full list:
EN 200:2008 Sanitary tapware - Single taps and combination taps for water supply systems of type 1 and type 2 - General technical specification
EN 246:2003 Sanitary tapware - General specifications for flow rate regulators
EN 248:2002 Sanitary tapware - General specification for electrodeposited coatings of Ni-Cr
EN 512:1994 Fibre-cement products - Pressure pipes and joints
EN 512:1994/A1:2001 Fibre-cement products - Pressure pipes and joints
EN 639:1994 Common requirements for concrete pressure pipes including joints and fittings
EN 640:1994 Reinforced concrete pressure pipes and distributed reinforcement concrete pressure pipes (non-cylinder type), including joints and fittings
EN 641:1994 Reinforced concrete pressure pipes, cylinder type, including joints and fittings
EN 642:1994 Prestressed concrete pressure pipes, cylinder and non-cylinder, including joints, fittings and specific requirements for prestressing steel for pipes
EN 805:2000 Water supply - Requirements for systems and components outside buildings
EN 806-1:2000 Specifications for installations inside buildings conveying water for human consumption - Part 1: General
EN 806-1:2000/A1:2001 Specifications for installations inside buildings conveying water for human consumption - Part 1: General
EN 806-2:2005 Specification for installations inside buildings conveying water for human consumption - Part 2: Design
EN 806-3:2006 Specifications for installations inside buildings conveying water for human consumption - Part 3: Pipe sizing - Simplified method
EN 806-4:2010 Specifications for installations inside buildings conveying water for human consumption - Part 4: Installation
EN 806-5:2012 Specifications for installations inside buildings conveying water for human consumption - Part 5: Operation and maintenance
EN 816:1996 Sanitary tapware - Automatic shut-off valves PN 10
EN 817:2008 Sanitary tapware - Mechanical mixing valves (PN 10) - General technical specifications
EN 878:2016 Chemicals used for treatment of water intended for human consumption - Aluminium sulfate
EN 881:2004 Chemicals used for treatment of water intended for human consumption - Aluminium chloride (monomeric), aluminium chloride hydroxide (monomeric) and aluminium chloride hydroxide sulfate (monomeric)
EN 882:2016 Chemicals used for treatment of water intended for human consumption - Sodium aluminate
EN 883:2004 Chemicals used for treatment of water intended for human consumption - Polyaluminium chloride hydroxyde and polyaluminium chloride hydroxyde sulfate
EN 885:2004 Chemicals used for treatment of water intended for human consumption - Polyaluminium chloride hydroxide silicate
EN 886:2004 Chemicals used for treatment of water intended for human consumption - Polyaluminium hydroxide silicate sulfate
EN 887:2016 Chemicals used for treatment of water intended for human consumption - Aluminium iron (III) sulfate
EN 888:2004 Chemicals used for treatment of water intended for human consumption - Iron (III) chloride
EN 889:2004 Chemicals used for treatment of water intended for human consumption - Iron (II) sulfate
EN 890:2012 Chemicals used for treatment of water intended for human consumption - Iron (III) sulfate solution
EN 891:2004 Chemicals used for treatment of water intended for human consumption - Iron (III) chloride sulfate
EN 896:2012 Chemicals used for treatment of water intended for human consumption - Sodium hydroxide
EN 897:2012 Chemicals used for treatment of water intended for human consumption - Sodium carbonate
EN 898:2012 Chemicals used for treatment of water intended for human consumption - Sodium hydrogen carbonate
EN 899:2009 Chemicals used for treatment of water intended for human consumption - Sulphuric acid
EN 900:2014 Chemicals used for treatment of water intended for human consumption - Calcium hypochlorite
EN 901:2013 Chemicals used for treatment of water intended for human consumption - Sodium hypochlorite
EN 902:2009 Chemicals used for treatment of water intended for human consumption - Hydrogen peroxide
EN 935:2004 Chemicals used for treatment of water intended for human consumption - Aluminium iron(III) chloride (monomeric) and aluminium iron(III) chloride hydroxide (monomeric)
EN 936:2013 Chemicals used for treatment of water intended for human consumption - Carbon dioxide
EN 937:2009 Chemicals used for treatment of water intended for human consumption - Chlorine
EN 938:2009 Chemicals used for treatment of water intended for human consumption - Sodium chlorite
EN 939:2009 Chemicals used for treatment of water intended for human consumption - Hydrochloric acid
