Page 1 of 2 1 2 LastLast
Results 1 to 12 of 18
Thread: CEN Standards Collection 110/370: CEN TC 185 - Fasteners
    full list:
    EN ISO 225:2010 Fasteners - Bolts, screws, studs and nuts - Symbols and descriptions of dimensions (ISO 225:2010)
    EN ISO 887:2000 Plain washers for metric bolts, screws and nuts for general purposes - General plan (ISO 887:2000)
    EN ISO 887:2000/AC:2006 Plain washers for metric bolts, screws and nuts for general purposes - General plan (ISO 887:2000)
    EN ISO 898-1:2013 Mechanical properties of fasteners made of carbon steel and alloy steel - Part 1: Bolts, screws and studs with specified property classes - Coarse thread and fine pitch thread (ISO 898-1:2013)
    EN ISO 898-1:2013/AC:2013 Mechanical properties of fasteners made of carbon steel and alloy steel - Part 1: Bolts, screws and studs with specified property classes - Coarse thread and fine pitch thread - Technical Corrigendum 1 (ISO 898-1:2013/Cor 1:2013)
    EN ISO 898-2:2012 Mechanical properties of fasteners made of carbon steel and alloy steel - Part 2: Nuts with specified property classes - Coarse thread and fine pitch thread (ISO 898-2:2012)
    EN ISO 898-5:2012 Mechanical properties of fasteners made of carbon steel and alloy steel - Part 5: Set screws and similar threaded fasteners with specified hardness classes - Coarse thread and fine pitch thread (ISO 898-5:2012)
    EN ISO 1207:2011 Slotted cheese head screws - Product grade A (ISO 1207:2011)
    EN ISO 1234:1997 Split pins (ISO 1234:1997)
    EN ISO 1478:1999 Tapping screws thread (ISO 1478:1999)
    EN ISO 1479:2011 Hexagon head tapping screws (ISO 1479:2011)
    EN ISO 1481:2011 Slotted pan head tapping screws (ISO 1481:2011)
    EN ISO 1482:2011 Slotted countersunk (flat) head tapping screws (ISO 1482:2011)
    EN ISO 1483:2011 Slotted raised countersunk (oval) head tapping screws (ISO 1483:2011)
    EN 1661:1997 Hexagon nuts with flange (ISO/DIS 4161:1996, modified)
    EN 1661:1997/AC:1998 Hexagon nuts with flange (ISO/DIS 4161:1996, modified)
    EN 1662:1997 Hexagon bolts with flange - Small series (ISO/DIS 15071:1996, modified)
    EN 1662:1997/AC:2007 Hexagon bolts with flange - Small series (ISO/DIS 15071:1996, modified)
    EN 1663:1997 Prevailing torque type hexagon nuts with flange (with non-metallic insert) (ISO 7043:1997, modified)
    EN 1664:1997 Prevailing torque type all-metal hexagon nuts with flange (ISO 7044:1997, modified)
    EN 1665:1997 Hexagon bolts with flange - Heavy series
    EN 1665:1997/AC:2007 Hexagon bolts with flange - Heavy series
    EN 1666:1997 Prevailing torque type hexagon nuts with flange (with non-metallic insert) with metric fine pitch thread (ISO 12125:1997, modified)
    EN 1667:1997 Prevailing torque type all-metal hexagon nuts with flange metric fine pitch thread (ISO 12126:1997, modified)
    EN ISO 1891-2:2014 Fasteners - Terminology - Part 2: Vocabulary and definitions for coatings (ISO 1891-2:2014)
    EN ISO 2009:2011 Slotted countersunk flat head screws - Product grade A (ISO 2009:2011)
    EN ISO 2010:2011 Slotted raised countersunk head screws - Product grade A (ISO 2010:2011)
    EN ISO 2320:2015 Fasteners - Prevailing torque steel nuts - Functional properties (ISO 2320:2015)
    EN ISO 2338:1997 Parallel pins, of unhardened steel and austenitic stainless steel (ISO 2338:1997)
    EN ISO 2342:2003 Slotted headless screws with shank (ISO 2342:2003)
    EN ISO 2702:2011 Heat-treated steel tapping screws - Mechanical properties (ISO 2702:2011)
