducers-Thermal Capacity Based on ISO/TR 14179-1
    11) AGMA 914-B04 Gear Sound Manual-Part I: Fundamentals of Sound as Related to Gears; Part II: Sources, Specifications and Levels of Gear Sound; Part III: Gear Noise Control
    12) ANSI/AGMA 6000-B96 Specification for Measurement of Linear Vibration on Gear Units
    13) ANSI/AGMA ISO 6336--6--A08 Calculation of Load Capacity of Spur and Helical Gears-Part 6: Calculation of Service Life Under Variable Load
    Re: Standards agma
    some available at link.
  1. API Standards
    By inconel in forum Mechanical Engineering
    Last Post: 08-18-2025, 09:29 AM
  2. Request ANSI/AGMA 6000-B96 (R2002)
    By 7251 in forum Mechanical Engineering
    Last Post: 02-06-2014, 03:34 PM
  3. AGMA Standards
    By v.munagala in forum Mechanical Engineering
    Last Post: 05-08-2013, 03:44 PM
  4. Request AGMA standards
    By mskhadke in forum Mechanical Engineering
    Last Post: 12-09-2011, 06:02 PM