EN 973:2009 Chemicals used for treatment of water intended for human consumption - Sodium chloride for regeneration of ion exchangers
EN 974:2003 Chemicals used for treatment of water intended for human consumption - Phosphoric acid
EN 1017:2014 Chemicals used for treatment of water intended for human consumption - Half-burnt dolomite
EN 1018:2013+A1:2015 Chemicals used for treatment of water intended for human consumption - Calcium carbonate
EN 1019:2005 Chemicals used for treatment of water intended for human consumption - Sulfur dioxide
EN 1111:1998 Sanitary tapware - Thermostatic mixing valves (PN 10) - General technical specification
EN 1112:2008 Sanitary tapware - Shower outlets for sanitary tapware for water supply systems of type 1 and type 2 - General technical specification
EN 1113:2015 Sanitary tapware - Shower hoses for sanitary tapware for water supply systems of type 1 and type 2 - General technical specification
EN 1197:2014 Chemicals used for treatment of water intended for human consumption - Monozinc phosphate solution
EN 1198:2005 Chemicals for treatment of water intended for human consumption - Sodium dihydrogen orthophosphate
EN 1199:2005 Chemicals used for treatment of water intended for human consumption - Disodium hydrogen orthophosphate
EN 1200:2005 Chemicals used for treatment of water intended for human consumption - Trisodium orthophosphate
EN 1201:2005 Chemicals used for treatment of water intended for human consumption - Potassium dihydrogen orthophosphate
EN 1202:2005 Chemicals used for treatment of water intended for human consumption - Dipotassium hydrogen orthophosphate
EN 1203:2005 Chemicals used for treatment of water intended for human consumption - Tripotassium orthophosphate
EN 1204:2005 Chemicals used for treatment of water intended for human consumption - Calcium tetrahydrogen bis(orthophosphate)
EN 1205:2005 Chemicals used for treatment of water intended for human consumption - Disodium dihydrogen pyrophosphate
EN 1206:2005 Chemicals used for treatment of water intended for human consumption - Tetrasodium pyrophosphate
EN 1207:2005 Chemicals used for treatment of water intended for human consumption - Tetrapotassium pyrophosphate
EN 1208:2005 Chemicals used for treatment of water intended for human consumption - Sodium calcium polyphosphate
EN 1209:2003 Chemicals used for treatment of water intended for human consumption - Sodium silicate
EN 1210:2005 Chemicals used for treatment of water intended for human consumption - Sodium tripolyphosphate
EN 1211:2005 Chemicals used for treatment of water intended for human consumption - Potassium tripolyphosphate
EN 1212:2005 Chemicals used for treatment of water intended for human consumption - Sodium polyphosphate
EN 1213:1999 Building valves - Copper alloy stopvalves for potable water supply in buildings - Tests and requirements
EN 1278:2010 Chemicals used for treatment of water intended for human consumption - Ozone
EN 1286:1999 Sanitary tapware - Low pressure mechanical mixing valves - General technical specification
EN 1287:1999 Sanitary tapware - Low pressure thermostatic mixing valves - General technical specifications
EN 1302:1999 Chemicals used for treatment of water intended for human consumption - Aluminium-based coagulants - Analytical methods
EN 1302:1999/AC:2002 Chemicals used for treatment of water intended for human consumption - Aluminium-based coagulants - Analytical methods
EN 1405:2009 Chemicals used for treatment of water intended for human consumption - Sodium alginate
EN 1406:2009 Chemicals used for treatment of water intended for human consumption - Modified starches
EN 1407:2008 Chemicals used for treatment of water intended for human consumption - Anionic and non-ionic polyacrylamides
EN 1408:2008 Chemicals used for treatment of water intended for human consumption - Poly (diallyldimethylammonium chloride)
EN 1409:2008 Chemicals used for water treatment intended for human consumption - Polyamines
EN 1410:2008 Chemicals used for treatment of water intended for human consumption - Cationic polyacrylamides
EN 1420:2016 Influence of organic materials on water intended for human consumption - Determination of odour and flavour assessment of water in piping systems
EN 1421:2012 Chemicals used for treatment of water intended for human consumption - Ammonium chloride
EN 1444:2000 Fibre-cement pipelines - Guide for laying and on-site work practices
EN 1487:2014 Building valves - Hydraulic safety groups - Tests and requirements
EN 1488:2000 Building valves - Expansion groups - Tests and requirements