    EN ISO 3269:2000 Fasteners - Acceptance inspection (ISO 3269:2000)
    EN ISO 3506-1:2009 Mechanical properties of corrosion-resistant stainless steel fasteners - Part 1: Bolts, screws and studs (ISO 3506-1:2009)
    EN ISO 3506-2:2009 Mechanical properties of corrosion-resistant stainless steel fasteners - Part 2: Nuts (ISO 3506-2:2009)
    EN ISO 3506-3:2009 Mechanical properties of corrosion-resistant stainless steel fasteners - Part 3: Set screws and similar fasteners not under tensile stress (ISO 3506-3:2009)
    EN ISO 3506-4:2009 Mechanical properties of corrosion-resistant stainless steel fasteners - Part 4: Tapping screws (ISO 3506-4:2009)
    EN ISO 4014:2011 Hexagon head bolts - Product grades A and B (ISO 4014:2011)
    EN ISO 4016:2011 Hexagon head bolts - Product grade C (ISO 4016:2011)
    EN ISO 4017:2014 Fasteners - Hexagon head screws - Product grades A and B (ISO 4017:2014)
    EN ISO 4018:2011 Hexagon head screws - Product grade C (ISO 4018:2011)
    EN ISO 4026:2003 Hexagon socket set screws with flat point (ISO 4026:2003)
    EN ISO 4027:2003 Hexagon socket set screws with cone point (ISO 4027:2003)
    EN ISO 4028:2003 Hexagon socket set screws with dog point (ISO 4028:2003)
    EN ISO 4029:2003 Hexagon socket set screws with cup point (ISO 4029:2003)
    EN ISO 4032:2012 Hexagon regular nuts (style 1) - Product grades A and B (ISO 4032:2012)
    EN ISO 4033:2012 Hexagon high nuts (style 2) - Product grades A and B (ISO 4033:2012)
    EN ISO 4034:2012 Hexagon regular nuts (style 1) - Product grade C (ISO 4034:2012)
    EN ISO 4034:2012/AC:2013 Hexagon regular nuts (style 1) - Product grade C - Technical Corrigendum 1 (ISO 4034:2012/Cor 1:2013)
    EN ISO 4035:2012 Hexagon thin nuts chamfered (style 0) - Product grades A and B (ISO 4035:2012)
    EN ISO 4036:2012 Hexagon thin nuts unchamfered (style 0) - Product grade B (ISO 4036:2012)
    EN ISO 4042:1999 Fasteners - Electroplated coatings (ISO 4042:1999)
    EN ISO 4753:2011 Fasteners - Ends of parts with external ISO metric thread (ISO 4753:2011)
    EN ISO 4757:1994 Cross recesses for screws (ISO 4757:1983)
    EN ISO 4759-1:2000 Tolerances for fasteners - Part 1: Bolts, screws, studs and nuts - Product grades A, B and C (ISO 4759-1:2000)
    EN ISO 4759-3:2000 Tolerances for fasteners - Part 3: Plain washers for bolts, screws and nuts - Products grades A and C (ISO 4759-3:2000)
    EN ISO 4762:2004 Hexagon socket head cap screws (ISO 4762:2004)
    EN ISO 4766:2011 Slotted set screws with flat point (ISO 4766:2011)
    EN ISO 6157-2:2004 Fasteners - Surface discontinuities - Part 2: Nuts (ISO 6157-2:1995)
    EN ISO 7040:2012 Prevailing torque type hexagon regular nuts (with non-metallic insert) - Property classes 5, 8 and 10 (ISO 7040:2012)
    EN ISO 7042:2012 Prevailing torque type all-metal hexagon high nuts - Property classes 5, 8, 10 and 12 (ISO 7042:2012)
    EN ISO 7045:2011 Pan head screws with type H or type Z cross recess - Product grade A (ISO 7045:2011)
    EN ISO 7046-1:2011 Countersunk flat head screws (common head style) with type H or type Z cross recess - Product grade A - Part 1: Steel screws of property class 4.8 (ISO 7046-1:2011)
    EN ISO 7046-2:2011 Countersunk flat head screws (common head style) with type H or type Z cross recess - Product grade A - Part 2: Steel screws of property class 8.8, stainless steel screws and non-ferrous metal screws (ISO 7046-2:2011)
