full list:
CR 245:1986 Thermal insulation - Classification of building materials according to their thermal insulation properties
EN 822:2013 Thermal insulating products for building applications - Determination of length and width
EN 823:2013 Thermal insulating products for building applications - Determination of thickness
EN 824:2013 Thermal insulating products for building applications - Determination of squareness
EN 825:2013 Thermal insulating products for building applications - Determination of flatness
EN 826:2013 Thermal insulating products for building applications - Determination of compression behaviour
EN 1602:2013 Thermal insulating products for building applications - Determination of the apparent density
EN 1603:2013 Thermal insulating products for building applications - Determination of dimensional stability under constant normal laboratory conditions (23 °C/ 50 % relative humidity)
EN 1604:2013 Thermal insulating products for building applications - Determination of dimensional stability under specified temperature and humidity conditions
EN 1605:2013 Thermal insulating products for building applications - Determination of deformation under specified compressive load and temperature conditions
EN 1606:2013 Thermal insulating products for building applications - Determination of compressive creep
EN 1607:2013 Thermal insulating products for building applications - Determination of tensile strength perpendicular to faces
EN 1608:2013 Thermal insulating products for building applications - Determination of tensile strength parallel to faces
EN 1609:2013 Thermal insulating products for building applications - Determination of short term water absorption by partial immersion
EN ISO 9229:2007 Thermal insulation - Vocabulary (ISO 9229:2007)
EN 12085:2013 Thermal insulating products for building applications - Determination of linear dimensions of test specimens
EN 12086:2013 Thermal insulating products for building applications - Determination of water vapour transmission properties
EN 12087:2013 Thermal insulating products for building applications - Determination of long term water absorption by immersion
EN 12088:2013 Thermal insulating products for building applications - Determination of long term water absorption by diffusion
EN 12089:2013 Thermal insulating products for building applications - Determination of bending behaviour
EN 12090:2013 Thermal insulating products for building applications - Determination of shear behaviour
EN 12091:2013 Thermal insulating products for building applications - Determination of freeze-thaw resistance
EN 12429:1998 Thermal insulating products for building applications - Conditioning to moisture equilibrium under specified temperature and humidity conditions
EN 12430:2013 Thermal insulating products for building applications - Determination of behaviour under point load
EN 12431:2013 Thermal insulating products for building applications - Determination of thickness for floating floor insulating products
EN 13162:2012+A1:2015 Thermal insulation products for buildings - Factory made mineral wool (MW) products - Specification
EN 13163:2012+A1:2015 Thermal insulation products for buildings - Factory made expanded polystyrene (EPS) products - Specification
EN 13164:2012+A1:2015 Thermal insulation products for buildings - Factory made extruded polystyrene foam (XPS) products - Specification
EN 13165:2012+A1:2015 Thermal insulation products for buildings - Factory made rigid polyurethane foam (PU) products - Specification
EN 13166:2012+A1:2015 Thermal insulation products for buildings - Factory made phenolic foam (PF) products - Specification
EN 13167:2012+A1:2015 Thermal insulation products for buildings - Factory made cellular glass (CG) products - Specification
EN 13168:2012+A1:2015 Thermal insulation products for buildings - Factory made wood wool (WW) products - Specification
EN 13169:2012+A1:2015 Thermal insulation products for buildings - Factory made expanded perlite board (EPB) products - Specification
EN 13170:2012+A1:2015 Thermal insulation products for buildings - Factory made products of expanded cork (ICB) - Specification
EN 13171:2012+A1:2015 Thermal insulation products for buildings - Factory made wood fibre (WF) products - Specification
EN 13172:2012 Thermal insulation products - Evaluation of conformity
EN 13467:2001 Thermal insulating products for building equipment and industrial installations - Determination of dimensions, squareness and linearity of preformed pipe insulation
EN 13468:2001 Thermal insulating products for building equipment and industrial installations - Determination of trace quantities of water soluble chloride, fluoride, silicate, sodium ions and pH
EN 13469:2012 Thermal insulating products for building equipment and industrial installations - Determination of water vapour transmission properties of preformed pipe insulation
EN 13470:2001 Thermal insulating products for building equipment and industrial installations - Determination of the apparent density of preformed pipe insulation
