full list:
EN 1934:1998 Thermal performance of buildings - Determination of thermal resistance by hot box method using heat flow meter - Masonry
EN 1946-1:1999 Thermal performance of building products and components - Specific criteria for the assessment of laboratories measuring heat transfer properties - Part 1: Common criteria
EN 1946-2:1999 Thermal performance of building products and components - Specific criteria for the assessment of laboratories measuring heat transfer properties - Part 2: Measurements by guarded hot plate method
EN 1946-3:1999 Thermal performance of building products and components - Specific criteria for the assessment of laboratories measuring heat transfer properties - Part 3: Measurements by heat flow meter method
EN 1946-4:2000 Thermal performance of building products and components - Specific criteria for the assessment of laboratories measuring heat transfer properties - Part 4: Measurements by hot box methods
EN 1946-5:2000 Thermal performance of building products and components - Specific criteria for the assessment of laboratories measuring heat transfer properties - Part 5: Measurements by pipe test methods
EN ISO 6781-3:2015 Performance of buildings - Detection of heat, air and moisture irregularities in buildings by infrared methods - Part 3: Qualifications of equipment operators, data analysts and report writers (ISO 6781-3:2015)
EN ISO 6946:2007 Building components and building elements - Thermal resistance and thermal transmittance - Calculation method (ISO 6946:2007)
EN ISO 7345:1995 Thermal insulation - Physical quantities and definitions (ISO 7345:1987)
EN ISO 8497:1996 Thermal insulation - Determination of steady-state thermal transmission properties of thermal insulation for circular pipes (ISO 8497:1994)
EN ISO 8990:1996 Thermal insulation - Determination of steady-state thermal transmission properties - Calibrated and guarded hot box (ISO 8990:1994)
EN ISO 9251:1995 Thermal insulation - Heat transfer conditions and properties of materials - Vocabulary (ISO 9251:1987)
EN ISO 9288:1996 Thermal insulation - Heat transfer by radiation - Physical quantities and definitions (ISO 9288:1989)
EN ISO 9346:2007 Hygrothermal performance of buildings and building materials - Physical quantities for mass transfer - Vocabulary (ISO 9346:2007)
EN ISO 9972:2015 Thermal performance of buildings - Determination of air permeability of buildings - Fan pressurization method (ISO 9972:2015)
EN ISO 10077-1:2006 Thermal performance of windows, doors and shutters - Calculation of thermal transmittance - Part 1: General (ISO 10077-1:2006)
EN ISO 10077-1:2006/AC:2009 Thermal performance of windows, doors and shutters - Calculation of thermal transmittance - Part 1: General (ISO 10077-1:2006)
EN ISO 10077-2:2012 Thermal performance of windows, doors and shutters - Calculation of thermal transmittance - Part 2: Numerical method for frames (ISO 10077-2:2012)
EN ISO 10077-2:2012/AC:2012 Thermal performance of windows, doors and shutters - Calculation of thermal transmittance - Part 2: Numerical method for frames (ISO 10077-2:2012)
EN ISO 10211:2007 Thermal bridges in building construction - Heat flows and surface temperatures - Detailed calculations (ISO 10211:2007)
EN ISO 10456:2007 Building materials and products - Hygrothermal properties -Tabulated design values and procedures for determining declared and design thermal values (ISO 10456:2007)
EN ISO 10456:2007/AC:2009 Building materials and products - Hygrothermal properties -Tabulated design values and procedures for determining declared and design thermal values (ISO 10456:2007)
EN 12114:2000 Thermal performance of buildings - Air permeability of building components and building elements - Laboratory test method
EN ISO 12241:2008 Thermal insulation for building equipment and industrial installations - Calculation rules (ISO 12241:2008)
EN 12412-2:2003 Thermal performance of windows, doors and shutters - Determination of thermal transmittance by hot box method - Part 2: Frames
EN 12412-4:2003 Thermal performance of windows, doors and shutters - Determination of thermal transmittance by hot box method - Part 4: Roller shutter boxes
EN ISO 12567-1:2010 Thermal performance of windows and doors - Determination of thermal transmittance by the hot-box method - Part 1: Complete windows and doors (ISO 12567-1:2010)
