full list:
EN 124-1:2015 Gully tops and manhole tops for vehicular and pedestrian areas - Part 1: Definitions, classification, general principles of design, performance requirements and test methods
EN 124-2:2015 Gully tops and manhole tops for vehicular and pedestrian areas - Part 2: Gully tops and manhole tops made of cast iron
EN 124-3:2015 Gully tops and manhole tops for vehicular and pedestrian areas - Part 3: Gully tops and manhole tops made of steel or aluminium alloys
EN 124-4:2015 Gully tops and manhole tops for vehicular and pedestrian areas - Part 4: Gully tops and manhole tops made of steel reinforced concrete
EN 124-5:2015 Gully tops and manhole tops for vehicular and pedestrian areas - Part 5: Gully tops and manhole tops made of composite materials
EN 124-6:2015 Gully tops and manhole tops for vehicular and pedestrian areas - Part 6: Gully tops and manhole tops made of polypropylene (PP), polyethylene (PE) or unplasticized poly(vinyl chloride) (PVC-U)
EN 274-1:2002 Waste fittings for sanitary appliances - Part 1: Requirements
EN 274-2:2002 Waste fittings for sanitary appliances - Part 2: Test methods
EN 274-3:2002 Waste fittings for sanitary appliances - Part 3: Quality control
EN 295-1:2013 Vitrified clay pipe systems for drains and sewers - Part 1: Requirements for pipes, fittings and joints
EN 295-2:2013 Vitrified clay pipe systems for drains and sewers - Part 2: Evaluation of conformity and sampling
EN 295-3:2012 Vitrified clay pipe systems for drains and sewers - Part 3: Test methods
EN 295-4:2013 Vitrified clay pipe systems for drains and sewers - Part 4: Requirements for adaptors, connectors and flexible couplings
EN 295-5:2013 Vitrified clay pipe systems for drains and sewers - Part 5: Requirements for perforated pipes and fittings
EN 295-6:2013 Vitrified clay pipes systems for drain and sewers - Part 6: Requirements for components of manholes and inspection chambers
EN 295-7:2013 Vitrified clay pipe systems for drains and sewers - Part 7: Requirements for pipes and joints for pipe jacking
EN 476:2011 General requirements for components used in drains and sewers
EN 588-1:1996 Fibre-cement pipes for sewers and drains - Part 1: Pipes, joints and fittings for gravity systems
EN 588-2:2001 Fibre cement pipes for drains and sewers - Part 2: Manholes and inspection chambers
EN 752:2008 Drain and sewer systems outside buildings
EN 858-1:2002 Separator systems for light liquids (e.g. oil and petrol) - Part 1: Principles of product design, performance and testing, marking and quality control
EN 858-1:2002/A1:2004 Separator systems for light liquids (e.g. oil and petrol) - Part 1: Principles of product design, performance and testing, marking and quality control
EN 858-2:2003 Separator systems for light liquids (e.g. oil and petrol) - Part 2: Selection of nominal size, installation, operation and maintenance
EN 1091:1996 Vacuum sewerage systems outside buildings
EN 1123-1:1999 Pipes and fittings of longitudinally welded hot-dip galvanized steel pipes with spigot and socket for waste water systems - Part 1: Requirements, testing, quality control
EN 1123-1:1999/A1:2004 Pipes and fittings of longitudinally welded hot-dip galvanized steel pipes with spigot and socket for waste water systems - Part 1: Requirements, testing, quality control
EN 1123-2:2006+A1:2007 Pipes and fittings of longitudinally welded hot-dip galvanized steel tube with spigot and socket for waste water systems - Part 2: Dimensions
EN 1123-3:2004 Pipes and fittings of longitudinally welded hot-dip galvanized steel pipes with spigot and socket for waste water systems - Part 3: Dimensions and special requirements for vacuum drainage systems and for drainage systems in ship-building
EN 1124-1:1999 Pipes and fittings of longitudinally welded stainless steel pipes with spigot and socket for waste water systems - Part 1: Requirements, testing, quality control
EN 1124-1:1999/A1:2004 Pipes and fittings of longitudinally welded stainless steel pipes with spigot and socket for waste water systems - Part 1: Requirements, testing, quality control
EN 1124-2:2014 Pipes and fittings of longitudinally welded stainless steel pipes with spigot and socket for waste water systems - Part 2: System S, forms and dimensions