EN 13471:2001 Thermal insulating products for building equipment and industrial installations - Determination of the coefficient of thermal expansion
EN 13472:2012 Thermal insulating products for building equipment and industrial installations - Determination of short term water absorption by partial immersion of preformed pipe insulation
EN 13494:2002 Thermal insulation products for building applications - Determination of the tensile bond strength of the adhesive and of the base coat to the thermal insulation material
EN 13495:2002 Thermal insulation products for building applications - Determination of the pull-off resistance of external thermal insulation composite systems (ETICS)(foam block test)
EN 13496:2013 Thermal insulation products for building applications - Determination of the mechanical properties of glass fibre meshes as reinforcement for External Thermal Insulation Composite Systems with renders (ETICS)
EN 13497:2002 Thermal insulation products for building applications - Determination of the resistance to impact of external thermal insulation composite systems (ETICS)
EN 13498:2002 Thermal insulation products for building applications - Determination of the resistance to penetration of external thermal insulation composite systems (ETICS)
EN 13499:2003 Thermal insulation products for buildings - External thermal insulation composite systems (ETICS) based on expanded polystyrene - Specification
EN 13500:2003 Thermal insulation products for buildings - External thermal insulation composite systems (ETICS) based on mineral wool - Specification
EN 13793:2003 Thermal insulating products for building applications - Determination of behaviour under cyclic loading
EN 13820:2003 Thermal insulating materials for building applications - Determination of organic content
EN 14063-1:2004 Thermal insulation products for buildings - In-situ formed expanded clay lightweight aggregate products - Part 1: Specification for the loose-fill products before installation
EN 14063-1:2004/AC:2006 Thermal insulation products for buildings - In-situ formed expanded clay lightweight aggregate products - Part 1: Specification for the loose-fill products before installation
EN 14063-2:2013 Thermal insulation products for buildings - In-situ formed expanded clay lightweight aggregate products - Part 2: Specification for the installed products
EN 14064-1:2010 Thermal insulation products for buildings - In-situ formed loose-fill mineral wool (MW) products - Part 1: Specification for the loose-fill products before installation
EN 14064-2:2010 Thermal insulation products for buildings - In-situ formed loose-fill mineral wool (MW) products - Part 2: Specification for the installed products
EN 14303:2015 Thermal insulation products for building equipment and industrial installations - Factory made mineral wool (MW) products - Specification
EN 14304:2015 Thermal insulation products for building equipment and industrial installations - Factory made flexible elastomeric foam (FEF) products - Specification
EN 14305:2015 Thermal insulation products for building equipment and industrial installations - Factory made cellular glass (CG) products - Specification
EN 14306:2015 Thermal insulation products for building equipment and industrial installations - Factory made calcium silicate (CS) products - Specification
EN 14307:2015 Thermal insulation products for building equipment and industrial installations - Factory made extruded polystyrene foam (XPS) products - Specification
EN 14308:2015 Thermal insulation products for building equipment and industrial installations - Factory made rigid polyurethane foam (PUR) and polyisocyanurate foam (PIR) products - Specification
EN 14309:2015 Thermal insulation products for building equipment and industrial installations - Factory made products of expanded polystyrene (EPS) - Specification
EN 14313:2015 Thermal insulation products for building equipment and industrial installations - Factory made polyethylene foam (PEF) products - Specification
EN 14314:2015 Thermal insulation products for building equipment and industrial installations - Factory made phenolic foam (PF) products - Specification
EN 14315-1:2013 Thermal insulating products for buildings - In-situ formed sprayed rigid polyurethane (PUR) and polyisocyanurate (PIR) foam products - Part 1: Specification for the rigid foam spray system before installation
EN 14315-2:2013 Thermal insulating products for buildings - In-situ formed sprayed rigid polyurethane (PUR) and polyisocyanurate (PIR) foam products - Part 2: Specification for the installed insulation products
EN 14316-1:2004 Thermal insulation products for buildings - In-situ thermal insulation formed from expanded perlite (EP) products - Part 1: Specification for bonded and loose-fill products before installation
EN 14316-2:2007 Thermal insulating products for buildings - In-situ thermal insulation formed from expanded perlite (EP) products - Part 2: Specification for the installed products
