Results 1 to 11 of 11
Thread: CEN Standards Collection 44/370: CEN TC 240 - Thermal Spraying...
    we missing 5 here:
    EN 582:1993 Thermal spraying - Determination of tensile adhesive strength
    EN 657:2005 Thermal spraying - Terminology, classification
    EN 1274:2004 Thermal spraying - Powders - Composition, technical supply conditions
    EN 1395-1:2007 Thermal spraying - Acceptance inspection of thermal spraying equipment - Part 1: General requirements
    EN 1395-2:2007 Thermal spraying - Acceptance inspection of thermal spraying equipment - Part 2: Flame spraying including HVOF
    EN 1395-3:2007 Thermal spraying - Acceptance inspection of thermal spraying equipment - Part 3: Arc spraying
    EN 1395-4:2007 Thermal spraying - Acceptance inspection of thermal spraying equipment - Part 4: Plasma spraying
    EN 1395-5:2007 Thermal spraying - Acceptance inspection of thermal spraying equipment - Part 5: Plasma spraying in chambers
    EN 1395-6:2007 Thermal spraying - Acceptance inspection of thermal spraying equipment - Part 6: Manipulator systems
    EN 1395-7:2007 Thermal spraying - Acceptance inspection of thermal spraying equipment - Part 7: Powder feed systems
    EN ISO 2063:2005 Thermal spraying - Metallic and other inorganic coatings - Zinc, aluminium and their alloys (ISO 2063:2005)
    EN ISO 12670:2015 Thermal spraying - Components with thermally sprayed coatings - Technical supply conditions (ISO 12670:2011)
    EN ISO 12671:2014 Thermal spraying - Thermally sprayed coatings - Symbolic representation on drawings (ISO 12671:2012)
    EN ISO 12679:2015 Thermal spraying - Recommendations for thermal spraying (ISO 12679:2011)
    EN ISO 12690:2010 Metallic and other inorganic coatings - Thermal spray coordination - Tasks and responsibilities (ISO 12690:2010)
    EN ISO 13123:2011 Metallic and other inorganic coatings - Test method of cyclic heating for thermal-barrier coatings under temperature gradient (ISO 13123:2011)
    EN 13507:2010 Thermal spraying - Pre-treatment of surfaces of metallic parts and components for thermal spraying
    EN 14616:2004 Thermal spraying - Recommendations for thermal spraying
    EN ISO 14918:1998 Thermal spraying - Approval testing of thermal sprayers (ISO 14918:1998)
    EN ISO 14919:2015 Thermal spraying - Wires, rods and cords for flame and arc spraying - Classification - Technical supply conditions (ISO 14919:2015)
    EN ISO 14920:2015 Thermal spraying - Spraying and fusing of self-fluxing alloys (ISO 14920:2015)
    EN ISO 14921:2010 Thermal spraying - Procedures for the application of thermally sprayed coatings for engineering components (ISO 14921:2010)
    EN ISO 14922-1:1999 Thermal spraying - Quality requirements of thermally sprayed structures - Part 1: Guidance for selection and use (ISO 14922-1:1999)
    EN ISO 14922-2:1999 Thermal spraying - Quality requirements of thermally sprayed structures - Part 2: Comprehensive quality requirements (ISO 14922-2:1999)
    EN ISO 14922-3:1999 Thermal spraying - Quality requirements of thermally sprayed structures - Part 3: Standard quality requirements (ISO 14922-3:1999)
    EN ISO 14922-4:1999 Thermal spraying - Quality requirements of thermally sprayed structures - Part 4: Elementary quality requirements (ISO 14922-4:1999)
    EN ISO 14923:2003 Thermal spraying - Characterization and testing of thermally sprayed coatings (ISO 14923:2003)
    EN ISO 14924:2005 Thermal spraying - Post-treatment and finishing of thermally sprayed coatings (ISO 14924:2005)
    EN 15311:2007 Thermal spraying - Components with thermally sprayed coatings - Technical supply conditions
    EN 15339-2:2007 Thermal spraying - Safety requirements for thermal spraying equipment - Part 2: Gas control units
    EN 15340:2007 Thermal spraying - Determination of shear load resistance of thermally sprayed coatings
    EN 15520:2007 Thermal spraying - Recommendations for constructional design of components with thermally sprayed coatings
    CEN/TR 15339-1:2014 Thermal spraying - Safety requirements for thermal spraying equipment - Part 1: General requirements - missing