EN 1124-3:2008 Pipes and fittings of longitudinally welded stainless steel pipes with spigot and socket for waste water systems - Part 3: System X - Dimensions
EN 1124-4:2013 Pipes and fittings of longitudinally welded stainless steel pipes with spigot and socket for wastewater systems - Part 4: Components for vacuum drainage systems and for drainage systems on ships
EN 1253-1:2015 Gullies for buildings - Part 1: Trapped floor gullies with a depth water seal of at least 50 mm
EN 1253-2:2015 Gullies for buildings - Part 2: Roof drains and floor gullies without trap
EN 1253-3:1999 Gullies for buildings - Part 3: Quality control
EN 1253-4:1999 Gullies for buildings - Part 4: Access covers
EN 1253-5:2003 Gullies for buildings - Part 5: Gullies with light liquids closure
EN 1295-1:1997 Structural design of buried pipelines under various conditions of loading - Part 1: General requirements
CEN/TR 1295-2:2005 Structural design of buried pipelines under various conditions of loading - Part 2: Summary of nationally established methods of design
CEN/TR 1295-3:2007 Structural design of buried pipelines under various conditions of loading - Part 3: Common method
CEN/TR 1295-4:2015 Structural design of buried pipelines under various conditions of loading - Part 4: Parameters for reliability of the design
EN 1433:2002 Drainage channels for vehicular and pedestrian areas - Classification, design and testing requirements, marking and evaluation of conformity
EN 1433:2002/AC:2004 Drainage channels for vehicular and pedestrian areas - Classification, design and testing requirements, marking and evaluation of conformity
EN 1433:2002/A1:2005 Drainage channels for vehicular and pedestrian areas - Classification, design and testing requirements, marking and evaluation of conformity
EN 1610:2015 Construction and testing of drains and sewers
EN 1671:1997 Pressure sewerage systems outside buildings
EN 1825-1:2004 Grease separators - Part 1: Principles of design, performance and testing, marking and quality control
EN 1825-1:2004/AC:2006 Grease separators - Part 1: Principles of design, performance and testing, marking and quality control
EN 1825-2:2002 Grease separators - Part 2: Selection of nominal size, installation, operation and maintenance
EN 1916:2002 Concrete pipes and fittings, unreinforced, steel fibre and reinforced
EN 1916:2002/AC:2008 Concrete pipes and fittings, unreinforced, steel fibre and reinforced
EN 1917:2002 Concrete manholes and inspection chambers, unreinforced, steel fibre and reinforced
EN 1917:2002/AC:2008 Concrete manholes and inspection chambers, unreinforced, steel fibre and reinforced
EN 12050-1:2015 Wastewater lifting plants for buildings and sites - Part 1: Lifting plants for wastewater containing faecal matter
EN 12050-2:2015 Wastewater lifting plants for buildings and sites - Part 2: Lifting plants for faecal-free wastewater
EN 12050-3:2015 Wastewater lifting plants for buildings and sites - Part 3: Lifting plants for limited applications
EN 12050-4:2015 Wastewater lifting plants for buildings and sites - Part 4: Non-return valves for faecal-free wastewater and wastewater containing faecal matter
EN 12056-1:2000 Gravity drainage systems inside buildings - Part 1: General and performance requirements
EN 12056-2:2000 Gravity drainage systems inside buildings - Part 2: Sanitary pipework, layout and calculation
EN 12056-3:2000 Gravity drainage systems inside buildings - Part 3: Roof drainage, layout and calculation
EN 12056-4:2000 Gravity drainage systems inside buildings - Part 4: Wastewater lifting plants - Layout and calculation
EN 12056-5:2000 Gravity drainage systems inside buildings - Part 5: Installation and testing, instructions for operation, maintenance and use
EN 12109:1999 Vacuum drainage systems inside buildings
EN 12255-1:2002 Wastewater treatment plants - Part 1: General construction principles
EN 12255-3:2000 Wastewater treatment plants - Part 3: Preliminary treatment
EN 12255-3:2000/AC:2000 Wastewater treatment plants - Part 3: Preliminary treatment
EN 12255-4:2002 Wastewater treatment plants - Part 4: Primary settlement
EN 12255-5:1999 Wastewater treatment plants - Part 5: Lagooning processes
