Thread: API 620 vs ASME VIII Div1
  1. Arrow API 620 vs ASME VIII Div1
    Hi friends,
    Im design a vessel/tank and the customer wants us to use API620, I want to know if I can use ASME instead, is this allowed???
  3. Hi Jazz79,would you like to share API620 file?? I need that file. Thanks....
    Jazz79,
    Tanks (Storage tanks) are to API620 or API650 or other "Tank" standards whereas ASME VIII is a pressure vessel Code. Your pressures may be outside the Scope of ASME VIII. Using ASME VIII is well over the top for design of a Tank.
  6. API 620 IS FOR TANK DESIGN AND ASME SEC VIII DEV1 IS FOR DESIGN OF PRESSURE VESSELS. If you can not find any design particulars in API 620, you can refer ASME sec VIII.
    Ultimately ASME SEC VIII is bible for design considerations
  1. Replies: 1
    Last Post: 07-29-2014, 10:26 PM
  2. asme viii div1 appendix 24
    By robydiluca in forum Oil And Gas Production
    Last Post: 05-24-2014, 12:47 PM
  3. ASME PTB-3-2010 asme section viii div.2 ,example problem manual
    By sharmilasu in forum Mechanical Engineering
    Last Post: 04-22-2012, 06:57 AM
  4. Asme esction viii div1 (hinged closure)
    By ravishe in forum Mechanical Engineering
    Last Post: 05-10-2011, 09:49 PM
  5. API 620 vs ASME VIII Div1
    By Jazz79 in forum Mechanical Engineering
    Last Post: 11-16-2009, 04:19 PM