EN ISO 12567-1:2010/AC:2010 Thermal performance of windows and doors - Determination of thermal transmittance by the hot-box method - Part 1: Complete windows and doors (ISO 12567-1:2010)
EN ISO 12567-2:2005 Thermal performance of windows and doors - Determination of thermal transmittance by hot box method - Part 2: Roof windows and other projecting windows (ISO 12567-2:2005)
EN ISO 12569:2012 Thermal performance of buildings and materials - Determination of specific airflow rate in buildings - Tracer gas dilution method (ISO 12569:2012)
EN ISO 12570:2000 Hygrothermal performance of building materials and products - Determination of moisture content by drying at elevated temperature (ISO 12570:2000)
EN ISO 12570:2000/A1:2013 Hygrothermal performance of building materials and products - Determination of moisture content by drying at elevated temperature (ISO 12570:2000)
EN ISO 12571:2013 Hygrothermal performance of building materials and products - Determination of hygroscopic sorption properties (ISO 12571:2013)
EN ISO 12572:2001 Hygrothermal performance of building materials and products - Determination of water vapour transmission properties (ISO 12572:2001)
EN ISO 12631:2012 Thermal performance of curtain walling - Calculation of thermal transmittance (ISO 12631:2012)
EN 12664:2001 Thermal performance of building materials and products - Determination of thermal resistance by means of guarded hot plate and heat flow meter methods - Dry and moist products of medium and low thermal resistance
EN 12667:2001 Thermal performance of building materials and products - Determination of thermal resistance by means of guarded hot plate and heat flow meter methods - Products of high and medium thermal resistance
EN 12865:2001 Hygrothermal performance of building components and building elements - Determination of the resistance of external wall systems to driving rain under pulsating air pressure
EN 12939:2000 Thermal performance of building materials and products - Determination of thermal resistance by means of guarded hot plate and heat flow meter methods - Thick products of high and medium thermal resistance
EN 13009:2000 Hygrothermal performance of building materials and products - Determination of hygric expansion coefficient
EN 13187:1998 Thermal performance of buildings - Qualitative detection of thermal irregularities in building envelopes - Infrared method (ISO 6781:1983 modified)
EN 13363-1:2003+A1:2007 Solar protection devices combined with glazing - Calculation of solar and light transmittance - Part 1: Simplified method
EN 13363-1:2003+A1:2007/AC:2008 Solar protection devices combined with glazing - Calculation of solar and light transmittance - Part 1: Simplified method
EN 13363-2:2005 Solar protection devices combined with glazing - Calculation of total solar energy transmittance and light transmittance - Part 2: Detailed calculation method
EN 13363-2:2005/AC:2006 Solar protection devices combined with glazing - Calculation of total solar energy transmittance and light transmittance - Part 2: Detailed calculation method
EN ISO 13370:2007 Thermal performance of buildings - Heat transfer via the ground - Calculation methods (ISO 13370:2007)
EN ISO 13786:2007 Thermal performance of building components - Dynamic thermal characteristics - Calculation methods (ISO 13786:2007)
EN ISO 13787:2003 Thermal insulation products for building equipment and industrial installations - Determination of declared thermal conductivity (ISO 13787:2003)
EN ISO 13788:2012 Hygrothermal performance of building components and building elements - Internal surface temperature to avoid critical surface humidity and interstitial condensation - Calculation methods (ISO 13788:2012)
EN ISO 13789:2007 Thermal performance of buildings - Transmission and ventilation heat transfer coefficients - Calculation method (ISO 13789:2007)
EN ISO 13790:2008 Energy performance of buildings - Calculation of energy use for space heating and cooling (ISO 13790:2008)
EN ISO 13791:2012 Thermal performance of buildings - Calculation of internal temperatures of a room in summer without mechanical cooling - General criteria and validation procedures (ISO 13791:2012)
EN ISO 13792:2012 Thermal performance of buildings - Calculation of internal temperatures of a room in summer without mechanical cooling - Simplified methods (ISO 13792:2012)