    CEN/TR 15339-3:2014 Thermal spraying - Safety requirements for thermal spraying equipment - Part 3: Torches for thermal spraying and their connection and supply units - missing
    CEN/TR 15339-4:2014 Thermal spraying - Safety requirements for thermal spraying equipment - Part 4: Gas and liquid fuel supply - missing
    CEN/TR 15339-5:2014 Thermal spraying - Safety requirements for thermal spraying equipment - Part 5: Powder and wire feed units - missing
    CEN/TR 15339-6:2014 Thermal spraying - Safety requirements for thermal spraying equipment - Part 6: Spray booth, Handling system, Dust collection, Exhaust system, Filter - missing
    EN 15648:2009 Thermal spraying - Component related procedure qualification
    EN ISO 17834:2003 Thermal spraying - Coatings for protection against corrosion and oxidation at elevated temperatures (ISO 17834:2003)
    EN ISO 17836:2004 Thermal spraying - Determination of the deposition efficiency for thermal spraying (ISO 17836:2004)
    or
    Re: CEN standars collection 44/300: CEN TC 240 - Thermal Spraying...
    update:
    EN 1395-1:2007 Thermal spraying - Acceptance inspection of thermal spraying equipment - Part 1: General requirements - better quality
    EN 1395-2:2007 Thermal spraying - Acceptance inspection of thermal spraying equipment - Part 2: Flame spraying including HVOF - EN version
    EN 1395-3:2007 Thermal spraying - Acceptance inspection of thermal spraying equipment - Part 3: Arc spraying - better quality
    EN 1395-4:2007 Thermal spraying - Acceptance inspection of thermal spraying equipment - Part 4: Plasma spraying - better quality
    EN 1395-5:2007 Thermal spraying - Acceptance inspection of thermal spraying equipment - Part 5: Plasma spraying in chambers - better quality
    EN 1395-6:2007 Thermal spraying - Acceptance inspection of thermal spraying equipment - Part 6: Manipulator systems - better quality
    EN 1395-7:2007 Thermal spraying - Acceptance inspection of thermal spraying equipment - Part 7: Powder feed systems - better quality
    EN ISO 12671:2014 Thermal spraying - Thermally sprayed coatings - Symbolic representation on drawings (ISO 12671:2012) - better quality
    EN ISO 12679:2015 Thermal spraying - Recommendations for thermal spraying (ISO 12679:2011) - better quality
    EN ISO 12690:2010 Metallic and other inorganic coatings - Thermal spray coordination - Tasks and responsibilities (ISO 12690:2010) - better quality
    EN ISO 13123:2011 Metallic and other inorganic coatings - Test method of cyclic heating for thermal-barrier coatings under temperature gradient (ISO 13123:2011) - better quality
    EN ISO 14919:2015 Thermal spraying - Wires, rods and cords for flame and arc spraying - Classification - Technical supply conditions (ISO 14919:2015) - better quality
    EN ISO 14920:2015 Thermal spraying - Spraying and fusing of self-fluxing alloys (ISO 14920:2015) - better quality
    EN ISO 14921:2010 Thermal spraying - Procedures for the application of thermally sprayed coatings for engineering components (ISO 14921:2010) - better quality
    CEN/TR 15339-1:2014 Thermal spraying - Safety requirements for thermal spraying equipment - Part 1: General requirements - added valid edition
    EN 15339-2:2007 Thermal spraying - Safety requirements for thermal spraying equipment - Part 2: Gas control units - EN version
    CEN/TR 15339-3:2014 Thermal spraying - Safety requirements for thermal spraying equipment - Part 3: Torches for thermal spraying and their connection and supply units - added valid edition
    CEN/TR 15339-4:2014 Thermal spraying - Safety requirements for thermal spraying equipment - Part 4: Gas and liquid fuel supply - added valid edition
    CEN/TR 15339-5:2014 Thermal spraying - Safety requirements for thermal spraying equipment - Part 5: Powder and wire feed units - added valid edition
    EN 15648:2009 Thermal spraying - Component related procedure qualification - better quality
    1 standard now missing:
    linkz:
    Re: CEN Standards Collection 44/300: CEN TC 240 - Thermal Spraying...
