Results 1 to 5 of 5
Thread: Need help in Eclipse
  1. Need help in Eclipse
    Dears Friends,
    I have a model that generates a 4GB PRT and therefore I am unable to rectify errors within the Schedule section.
    Can anyone help how I can reduce the PRT file size.
    Also, my run states that there is spurious data aftera certain date - 1-5-2009; first production date is 1-10-1993.
    Can anyone help rectify the problem?
    Scedule and file error summary attached.
    Vijay
    Attached Files Attached Files
    Re: Need help in Eclipse
    hi
    i have looked at schedule file. it looks like there is something wrong with spaces starting from 31-May-2009. have a look at the file attached, last slide. try to fix spaces for couple month to see if solved problem...
    also i noticed that you NOECHO whole schedule file probably you could save some space (file size) by changing what you are requesting as output...
    Jan 2009
    ALA, KZ
    I would also suggest that you request to report properties in each time step
    Check RPTSCHED keyword
    Better if you post data file here
    Jan 2009
    ALA, KZ
    Jan 2009
    ALA, KZ
    RPTSCHED
    'PRES' 'SOIL' 'SWAT' 'RESTART=1' 'FIP=1' /
    this mean that in any time step in PRT file eclipse writes pressure, soil, swat arrays
    remove them and your prt file will be lighter
  1. looking for eclipse
    By anas1980 in forum Reservoir
    Last Post: 06-25-2013, 05:23 PM
  2. Eclipse
    By chap in forum Reservoir
    Last Post: 12-29-2012, 07:49 AM
