ok* CEN sectors 81-100 of 370 will be uploaded tonight with updates* if updates are avaivable* tonight* so...here's the missing list of 1-100 CEN sectors* so if anyone have any of the following standards...let's complete the collection:
CEN/TR 17052:2017 Guidelines on implementing EN 1090-1:2009+A1:2011* Execution of steel structures and aluminium structures - Part 1: Requirements for conformity assessment of structural components
EN 10635:2017 Hot rolled steel channels* I and H sections - Dimensions and masses
EN 13480-5:2012/A2:2017 Metallic industrial piping - Part 5: Inspection and testing
EN 207:2017 Personal eye-protection equipment - Filters and eye-protectors against laser radiation (laser eye-protectors)
EN ISO 20421-2:2017 Cryogenic vessels - Large transportable vacuum-insulated vessels - Part 2: Operational requirements (ISO 20421-2:2017)
CEN/TS 15399:2007 Gas Supply Systems - Guidelines for Management systems for Gas Distribution Network
CR 13642:1999 Flanges and their joints - Design rules for gasketed circular flange connections - Background information
EN 515:2017 Aluminium and aluminium alloys - Wrought products - Temper designations
EN 12020-2:2016/AC:2017 Aluminium and aluminium alloys - Extruded precision profiles in alloys EN AW-6060 and EN AW-6063 - Part 2: Tolerances on dimensions and form
EN 16914:2017 Aluminium and aluminium alloys - Hot-rolled armour plates in weldable aluminium alloy - Technical delivery conditions
CEN/TS 14940-1:2009 Copper and copper alloys - Determination of chromium content - Part 1: Titrimetric method
CEN/TS 15703-1:2009 Copper and copper alloys - Determination of manganese content - Part 1: Spectrophotometric method
CEN/CLC Guide 9:2001 Guidelines for the inclusion of safety aspects in standards
EN 1559-5:2017 Founding - Technical conditions of delivery - Part 5: Additional requirements for magnesium alloy castings
EN 12421:2017 Magnesium and magnesium alloys - Unalloyed magnesium
EN 13481-2:2012+A1:2017 Railway applications - Track - Performance requirements for fastening systems - Part 2: Fastening systems for concrete sleepers
EN 13481-5:2012+A1:2017 Railway applications - Track - Performance requirements for fastening systems - Part 5: Fastening systems for slab track with rail on the surface or rail embedded in a channel
EN 14730-1:2017 Railway applications - Track - Aluminothermic welding of rails - Part 1: Approval of welding processes
EN 15153-1:2013+A1:2016 Railway applications - External visible and audible warning devices for trains - Part 1: Head* marker and tail lamps
EN 15273-1:2013+A1:2016 Railway applications - Gauges - Part 1: General - Common rules for infrastructure and rolling stock
EN 15273-2:2013+A1:2016 Railway applications - Gauges - Part 2: Rolling stock gauge
EN 15273-3:2013+A1:2016 Railway applications - Gauges - Part 3: Structure gauges
EN 16275:2016 Railway applications - Track - Restoration and repair of manganese crossings
CEN/TR 16335:2014 Railway application - Design for PRM Use - Equipment and Components onboard Rolling Stock - Toilets
CEN/TR 17039:2017 Railway applications - Technical Report about the revision of EN 14363
CR 10316:2001 Optical emission analysis of low alloy steels (routine method) - Guidelines for the preparation of standard routine method for optical emission spectrometry
CR 10321:2003 Chemical analysis of ferrous materials - Recommendations for the drafting of standard methods of analysis employing flame atomic absorption spectrometry for the chemical analysis of iron and steel
CR 10322:2003 Chemical analysis of ferrous materials - Operational guidelines for the application of flame atomic absorption spectrometry in standard methods for the chemical analysis of iron and steel
EN ISO 8503-5:2017 Preparation of steel substrates before application of paints and related products - Surface roughness characteristics of blast-cleaned steel substrates - Part 5: Replica tape method for the determination of the surface profile (ISO 8503-5:2003)
EN 13523-1:2017 Coil coated metals - Test methods - Part 1: Film thickness
EN 13523-10:2017 Coil coated metals - Test methods - Part 10: Resistance to fluorescent UV radiation and water condensation
EN 13523-12:2017 Coil coated metals - Test methods - Part 12: Resistance to scratching
EN 13523-22:2017 Coil coated metals - Test methods - Part 22: Colour difference - Visual comparison
EN 13523-29:2017 Coil coated metals - Test methods - Part 29: Resistance to environmental soiling (Dirt pick-up and striping)
CEN/TR 15760:2010 Heat meters - Checklist documenting the relationship between the Directive 2004/22/EC (MID) and EN 1434:2007
CR 12695:1997 Metal chimneys - Corrosion resistance requirements and test methods
EN 16475-2:2017 Chimneys - Accessories - Part 2: Chimney fans - Requirements and test methods
EN 16497-2:2017 Chimneys - Concrete System Chimneys - Part 2: Balanced flue applications
EN ISO 6789-1:2017 Assembly tools for screws and nuts - Hand torque tools - Part 1: Requirements and methods for design conformance testing and quality conformance testing: minimum requirements for declaration of conformance (ISO 6789-1:2017)
EN ISO 6789-2:2017 Assembly tools for screws and nuts - Hand torque tools - Part 2: Requirements for calibration and determination of measurement uncertainly (ISO 6789-2:2017)
EN 16282-2:2016 Equipment for commercial kitchens - Components for ventilation in commercial kitchens - Part 2: Kitchen ventilation hoods; design and safety requirements
EN 16753:2017 Ventilation for Buildings - Performance testing of components for residential buildings - Multifunctional balanced ventilation units for single family dwellings* including heat pumps
EN ISO 177:2017 Plastics - Determination of migration of plasticizers (ISO 177:2016)
CEN/TS 15354:2006 Plastics - Extruded and/or calendered* non-reinforced film and sheeting made of plasticized poly(vinyl chloride) (PVC-P) - Guidance for characterisation and designation
EN ISO 11114-1:2012/A1:2017 Gas cylinders - Compatibility of cylinder and valve materials with gas contents - Part 1: Metallic materials - Amendment 1 (ISO 11114-1:2012/Amd 1:2017)
EN ISO 12209:2013/A1:2016 Gas cylinders - Outlet connections for gas cylinder valves for compressed breathable air - Amendment 1: Outlet connection up to a maximum cylinder working pressure of 500 bar (ISO 12209:2013/Amd 1:2016)
EN ISO 16440:2016 Petroleum and natural gas industries - Pipeline transportation systems - Design* construction and maintenance of steel cased pipelines (ISO 16440:2016)
EN ISO 16530-1:2017 Petroleum and natural gas industries - Well integrity - Part 1: Life cycle governance (ISO 16530-1:2017)
EN 490:2011+A1:2017 Concrete roofing tiles and fittings for roof covering and wall cladding - Product specifications
CR 833:1992 General requirements for a discontinuously laid roofing covering
EN 54-17:2005/AC:2007 Fire detection and fire alarm systems - Part 17: Short-circuit isolators
CEN/TR 14568:2003 EN 54 - Fire detection and fire alarm systems - Interpretation of specific clauses of EN 54-2:1997
This list will be updated after reuploading of 100 by 100 sectors* of 370 shared so far now. After reuploading of all 370 sectors* if you see again reuploaded some CEN' sector it means that's something changed; no more reupping for "nothing". Hope in future this collection will reach 400 sectors. So...if anyone willing to complete* at least a part of this collection...