EN 1489:2000 Building valves - Pressure safety valves - Tests and requirements
EN 1490:2000 Building valves - Combined temperature and pressure relief valves - Tests and requirements
EN 1491:2000 Building valves - Expansion valves - Tests and requirements
EN 1508:1998 Water supply - Requirements for systems and components for the storage of water
EN 1567:1999 Building valves - Water pressure reducing valves and combination water pressure reducing valves - Requirements and tests
EN 1717:2000 Protection against pollution of potable water in water installations and general requirements of devices to prevent pollution by backflow
EN 12120:2012 Chemicals used for treatment of water intended for human consumption - Sodium hydrogen sulfite
EN 12121:2012 Chemicals used for treatment of water intended for human consumption - Sodium disulfite
EN 12122:2005 Chemicals used for treatment of water intended for human consumption - Ammonia solution
EN 12123:2012 Chemicals used for treatment of water intended for human consumption - Ammonium sulfate
EN 12124:2012 Chemicals used for treatment of water intended for human consumption - Sodium sulfite
EN 12125:2012 Chemicals used for treatment of water intended for human consumption - Sodium thiosulfate
EN 12126:2012 Chemicals used for treatment of water intended for human consumption - Liquefied ammonia
EN 12173:2012 Chemicals used for treatment of water intended for human consumption - Sodium fluoride
EN 12174:2013 Chemicals used for treatment of water intended for human consumption - Sodium hexafluorosilicate
EN 12175:2013 Chemicals used for treatment of water intended for human consumption - Hexafluorosilicic acid
EN 12386:2012 Chemicals used for treatment of water intended for human consumption - Copper sulfate
EN 12485:2010 Chemicals used for treatment of water intended for human consumption - Calcium carbonate, high-calcium lime, half-burnt dolomite, magnesium oxide and calcium magnesium carbonate - Test methods
EN 12518:2014 Chemicals used for treatment of water intended for human consumption - High-calcium lime
EN 12541:2002 Sanitary tapware - Pressure flushing valves and automatic closing urinal valves PN 10
EN 12671:2009 Chemicals used for treatment of water intended for human consumption - Chlorine dioxide generated in situ
EN 12672:2008 Chemicals used for treatment of water intended for human consumption - Potassium permanganate
EN 12678:2008 Chemicals used for treatment of water intended for human consumption - Potassium peroxomonosulfate
EN 12729:2002 Devices to prevent pollution by backflow of potable water - Controllable backflow preventer with reduced pressure zone - Family B - Type A
EN 12873-1:2014 Influence of materials on water intended for human consumption - Influence due to migration - Part 1: Test method for factory-made products made from or incorporating organic or glassy (porcelain/vitreous enamel) materials
EN 12873-2:2005 Influence of materials on water intended for human consumption - Influence due to migration - Part 2: Test method for non-metallic and non-cementitious site-applied materials
EN 12873-3:2006 Influence of materials on water intended for human consumption - Influence due to migration - Part 3: Test method for ion exchange and adsorbent resins
EN 12873-4:2006 Influence of materials on water intended for human consumption - Influence due to migration - Part 4: Test method for water treatment membranes
EN 12876:2015 Chemicals used for treatment of water intended for human consumption - Oxygen
EN 12897:2006 Water supply - Specification for indirectly heated unvented (closed) storage water heaters
EN 12901:1999 Products used for treatment of water intended for human consumption - Inorganic supporting and filtering materials - Definitions
EN 12902:2004 Products used for treatment of water intended for human consumption - Inorganic supporting and filtering materials - Methods of test
EN 12903:2009 Products used for the treatment of water intended for human consumption - Powdered activated carbon
EN 12904:2005 Products used for treatment of water intended for human consumption - Silica sand and silica gravel
EN 12905:2012 Products used for treatment of water intended for human consumption - Expanded aluminosilicate
EN 12906:2012 Products used for treatment of water intended for human consumption - Pumice
EN 12907:2009 Products used for treatment of water intended for human consumption - Pyrolyzed coal material
EN 12909:2012 Products used for treatment of water intended for human consumption - Anthracite