    EN ISO 7047:2011 Raised countersunk head screws (common head style) with type H or type Z cross recess - Product grade A (ISO 7047:2011)
    EN ISO 7048:2011 Cross-recessed cheese head screws (ISO 7048:2011)
    EN ISO 7049:2011 Cross-recessed pan head tapping screws (ISO/FDIS 7049:2011)
    EN ISO 7050:2011 Cross-recessed countersunk (flat) head tapping screws (ISO 7050:2011)
    EN ISO 7051:2011 Cross-recessed raised countersunk (oval) head tapping screws (ISO 7051:2011)
    EN ISO 7053:2011 Hexagon washer head tapping screws (ISO 7053:2011)
    EN ISO 7089:2000 Plain washers - Normal series - Product grade A (ISO 7089:2000)
    EN ISO 7090:2000 Plain washers, chamfered - Normal series - Product grade A (ISO 7090:2000)
    EN ISO 7091:2000 Plain washers - Normal series - Product grade C (ISO 7091:2000)
    EN ISO 7092:2000 Plain washers - Small series - Product grade A (ISO 7092:2000)
    EN ISO 7093-1:2000 Plain washers - Large series - Part 1: Product grade A (ISO 7093-1:2000)
    EN ISO 7093-2:2000 Plain washers - Large series - Part 2: Product grade C (ISO 7093-2:2000)
    EN ISO 7094:2000 Plain washers - Extra large series - Product grade C (ISO 7094:2000)
    EN ISO 7094:2000/AC:2002 Plain washers - Extra large series - Product grade C (ISO 7094:2000/Cor.1:2000)
    EN ISO 7380-1:2011 Button head screws - Part 1: Hexagon socket button head screws (ISO 7380-1:2011)
    EN ISO 7380-2:2011 Button head screws - Part 2: Hexagon socket button head screws with collar (ISO 7380-2:2011)
    EN ISO 7719:2012 Prevailing torque type all-metal hexagon regular nuts - Property classes 5, 8 and 10 (ISO 7719:2012)
    EN ISO 7719:2012/AC:2013 Prevailing torque type all-metal hexagon regular nuts - Property classes 5, 8 and 10 - Technical Corrigendum 1 (ISO 7719:2012/Cor 1:2013)
    EN ISO 7721-2:1994 Countersunk flat head screws - Part 2: Penetration depth of cross recesses (ISO 7721-2:1990)
    EN ISO 8673:2012 Hexagon regular nuts (style 1) with metric fine pitch thread - Product grades A and B (ISO 8673:2012)
    EN ISO 8674:2012 Hexagon high nuts (style 2) with metric fine pitch thread - Product grades A and B (ISO 8674:2012)
    EN ISO 8675:2012 Hexagon thin nuts chamfered (style 0) with metric fine pitch thread - Product grades A and B (ISO 8675:2012)
    EN ISO 8676:2011 Hexagon head screws with metric fine pitch thread - Product grades A and B (ISO 8676:2011)
    EN ISO 8733:1997 Parallel pins with internal thread, of unhardened steel or austenitic stainless steel (ISO 8733:1997)
    EN ISO 8734:1997 Parallel pins, or hardened steel or martensitic stainless steel (Dowel pins) (ISO 8734:1997)
    EN ISO 8735:1997 Parallel pins with internal thread, of hardened steel or martensitic stainless steel (ISO 8735:1997)
    EN ISO 8739:1997 Grooved pins - Full-length parallel grooved, with pilot (ISO 8739:1997)
    EN ISO 8740:1997 Grooved pins - Full-length parallel grooved, with chamfer (ISO 8740:1997)
    EN ISO 8741:1997 Grooved pins - Half-length reverse taper grooved (ISO 8741:1997)
    EN ISO 8742:1997 Grooved pins - One-third-length centre grooved (ISO 8742:1997)
    EN ISO 8743:1997 Grooved pins - Half-length centre grooved (ISO 8743:1997)
    EN ISO 8744:1997 Grooved pins - Full-length taper grooved (ISO 8744:1997)
    EN ISO 8745:1997 Grooved pins - Half-length taper grooved (ISO 8745:1997)
    EN ISO 8746:1997 Grooved pins with round head (ISO 8746:1997)
    EN ISO 8747:1997 Grooved pins with countersunk head (ISO 8747:1997)