EN 14317-1:2004 Thermal insulation products for buildings - In-situ thermal insulation formed from exfoliated vermiculite (EV) products - Part 1: Specification for bonded and loose-fill products before installation
EN 14317-2:2007 Thermal insulation products for buildings - In-situ thermal insulation formed from exfoliated vermiculite (EV) products - Part 2: Specification for the installed products
EN 14318-1:2013 Thermal insulating products for buildings - In-situ formed dispensed rigid polyurethane (PUR) and polyisocyanurate (PIR) foam products - Part 1: Specification for the rigid foam dispensed system before installation
EN 14318-2:2013 Thermal insulating products for buildings - In-situ formed dispensed rigid polyurethane (PUR) and polyisocyanurate (PIR) foam products - Part 2: Specification for the installed insulation products
EN 14319-1:2013 Thermal insulating products for building equipment and industrial installations - In-situ formed dispensed rigid polyurethane (PUR) and polyisocyanurate foam (PIR) products - Part 1: Specification for the rigid foam dispensed system before installation
EN 14319-2:2013 Thermal insulating products for building equipment and industrial installations - In-situ formed dispensed rigid polyurethane (PUR) and polyisocyanurate foam (PIR) products - Part 2: Specification for the installed insulation products
EN 14320-1:2013 Thermal insulating products for building equipment and industrial installations - In-situ formed sprayed rigid polyurethane (PUR) and polyisocyanurate foam (PIR) products - Part 1: Specification for the rigid foam spray system before installation
EN 14320-2:2013 Thermal insulating products for building equipment and industrial installations - In-situ formed sprayed rigid polyurethane (PUR) and polyisocyanurate foam (PIR) products - Part 2: Specification for the installed insulation products
EN 14706:2012 Thermal insulating products for building equipment and industrial installations - Determination of maximum service temperature
EN 14707:2012 Thermal insulating products for building equipment and industrial installations - Determination of maximum service temperature for preformed pipe insulation
EN 14933:2007 Thermal insulation and light weight fill products for civil engineering applications - Factory made products of expanded polystyrene (EPS) - Specification
EN 14934:2007 Thermal insulation and light weight fill products for civil engineering applications - Factory made products of extruded polystyrene foam (XPS) - Specification
EN 15101-1:2013 Thermal insulation products for buildings - In-situ formed loose fill cellulose (LFCI) products - Part 1: Specification for the products before installation
EN 15101-2:2013 Thermal insulation products for buildings - In-situ formed loose fill cellulose (LFCI) products - Part 2: Specification for the installed products
EN 15501:2015 Thermal insulation products for building equipment and industrial installations - Factory made expanded perlite (EP) and exfoliated vermiculite (EV) products - Specification
EN 15599-1:2010 Thermal insulation products for building equipment and industrial installations - In-situ thermal insulation formed from expanded perlite (EP) products - Part 1: Specification for bonded and loose-fill products before installation
EN 15599-2:2010 Thermal insulation products for building equipment and industrial installations - In-situ thermal insulation formed from expanded perlite (EP) products - Part 2: Specification for the installed products
EN 15715:2009 Thermal insulation products - Instructions for mounting and fixing for reaction to fire testing - Factory made products
EN 15732:2012 Light weight fill and thermal insulation products for civil engineering applications (CEA) - Expanded clay lightweight aggregate products (LWA)
CEN/TR 15985:2010 Thermal insulating products - Factory made products of expanded polystyrene (EPS) - Voluntary certification of the raw material
EN 15600-1:2010 Thermal insulation products for building equipment and industrial installations - In-situ thermal insulation formed from exfoliated vermiculite (EV) products - Part 1: Specification for bonded and loose-fill products before installation
EN 15600-2:2010 Thermal insulation products for building equipment and industrial installations - In-situ thermal insulation formed from exfoliated vermiculite (EV) products - Part 2: Specification for the installed products
EN 16025-1:2013 Thermal and/or sound insulating products in building construction - Bound EPS ballastings - Part 1: Requirements for factory premixed EPS dry plaster
EN 16025-2:2013 Thermal and/ or sound insulating products in building construction - Bound EPS ballastings - Part 2: Processing of the factory premixed EPS dry plaster
EN 16069:2012+A1:2015 Thermal insulation products for buildings - Factory made products of polyethylene foam (PEF) - Specification
EN 16724:2015 Thermal insulation products for building applications - Instructions for mounting and fixing for determination of the reaction to fire testing of external thermal Insulation composite systems (ETICS)
missing standards:
missing valid editions:
missing AMD's from 2015:
linkz:
or