EN 12910:2012 Products used for treatment of water intended for human consumption - Garnet
EN 12911:2013 Products used for treatment of water intended for human consumption - Manganese greensand
EN 12912:2012 Products used for treatment of water intended for human consumption - Barite
EN 12913:2012 Products used for treatment of water intended for human consumption - Powdered diatomaceous earth
EN 12914:2012 Products used for treatment of water intended for human consumption - Powdered perlite
EN 12915-1:2009 Products used for the treatment of water intended for human consumption - Granular activated carbon - Part 1: Virgin granular activated carbon
EN 12915-2:2009 Products used for the treatment of water intended for human consumption - Granular activated carbon - Part 2: Reactivated granular activated carbon
EN 12926:2015 Chemicals used for treatment of water intended for human consumption - Sodium peroxodisulfate
EN 12931:2015 Chemicals used for treatment of water intended for human consumption - Chemicals for emergency use - Sodium dichloroisocyanurate, anhydrous
EN 12932:2015 Chemicals used for treatment of water intended for human consumption - Chemicals for emergency use - Sodium dichloroisocyanurate, dihydrate
EN 12933:2015 Chemicals used for treatment of water intended for human consumption - Chemicals for emergency use - Trichloroisocyanuric acid
EN 13052-1:2001 Influence of materials on water intended for human consumption - Organic materials - Determination of colour and turbidity of water in piping systems - Part 1: Test method
EN 13076:2003 Devices to prevent pollution by backflow of potable water - Unrestricted air gap-Family A - Type A
EN 13077:2008 Devices to prevent pollution by backflow of potable water - Air gap with non-circular overflow (unrestricted) - Family A - Type B
EN 13078:2003 Devices to prevent pollution by backflow of potable water - Air gap with submerged feed incorporating air inlet plus overflow - Family A, type C
EN 13079:2003 Devices to prevent pollution by backflow of potable water - Air gap with injector - Family A - Type D
EN 13176:2015 Chemicals used for treatment of water intended for human consumption - Ethanol
EN 13177:2010 Chemicals used for treatment of water intended for human consumption - Methanol
EN 13194:2015 Chemicals used for treatment of water intended for human consumption - Acetic Acid
EN 13443-1:2002+A1:2007 Water conditioning equipment inside buildings - Mechanical filters - Part 1: Particle rating 80 µm to 150 µm - Requirements for performances, safety and testing
EN 13443-2:2005+A1:2007 Water conditioning equipment inside buildings - Mechanical filters - Part 2: Particle rating 1 µm to less than 80 µm - Requirements for performance, safety and testing
EN 13618:2011 Flexible hose assemblies in drinking water installations - Functional requirements and test methods
EN 13752:2012 Products used for treatment of water intended for human consumption - Manganese dioxide
EN 13753:2009 Products used for treatment of water intended for human consumption - Granular activated alumina
EN 13754:2009 Products used for treatment of water intended for human consumption - Bentonite
EN 13828:2003 Building valves - Manually operated copper alloy and stainless steel ball valves for potable water supply in buildings -Tests and requirements
EN 13959:2004 Anti-pollution check valves - DN 6 to DN 250 inclusive family E, type A, B, C and D
EN 14095:2003 Water conditioning equipment inside buildings - Electrolytic treatment systems with aluminium anodes - Requirements for performance, safety and testing
EN 14124:2004 Inlet valves for flushing cisterns with internal overflow
CR 14269:2001 Chemicals used for treatment of water intended for human consumption - Guidelines for the purchase
EN 14367:2005 Non controllable backflow preventer with different pressure zones - Family C, type A
EN 14368:2015 Products used for treatment of water intended for human consumption - Manganese dioxide coated limestone
EN 14369:2015 Products used for treatment of water intended for human consumption - Iron-coated granular activated alumina
EN 14395-1:2004 Influence of organic materials on water intended for human consumption - Organoleptic assessment of water in storage systems - Part 1: Test method
EN 14451:2005 Devices to prevent pollution by backflow of potable water - In-line anti-vacuum valves DN 8 to DN 80 - Family D, type A
EN 14452:2005 Devices to prevent pollution by backflow of potable water - Pipe interrupter with atmospheric vent and moving element DN 10 to DN 20 - Family D, type B