    EN ISO 8748:2007 Spring-type straight pins - Coiled, heavy duty (ISO 8748:2007)
    EN ISO 8750:2007 Spring-type straight pins - Coiled, standard duty (ISO 8750:2007)
    EN ISO 8751:2007 Spring-type straight pins - Coiled, light duty (ISO 8751:2007)
    EN ISO 8752:2009 Spring-type straight pins - Slotted, heavy duty (ISO 8752:2009)
    EN ISO 8765:2011 Hexagon head bolts with metric fine pitch thread - Product grades A and B (ISO 8765:2011)
    EN ISO 10484:2004 Widening test on nuts (ISO 10484:1997)
    EN ISO 10510:2011 Tapping screw and washer assemblies with plain washers (ISO 10510:2011)
    EN ISO 10511:2012 Prevailing torque type hexagon thin nuts (with non-metallic insert) (ISO 10511:2012)
    EN ISO 10512:2012 Prevailing torque type hexagon regular nuts (with non-metallic insert) with metric fine pitch thread - Property classes 6, 8 and 10 (ISO 10512:2012)
    EN ISO 10513:2012 Prevailing torque type all-metal hexagon high nuts with metric fine pitch thread - Property classes 8, 10 and 12 (ISO 10513:2012)
    EN ISO 10642:2004 Hexagon socket countersunk head screws (ISO 10642:2004)
    EN ISO 10642:2004/A1:2012 Hexagon socket countersunk head screws (ISO 10642:2004)
    EN ISO 10644:2009 Screw and washer assemblies made of steel with plain washers - Washer hardness classes 200 HV and 300 HV (ISO 10644:2009)
    EN ISO 10664:2014 Hexalobular internal driving feature for bolts and screws (ISO 10664:2014)
    EN ISO 10666:1999 Drilling screws with tapping screw thread - Mechanical and functional properties (ISO 10666:1999)
    EN ISO 10669:1999 Plain washers for tapping screw and washer assemblies - Normal and large series - Product grade A (ISO 10669:1999)
    EN ISO 10673:2009 Plain washers for screw and washer assemblies - Small, normal and large series - Product grade A (ISO 10673:2009)
    EN ISO 10683:2014 Fasteners - Non-electrolytically applied zinc flake coatings (ISO 10683:2014)
    EN ISO 10684:2004 Fasteners - Hot dip galvanized coatings (ISO 10684:2004)
    EN ISO 10684:2004/AC:2009 Fasteners - Hot dip galvanized coatings (ISO 10684:2004)
    EN ISO 12474:2010 Hexagon socket head cap screws with metric fine pitch thread (ISO 12474:2010)
    EN ISO 13337:2009 Spring-type straight pins - Slotted, light duty (ISO 13337:2009)
    EN 14218:2003 Hexagon nuts with flange - Fine pitch thread (ISO 10663:1999, modified)
    EN 14219:2003 Hexagon bolts with flange with metric fine pitch thread - Small series (ISO 15072:1999, modified)
    EN 14219:2003/AC:2007 Hexagon bolts with flange with metric fine pitch thread - Small series (ISO 15072:1999, modified)
    EN 14399-1:2015 High-strength structural bolting assemblies for preloading - Part 1: General requirements
    EN 14399-2:2015 High-strength structural bolting assemblies for preloading - Part 2: Suitability for preloading
    EN 14399-3:2015 High-strength structural bolting assemblies for preloading - Part 3: System HR - Hexagon bolt and nut assemblies
    EN 14399-4:2015 High-strength structural bolting assemblies for preloading - Part 4: System HV - Hexagon bolt and nut assemblies
    EN 14399-5:2015 High-strength structural bolting assemblies for preloading - Part 5: Plain washers
    EN 14399-6:2015 High-strength structural bolting assemblies for preloading - Part 6: Plain chamfered washers
    EN 14399-7:2007 High-strength structural bolting assemblies for preloading - Part 7: System HR - Countersunk head bolt and nut assemblies