    update:
    EN ISO 14922-1:1999 Thermal spraying - Quality requirements of thermally sprayed structures - Part 1: Guidance for selection and use (ISO 14922-1:1999) - EN version
    EN ISO 14922-2:1999 Thermal spraying - Quality requirements of thermally sprayed structures - Part 2: Comprehensive quality requirements (ISO 14922-2:1999) - EN version
    EN ISO 14924:2005 Thermal spraying - Post-treatment and finishing of thermally sprayed coatings (ISO 14924:2005) - EN version
    EN 15311:2007 Thermal spraying - Components with thermally sprayed coatings - Technical supply conditions - EN version
    EN 15520:2007 Thermal spraying - Recommendations for constructional design of components with thermally sprayed coatings - EN version
    EN ISO 17836:2004 Thermal spraying - Determination of the deposition efficiency for thermal spraying (ISO 17836:2004) - EN version
    added missing standard:
    sector complete
    or
    Re: CEN Standards Collection 44/340: CEN TC 240 - Thermal Spraying...
    no changes, everything here, fresh links:
    still complete
    or
    Re: CEN Standards Collection 44/350: CEN TC 240 - Thermal Spraying...
    update:
    EN ISO 12670:2015 Thermal spraying - Components with thermally sprayed coatings - Technical supply conditions (ISO 12670:2011) - better quality
    CEN/TR 15339-6:2014 Thermal spraying - Safety requirements for thermal spraying equipment - Part 6: Spray booth* Handling system* Dust collection* Exhaust system* Filter - better quality
    EN 16813:2016 Thermal spraying - Measurement of the electrical conductivity of thermal sprayed non-iron metal coatings by means of eddy current method - added new standard
    links:
    or
    Re: CEN Standards Collection 44/370: CEN TC 240 - Thermal Spraying...
    nothing changed* new link:
    update:
    better quality or EN versions:
    EN 657:2005 Thermal spraying - Terminology* classification
    EN ISO 2063:2005 Thermal spraying - Metallic and other inorganic coatings - Zinc* aluminium and their alloys (ISO 2063:2005)
    two new are missing:
    EN ISO 14916:2017 Thermal spraying - Determination of tensile adhesive strength (ISO 14916:2017)
    EN ISO 14917:2017 Thermal spraying - Terminology* classification (ISO 14917:2017)
    complete
    new one:
    EN ISO 14232-1:2017 Thermal spraying - Powders - Part 1: Characterization and technical supply conditions (ISO 14232-1:2017)
    still complete
  14. #11
    full list 27.10.2017:
    EN 1274:2004 Thermal spraying - Powders - Composition* technical supply conditions
    EN ISO 2063-1:2017 Thermal spraying - Zinc* aluminium and their alloys - Part 1: Design considerations and quality requirements for corrosion protection systems (ISO 2063-1:2017)
    EN ISO 2063-2:2017 Thermal spraying - Zinc* aluminium and their alloys - Part 2: Execution of corrosion protection systems (ISO 2063-2:2017)
    EN ISO 14919:2015 Thermal spraying - Wires* rods and cords for flame and arc spraying - Classification - Technical supply conditions (ISO 14919:2015)
    complete
  1. Replies: 9
    Last Post: 06-08-2017, 04:43 PM
  2. Replies: 6
    Last Post: 05-31-2017, 01:14 AM
  3. 100 x 100 Books # 7.1 - Thermal Spraying
    Last Post: 03-06-2017, 02:39 AM
  4. 100 x 100 Books # 7 - Thermal Spraying
    Last Post: 02-10-2017, 05:14 AM
  5. Thermal Spraying on Existing equipment
    By ramjiprasanna in forum Petrochemical
    Last Post: 10-07-2013, 08:47 AM