EN 14453:2005 Devices to prevent pollution by backflow of potable water - Pipe interrupter with permanent atmospheric vent DN 10 to DN 20 - Family D, type C
EN 14454:2005 Devices to prevent pollution by backflow of potable water - Hose union backflow preventer DN 15 to DN 32 - Family H, type A
EN 14455:2005 Devices to prevent pollution by backflow of potable water - Presssurised air inlet valves DN 15 to DN 50 - Family L, type A and type B
EN 14456:2004 Products used for treatment of water intended for human consumption - Bone charcoal
EN 14506:2005 Devices to prevent pollution by backflow of potable water - Automatic diverter - Family H, type C
EN 14622:2005 Devices to prevent pollution by backflow of potable water - Air gap with circular overflow (restricted) - Family A, type F
EN 14623:2005 Devices to prevent pollution by backflow of potable water - Air gaps with minimum circular overflow (verified by test or measurement) - Family A, type G
EN 14664:2004 Chemicals used for treatment of water intended for human consumption - Iron (III) sulfate, solid
EN 14652:2005+A1:2007 Water conditioning equipment inside buildings - Membrane separation devices - Requirements for performance, safety and testing
EN 14718:2014 Influence of organic materials on water intended for human consumption - Determination of the chlorine demand - Test method
CEN/TR 14740:2004 Chemical used for treatment of water intended for human consumption - Ozone-Production - Guidelines for installations and minimal functional requirements
EN 14743:2005+A1:2007 Water conditioning equipment inside buildings - Softeners - Requirements for performance, safety and testing
EN 14805:2008 Chemicals used for treatment of water intended for human consumption - Sodium chloride for on site electrochlorination using non-membrane technology
EN 14812:2005+A1:2007 Water conditioning equipment inside buildings - Chemical dosing systems - Pre-set dosing systems - Requirements for performance, safety and testing
EN 14897:2006+A1:2007 Water conditioning equipment inside buildings - Devices using mercury low-pressure ultraviolet radiators - Requirements for performance, safety and testing
EN 14898:2006+A1:2007 Water conditioning equipment inside buildings - Active media filters - Requirements for performance, safety and testing
EN 14944-1:2006 Influence of cementitious products on water intended for human consumption - Test methods - Part 1: Influence of factory made cementitious products on organoleptic parameters
EN 14944-3:2007 Influence of cementitious products on water intended for human consumption - Test methods - Part 3: Migration of substances from factory-made cementititous products
EN 15028:2012 Chemicals used for treatment of water intended for human consumption - Sodium chlorate
EN 15029:2012 Products used for treatment of water intended for human consumption - Iron (III) hydroxide oxide
EN 15030:2012+A1:2015 Chemicals used for treatment of water intended for human consumption - Silver salts for intermittent use
EN 15031:2013 Chemicals used for treatment of swimming pool water - Aluminium based coagulants
EN 15032:2006+A1:2008 Chemicals used for treatment of swimming pool water - Trichloroisocyanuric acid
EN 15039:2014 Chemicals used for treatment of water intended for human consumption - Antiscalants for membranes - Polycarboxilic acids and salts
EN 15040:2014 Chemicals used for treatment of water intended for human consumption - Antiscalants for membranes - Phosphonic acids and salts
EN 15041:2014 Chemicals used for treatment of water intended for human consumption - Antiscalants for membranes - Polyphosphates
EN 15072:2013 Chemicals used for treatment of swimming pool water - Sodium dichloroisocyanurate, anhydrous
EN 15073:2013 Chemicals used for treatment of swimming pool water - Sodium dichloroisocyanurate, dihydrate
EN 15074:2014 Chemicals used for treatment of swimming pool water - Ozone
EN 15075:2013 Chemicals used for treatment of swimming pool water - Sodium hydrogen carbonate
EN 15076:2013 Chemicals used for treatment of swimming pool water - Sodium hydroxide
EN 15077:2013 Chemicals used for treatment of swimming pool water - Sodium hypochlorite
EN 15078:2013 Chemicals used for treatment of swimming pool water - Sulfuric acid
EN 15091:2013 Sanitary tapware - Electronic opening and closing sanitary tapware
EN 15092:2008 Building valves - Inline hot water supply tempering valves - Tests and requirements
EN 15096:2008 Devices to prevent pollution by backflow of potable water - Hose Union anti-vacuum valves - DN 15 to DN 25 inclusive Family H, type B and type D - General technical specification