EN ISO 13793:2001 Thermal performance of buildings - Thermal design of foundations to avoid frost heave (ISO 13793:2001)
CEN/TR 14613:2003 Thermal performance of building materials and components - Principles for the determination of thermal properties of moist material and components
EN ISO 14683:2007 Thermal bridges in building construction - Linear thermal transmittance - Simplified methods and default values (ISO 14683:2007)
EN 15026:2007 Hygrothermal performance of building components and building elements - Assessment of moisture transfer by numerical simulation
CEN/TR 15131:2006 Thermal performance of building materials - The use of interpolating equations in relation to thermal measurement on thick specimens - Guarded hot plate and heat flow meter apparatus
EN ISO 15148:2002 Hygrothermal performance of building materials and products - Determination of water absorption coefficient by partial immersion (ISO 15148:2002)
EN ISO 15148:2002/A1:2016 Hygrothermal performance of building materials and products - Determination of water absorption coefficient by partial immersion - Amendment 1 (ISO 15148:2002/Amd 1:2016)
EN 15217:2007 Energy performance of buildings - Methods for expressing energy performance and for energy certification of buildings
EN 15255:2007 Energy performance of buildings - Sensible room cooling load calculation - General criteria and validation procedures
EN 15265:2007 Energy performance of buildings - Calculation of energy needs for space heating and cooling using dynamic methods - General criteria and validation procedures
CEN/TS 15548-1:2014 Thermal insulation products for building equipment and industrial installations - Determination of thermal resistance by means of the guarded hot plate method - Part 1: Measurements at elevated temperatures from 100 °C to 850 °C
CEN/TR 15601:2012 Hygrothermal performance of buildings - Resistance to wind - driven rain of roof coverings with discontinuously laid small elements - Test methods
EN ISO 15758:2014 Hygrothermal performance of building equipment and industrial installations - Calculation of water vapour diffusion - Cold pipe insulation systems (ISO 15758:2014)
EN ISO 15927-1:2003 Hygrothermal performance of buildings - Calculation and presentation of climatic data - Part 1: Monthly means of single meteorological elements (ISO 15927-1:2003)
EN ISO 15927-2:2009 Hygrothermal performance of buildings - Calculation and presentation of climatic data - Part 2: Hourly data for design cooling load (ISO 15927-2:2009)
EN ISO 15927-3:2009 Hygrothermal performance of buildings - Calculation and presentation of climatic data - Part 3: Calculation of a driving rain index for vertical surfaces from hourly wind and rain data (ISO 15927-3:2009)
EN ISO 15927-4:2005 Hygrothermal performance of buildings - Calculation and presentation of climatic data - Part 4: Hourly data for assessing the annual energy use for heating and cooling (ISO 15927-4:2005)
EN ISO 15927-5:2004 Hygrothermal performance of buildings - Calculation and presentation of climatic data - Part 5: Data for design heat load for space heating (ISO 15927-5:2004)
EN ISO 15927-5:2004/A1:2011 Hygrothermal performance of buildings - Calculation and presentation of climatic data - Part 5: Data for design heat load for space heating (ISO 15927-5:2004)
EN ISO 15927-6:2007 Hygrothermal performance of buildings - Calculation and presentation of climatic data - Part 6: Accumulated temperature differences (degree-days) (ISO 15927-6:2007)
EN 16012:2012+A1:2015 Thermal insulation for buildings - Reflective insulation products - Determination of the declared thermal performance
EN ISO 23993:2010 Thermal insulation products for building equipment and industrial installations - Determination of design thermal conductivity (ISO 23993:2008, Corrected version 2009-10-01)
we missing here:
EN ISO 15148:2002/A1:2016 Hygrothermal performance of building materials and products - Determination of water absorption coefficient by partial immersion - Amendment 1 (ISO 15148:2002/Amd 1:2016) - missing A1:2016
EN 16012:2012+A1:2015 Thermal insulation for buildings - Reflective insulation products - Determination of the declared thermal performance - missing A1:2015
linkz:
or
