full list:
EN 1516:1999 Surfaces for sports areas - Determination of resistance to indentation
EN 1517:1999 Surfaces for sports areas - Determination of resistance to impact
EN 1569:1999 Surfaces for sports areas - Determination of the behaviour under a rolling load
EN 1969:2000 Surfaces for sports areas - Determination of thickness of synthetic sports surfaces
EN 12228:2013 Surfaces for sports areas - Determination of joint strength of synthetic surfaces
EN 12229:2014 Surfaces for sports areas - Procedure for the preparation of synthetic turf and needle-punch test pieces
EN 12230:2003 Surfaces for sports areas - Determination of tensile properties of synthetic sports surfaces
EN 12231:2003 Surfaces for sports areas - Method of test - Determination of ground cover of natural turf
EN 12232:2003 Surfaces for sports areas - Determination of thatch depth of natural turf
EN 12233:2003 Surfaces for sports areas - Determination of sward height of natural turf
EN 12234:2013 Surfaces for sports areas - Determination of ball roll behaviour
EN 12235:2013 Surfaces for sports areas - Determination of vertical ball behaviour
EN 12616:2013 Surfaces for sports areas - Determination of water infiltration rate
EN 13672:2004 Surfaces for sports areas - Determination of resistance to abrasion of non-filled synthetic turf
EN 13744:2004 Surfaces for sports areas - Procedure for accelerated ageing by immersion in hot water
EN 13745:2004 Surfaces for sports areas - Determination of specular reflectance
EN 13746:2004 Surfaces for sports areas - Determination of dimensional changes due to the effect of varied water, frost and heat conditions
EN 13817:2004 Surfaces for sports areas - Procedure for accelerated ageing by exposure to hot air
EN 13864:2004 Surfaces for sports areas - Determination of tensile strength of synthetic yarns
EN 13865:2003 Surfaces for sports areas - Determination of angled ball behaviour - Tennis
EN 14808:2005 Surfaces for sports areas - Determination of shock absorption
EN 14809:2005 Surfaces for sports areas - Determination of vertical deformation
EN 14809:2005/AC:2007 Surfaces for sports areas - Determination of vertical deformation
EN 14810:2006 Surfaces for sports areas - Determination of spike resistance
EN 14836:2005 Synthetic surfaces for outdoor sports areas - Exposure to artificial weathering
EN 14836:2005/AC:2007 Synthetic surfaces for outdoor sports areas - Exposure to artificial weathering
EN 14837:2006 Surfaces for sports areas - Determination of slip resistance
EN 14877:2013 Synthetic surfaces for outdoor sports areas - Specification
EN 14904:2006 Surfaces for sports areas - Indoor surfaces for multi-sports use - Specification
EN 14952:2005 Surfaces for sports areas - Determination of water absorption of unbound minerals
EN 14953:2005 Surfaces for sport areas - Determination of thickness of unbound mineral surfaces for outdoor sports areas
EN 14954:2005 Surfaces for sports areas - Determination of hardness of natural turf and unbound mineral surfaces for outdoor sports areas
EN 14955:2005 Surfaces for sports areas - Determination of composition and particle shape of unbound mineral surfaces for outdoor sports areas
EN 14956:2005 Surfaces for sports areas - Determination of water content of unbound mineral surfaces for outdoor sports areas
CEN/TS 15122:2005 Surfaces for sports areas - Determination of resistance of synthetic sports surfaces to repeated impact
EN 15301-1:2007 Surfaces for sports areas - Part 1: Determination of rotational resistance
EN 15301-2:2007 Surfaces for sports areas - Part 2: Determination of shear strength by dynamic top layer testing of unbound mineral surfaces in the laboratory
EN 15306:2014 Surfaces for outdoor sports areas - Exposure of synthetic turf to simulated wear
EN 15330-1:2013 Surfaces for sports areas - Synthetic turf and needle-punched surfaces primarily designed for outdoor use - Part 1: Specification for synthetic turf surfaces for football, hockey, rugby union training, tennis and multi-sports use
EN 15330-2:2008 Surfaces for sports areas - Synthetic turf and needle-punched surfaces primarily designed for outdoor use - Part 2: Specification for needle-punched surfaces
CEN/TS 16384:2012 Synthetic sport systems - Leaching test
CEN/TS 16717:2015 Surface for sports areas - Method of test for the determination of shock absorption, vertical deformation and energy restitution using the advanced artificial athlete
missing:
or