EN 12255-6:2002 Wastewater treatment plants - Part 6: Activated sludge process
EN 12255-7:2002 Wastewater treatment plants - Part 7: Biological fixed-film reactors
EN 12255-8:2001 Wastewater treatment plants - Part 8: Sludge treatment and storage
EN 12255-9:2002 Wastewater treatment plants - Part 9: Odour control and ventilation
EN 12255-10:2000 Wastewater treatment plants - Part 10: Safety principles
EN 12255-11:2001 Wastewater treatment plants - Part 11: General data required
EN 12255-12:2003 Wastewater treatment plants - Part 12: Control and automation
EN 12255-13:2002 Wastewater treatment plants - Part 13: Chemical treatment - Treatment of wastewater by precipitation/flocculation
EN 12255-14:2003 Wastewater treatment plants - Part 14: Disinfection
EN 12255-15:2003 Wastewater treatment plants - Part 15: Measurement of the oxygen transfer in clean water in aeration tanks of activated sludge plants
EN 12255-16:2005 Wastewater treatment plants - Part 16: Physical (mechanical) filtration
EN 12380:2002 Air admittance valves for drainage systems - Requirements, tests methods and evaluation of conformity
EN 12566-1:2000 Small wastewater treatment systems for up to 50 PT - Part 1: Prefabricated septic tanks
EN 12566-1:2000/A1:2003 Small wastewater treatment systems for up to 50 PT - Part 1: Prefabricated septic tanks
CEN/TR 12566-2:2005 Small wastewater treatment systems for up to 50 PT - Part 2: Soil infiltration systems
EN 12566-3:2005+A2:2013 Small wastewater treatment systems for up to 50 PT - Part 3: Packaged and/or site assembled domestic wastewater treatment plants
EN 12566-4:2007 Small wastewater treatment systems for up to 50 PT - Part 4: Septic tanks assembled in situ from prefabricated kits
CEN/TR 12566-5:2008 Small wastewater treatment systems up to 50 PT - Part 5: Pre-treated Effluent Filtration systems
EN 12566-6:2013 Small wastewater treatment systems for up to 50 PT - Part 6: Prefabricated treatment units for septic tank effluent
EN 12566-7:2013 Small wastewater treatment systems for up to 50 PT - Part 7: Prefabricated tertiary treatment units
EN 12763:2000 Fibre-cement pipes and fittings for discharge systems for buildings - Dimensions and technical terms of delivery
EN 12889:2000 Trenchless construction and testing of drains and sewers
EN 13101:2002 Steps for underground man entry chambers - Requirements, marking, testing and evaluation of conformity
EN 13380:2001 General requirements for components used for renovation and repair of drain and sewer systems outside buildings
EN 13508-1:2012 Investigation and assessment of drain and sewer systems outside buildings - Part 1: General Requirements
EN 13508-2:2003+A1:2011 Investigation and assessment of drain and sewer systems outside buildings - Part 2: Visual inspection coding system
EN 13564-1:2002 Anti-flooding devices for buildings - Part 1: Requirements
EN 13564-2:2002 Anti-flooding devices for buildings - Part 2: Test methods
EN 13564-3:2003 Anti-flooding devices for buildings - Part 3: Quality assurance
EN 14396:2004 Fixed ladders for manholes
EN 14457:2004 General requirements for components specifically designed for use in trenchless construction of drains and sewers
EN 14654-1:2014 Management and control of operational activities in drain and sewer systems outside buildings - Part 1: Cleaning
EN 14654-2:2013 Management and control of operational activities in drain and sewer systems outside buildings - Part 2: Rehabilitation
EN 14801:2006 Conditions for pressure classification of products for water and wastewater pipelines
CEN/TR 14920:2005 Jetting resistance of drain and sewer pipes - Moving jet test method
EN 15885:2010 Classification and characteristics of techniques for renovation and repair of drains and sewers
EN 16323:2014 Glossary of wastewater engineering terms
EN 16397-1:2014 Flexible couplings - Part 1: Performance requirements
EN 16397-2:2014 Flexible couplings - Part 2: Characteristics and testing for metal banded flexible couplings, adaptors and bushes
EN 16506:2014 Systems for renovation of drains and sewers - Lining with a rigidly anchored plastics inner layer (RAPL)
CEN/TR 16626:2014 Vitrified clay pipe systems for drains and sewers - Guidance for voluntary third-party certification procedures
missing:
or