EN 15161:2006 Water conditioning equipment inside buildings - Installation, operation, maintenance and repair
EN 15219:2006+A1:2007 Water conditioning equipment inside buildings - Nitrate removal devices - Requirements for performance, safety and testing
EN 15362:2014 Chemicals used for treatment of swimming pool water - Sodium carbonate
EN 15363:2014 Chemicals used for treatment of swimming pool water - Chlorine
EN 15482:2012 Chemicals used for treatment of water intended for human consumption - Sodium permanganate
EN 15513:2014 Chemicals used for treatment of swimming pool water - Carbon dioxide
EN 15514:2014 Chemicals used for treatment of swimming pool water - Hydrochloric acid
EN 15664-1:2008+A1:2013 Influence of metallic materials on water intended for human consumption - Dynamic rig test for assessment of metal release - Part 1: Design and operation
EN 15664-2:2010 Influence of metallic materials on water intended for human consumption - Dynamic rig test for assessment of metal release - Part 2: Test waters
EN 15768:2015 Influence of materials on water intended for human consumption - GC-MS identification of water leachable organic substances
EN 15795:2010 Products used for treatment of water intended for human consumption - Natural unexpanded aluminosilicates
EN 15796:2010 Chemicals used for treatment of swimming pool water - Calcium hypochlorite
EN 15797:2010 Chemicals used for the treatment of swimming pool water - Iron based coagulants
EN 15798:2010 Products used for the treatment of swimming pool water - Filter media
EN 15799:2010 Products used for treatment of swimming pool water - Powdered activated carbon
EN 15848:2010 Water conditioning equipment inside buildings - Adjustable chemical dosing systems - Requirements for performance, safety and testing
EN 15975-1:2011+A1:2015 Security of drinking water supply - Guidelines for risk and crisis management - Part 1: Crisis management
EN 15975-2:2013 Security of drinking water supply - Guidelines for risk and crisis management - Part 2: Risk management
EN 16003:2011 Chemicals used for treatment of water intended for human consumption - Calcium magnesium carbonate
EN 16004:2011 Chemicals used for treatment of water intended for human consumption - Magnesium oxide
EN 16037:2012 Chemicals used for treatment of water intended for human consumption - Sodium hydrogen sulfate
EN 16038:2012 Chemicals used for treatment of water for swimming pools - Sodium hydrogen sulfate
EN 16056:2012 Influence of metallic materials on water intended for human consumption - Method to evaluate the passive behaviour of stainless steels
EN 16057:2012 Influence of metallic materials on water intended for human consumption - Determination of residual surface lead (Pb) - Extraction method
EN 16058:2012 Influence of metallic materials on water intended for human consumption - Dynamic rig test for assessment of surface coatings with nickel layers - Long-term test method
EN 16070:2014 Products used for treatment of water intended for human consumption - Natural zeolite
EN 16145:2012 Sanitary tapware - Extractable outlets for sink and basin mixers - General technical specification
EN 16146:2012+A1:2014 Sanitary tapware - Extractable shower hoses for sanitary tapware for supply systems type 1 and type 2 - General technical specification
CEN/TR 16355:2012 Recommendations for prevention of Legionella growth in installations inside buildings conveying water for human consumption
CEN/TR 16364:2012 Influence of materials on water intended for human consumption - Influence due to migration - Prediction of migration from organic materials using mathematical modelling
EN 16370:2013 Chemicals used for treatment of water intended for human consumption - Sodium chloride for on site electrochlorination using membrane cells
EN 16380:2013 Chemicals used for treatment of swimming pool water - Potassium peroxomonosulfate
EN 16381:2013 Chemicals used for treatment of swimming pool water - Sodium peroxodisulfate
EN 16399:2013 Chemicals used for treatment of swimming pool water - Sodium thiosulfate
EN 16400:2013 Chemicals used for treatment of swimming pool water - Hydrogen peroxide
EN 16401:2013 Chemicals used for treatment of swimming pool water - Sodium chloride used for electrochlorinator systems
EN 16409:2013 Chemicals used for treatment of water intended for human consumption - Dolomitic lime
EN 16421:2014 Influence of materials on water for human consumption - Enhancement of microbial growth (EMG)
missing:
or
