Results 1 to 5 of 5
Thread: about SOWCR in eclipse
  1. about SOWCR in eclipse
    hii all, how can i generate the SOWCR in the eclipse. which keyword and in which section that keyword should i use so that i can generate the SOWCR.
    Nov 2008
    Australia
    Strangely, the keyword is SOWCR. Define it as you would any other property, for example by include file, by OPERATE function, by EQUALS function etc..... The section is PROPS
    Strongly suggest you read the Eclipse Technical Description Manual section on Saturation Functions
  5. thanks....
    i know its a keyword... but SOWCR was not being generated... can you tell me the meaning of
    RPTRST
    0 0 0 0 1 0 2 3 1 0 0/
    this is the old convention and i am unable to understand.
    thanks again
    Nov 2008
    Australia
    Not sure what you mean by it is not being generated..... you specify SOWCR, Eclipse does not 'generate' it. If you mean it is not being exported for viewing in 3D, check you have INIT defined
    With regards RPTRST, sorry not familiar with old formats
  7. okkk.... i tried FILLEPS keyword.... it worked.
  1. looking for eclipse
    By anas1980 in forum Reservoir
    Last Post: 06-25-2013, 05:23 PM
  2. Need help in Eclipse
    By vijaysin2000 in forum Reservoir
    Last Post: 11-13-2012, 04:46 PM
