only 1 VE is missing
EN 12952-1:2015 Water-tube boilers and auxiliary installations - Part 1: General - missing VE
EN 12952-2:2011 Water-tube boilers and auxiliary installations - Part 2: Materials for pressure parts of boilers and accessories
EN 12952-3:2011 Water-tube boilers and auxiliary installations - Part 3: Design and calculation for pressure parts of the boiler
EN 12952-4:2011 Water-tube boilers and auxiliary installations - Part 4: In-service boiler life expectancy calculations
EN 12952-5:2011 Water-tube boilers and auxiliary installations - Part 5: Workmanship and construction of pressure parts of the boiler
EN 12952-6:2011 Water-tube boilers and auxiliary installations - Part 6: Inspection during construction; documentation and marking of pressure parts of the boiler
EN 12952-7:2012 Water-tube boilers and auxiliary installations - Part 7: Requirements for equipment for the boiler
EN 12952-8:2002 Water-tube boilers and auxiliary installations - Part 8: Requirements for firing systems for liquid and gaseous fuels for the boiler
EN 12952-9:2002 Water-tube boilers and auxiliary installations - Part 9: Requirements for firing systems for pulverized solid fuels for the boiler
EN 12952-10:2002 Water-tube boilers and auxiliary installations - Part 10: Requirements for safeguards against excessive pressure
EN 12952-11:2007 Water-tube boilers and auxiliary installations - Part 11: Requirements for limiting devices of the boiler and accessories
EN 12952-12:2003 Water-tube boilers and auxiliary installations - Part 12: Requirements for boiler feedwater and boiler water quality
EN 12952-13:2003 Water-tube boilers and auxiliary installations - Part 13: Requirements for flue gas cleaning systems
EN 12952-13:2003/A1:2003 Water-tube boilers and auxiliary installations - Part 13: Requirements for flue gas cleaning systems
EN 12952-14:2004 Water-tube boilers and auxiliary installations - Part 14: Requirements for flue gas DENOX-systems using liquefied pressurized ammonia and ammonia water solution
EN 12952-15:2003 Water-tube boilers and auxiliary installations - Part 15: Acceptance tests
EN 12952-16:2002 Water-tube boilers and auxiliary installations - Part 16: Requirements for grate and fluidized-bed firing systems for solid fuels for the boiler
CR 12952-17:2002 Water boilers and auxiliary installations - Part 17: Guideline for the involvement of an inspection body independent of the manufacturer
EN 12952-18:2012 Water-tube boilers and auxiliary installations - Part 18: Operating instructions
EN 12953-1:2012 Shell boilers - Part 1: General
EN 12953-2:2012 Shell boilers - Part 2: Materials for pressure parts of boilers and accessories
EN 12953-3:2002 Shell boilers - Part 3: Design and calculation for pressure parts
EN 12953-4:2002 Shell boilers - Part 4: Workmanship and construction of pressure parts of the boiler
EN 12953-5:2002 Shell boilers - Part 5: Inspection during construction, documentation and marking of pressure parts of the boiler
EN 12953-6:2011 Shell Boilers - Part 6: Requirements for equipment for the boiler
EN 12953-7:2002 Shell boilers - Part 7 : Requirements for firing systems for liquid and gaseous fuels for the boilers
EN 12953-8:2001 Shell boilers - Part 8: Requirements for safeguards against excessive pressure
EN 12953-8:2001/AC:2002 Shell boilers - Part 8: Requirements for safeguards against excessive pressure
EN 12953-9:2007 Shell boilers - Part 9: Requirements for limiting devices of the boiler and accessories
EN 12953-10:2003 Shell boilers - Part 10 : Requirements for feedwater and boiler water quality
EN 12953-11:2003 Shell boilers - Part 11: Acceptance tests
EN 12953-12:2003 Shell boilers - Part 12: Requirements for grate firing systems for solid fuels for the boiler
EN 12953-13:2012 Shell boilers - Part 13: Operating instructions
CR 12953-14:2002 Shell boilers - Part 14: Guideline for involvement of an inspection body independent of the manufacturer
EN 14222:2003 Stainless steel shell boilers
or