    EN 14399-8:2007 High-strength structural bolting assemblies for preloading - Part 8: System HV - Hexagon fit bolt and nut assemblies
    EN 14399-9:2009 High-strength structural bolting assemblies for preloading - Part 9: System HR or HV - Direct tension indicators for bolt and nut assemblies
    EN 14399-10:2009 High-strength structural bolting assemblies for preloading - Part 10: System HRC - Bolt and nut assemblies with calibrated preload
    EN ISO 14579:2011 Hexalobular socket head cap screws (ISO 14579:2011)
    EN ISO 14580:2011 Hexalobular socket cheese head screws (ISO 14580:2011)
    EN ISO 14581:2013 Fasteners - Hexalobular socket countersunk flat head screws (ISO 14581:2013)
    EN ISO 14582:2013 Fasteners - Hexalobular socket countersunk head screws, high head (ISO 14582:2013)
    EN ISO 14583:2011 Hexalobular socket pan head screws (ISO 14583:2011)
    EN ISO 14584:2011 Hexalobular socket raised countersunk head screws (ISO 14584:2011)
    EN ISO 14585:2011 Hexalobular socket pan head tapping screws (ISO 14585:2011)
    EN ISO 14586:2011 Hexalobular socket countersunk head tapping screws (ISO 14586:2011)
    EN ISO 14587:2011 Hexalobular socket raised countersunk (oval) head tapping screws (ISO 14587:2011)
    EN ISO 14588:2000 Blind rivets - Terminology and definitions (ISO 14588:2000)
    EN ISO 14589:2000 Blind rivets - Mechanical testing (ISO 14589:2000)
    EN 14831:2005 Fasteners - Tightening performance - Torque/Angle simplified test method
    EN 15048-1:2007 Non-preloaded structural bolting assemblies - Part 1: General requirements
    EN 15048-2:2007 Non-preloaded structural bolting assemblies - Part 2: Suitability test
    EN ISO 15065:2005 Countersinks for countersunk head screws with head configuration in accordance with ISO 7721 (ISO 15065:2005)
    EN ISO 15330:1999 Fasteners - Preloading test for the detection of hydrogen embrittlement - Parallel bearing surface method (ISO 15330:1999)
    EN ISO 15480:1999 Hexagon washer head drilling screws with tapping screw thread (ISO 15480:1999)
    EN ISO 15481:1999 Cross recessed pan head drilling screws with tapping screw thread (ISO 15481:1999)
    EN ISO 15482:1999 Cross recessed countersunk head drilling screws with tapping screw thread (ISO 15482:1999)
    EN ISO 15483:1999 Cross recessed raised countersunk head drilling screws with tapping screw thread (ISO 15483:1999)
    EN ISO 15973:2000 Closed end blind rivets with break pull mandrel and protruding head - AIA/St (ISO 15973:2000)
    EN ISO 15974:2000 Closed end blind rivets with break pull mandrel and countersunk head - AIA/St (ISO 15974:2000)
    EN ISO 15975:2002 Closed end blind rivets with break pull mandrel and protrudiing head - AI/AIA (ISO 15975:2002)
    EN ISO 15976:2002 Closed end blind rivets with break pull mandrel and protrudiing head - St/St (ISO 15976:2002)
    EN ISO 15977:2002 Open end blind rivets with break pull mandrel and protruding head - AIA/St (ISO 15977:2002)
    EN ISO 15978:2002 Open end blind rivets with break pull mandrel and countersunk head - AIA/St (ISO 15978:2002)
    EN ISO 15979:2002 Open end blind rivets with break pull mandrel and protruding head - St/St (ISO 15979:2002)
    EN ISO 15980:2002 Open end blind rivets with break pull mandrel and countersunk head - St/St (ISO 15980:2002)
    EN ISO 15981:2002 Open end blind rivets with break pull mandrel and protruding head - AIA/AIA (ISO 15981:2002)
    EN ISO 15982:2002 Open end blind rivets with break pull mandrel and countersunk head - AIA/AIA (ISO 15982:2002)
    EN ISO 15983:2002 Open end blind rivets with break pull mandrel and protruding head - A2/A2 (ISO 15983:2002)
    EN ISO 15984:2002 Open end blind rivets with break pull mandrel and countersunk head - A2/A2 (ISO 15984:2002)
    EN ISO 16047:2005 Fasteners - Torque/clamp force testing (ISO 16047:2005)
    EN ISO 16047:2005/A1:2012 Fasteners - Torque/clamp force testing (ISO 16047:2005)
    EN ISO 16048:2003 Passivation of corrosion-resistant stainless-steel fasteners (ISO 16048:2003)
    EN ISO 16426:2002 Fasteners - Quality assurance system (ISO 16426:2002)
    EN ISO 16582:2002 Open end blind rivets with break pull mandrel and protruding head - Cu/St or Cu/Br or Cu/SSt (ISO 16582:2002)
    EN ISO 16583:2002 Open end blind rivets with break pull mandrel and countersunk head - Cu/St or Cu/Br or Cu/SSt (ISO 16583:2002)
    EN ISO 16584:2002 Open end blind rivets with break pull mandrel and protruding head - NiCu/St or NiCu/SSt (ISO 16584:2002)
    EN ISO 16585:2002 Closed end blind rivets Closed end blind rivets with pull mandrel and protruding head - A2/SSt (ISO 16585:2002)with pull mandrel and protruding head - A2/SSt (ISO 16585:2002)
    EN 20273:1991 Fasteners - Clearance holes for bolts and screws (ISO 273:1979)
    EN 20898-7:1995 Mechanical properties of fasteners - Part 7: Torsional test and minimum torques for bolts and screws with nominal diameters 1 mm to 10 mm (ISO 898-7:1992)
    EN ISO 21670:2014 Fasteners - Hexagon weld nuts with flange (ISO 21670:2014)
    EN 22339:1992 Taper pins, unhardened (ISO 2339:1986)
    EN 22340:1992 Clevis pins without head (ISO 2340:1986)
    EN 22341:1992 Clevis pins with head (ISO 2341:1986)
    EN ISO 23429:2004 Gauging of hexagon sockets (ISO 23429:2004)
    EN 24015:1991 Hexagon head bolts - Product grade B - Reduced shank (Shank diameter = pitch diameter) (ISO 4015:1979)
    EN 26157-1:1991 Fasteners - Surface discontinuities - Part 1: Bolts, screws and studs for general requirements (ISO 6157-1:1988)
    EN 26157-3:1991 Fasteners - Surface discontinuities - Part 3: Bolts, screws and studs for special requirements (ISO 6157-3:1988)
    EN 27434:1992 Slotted set screws with cone point (ISO 7434:1983)
    EN 27435:1992 Slotted set screws with long dog point (ISO 7435:1983)
    EN 27436:1992 Slotted set screws with cup point (ISO 7436:1983)
    EN 27721:1991 Countersunk head screws - Head configuration and gauging (ISO 7721:1983)
    EN 28736:1992 Taper pins with internal thread, unhardened (ISO 8736:1986)
    EN 28737:1992 Taper pins with external thread, unhardened (ISO 8737:1986)
    EN 28738:1992 Plain washers for clevis pins - Product grade A (ISO 8738:1986)
    EN 28749:1992 Pins and grooved pins - Shear test (ISO 8749:1986)
    EN 28839:1991 Mechanical properties of fasteners - Bolts, screws, studs and nuts made of non-ferrous metals (ISO 8839:1986)
    missing:
    EN ISO 898-1:2013/AC:2013 Mechanical properties of fasteners made of carbon steel and alloy steel - Part 1: Bolts, screws and studs with specified property classes - Coarse thread and fine pitch thread - Technical Corrigendum 1 (ISO 898-1:2013/Cor 1:2013) - missing AC
    EN 1661:1997/AC:1998 Hexagon nuts with flange (ISO/DIS 4161:1996, modified) - missing AC
    EN ISO 2320:2015 Fasteners - Prevailing torque steel nuts - Functional properties (ISO 2320:2015) - missing valid edition
    EN ISO 4034:2012/AC:2013 Hexagon regular nuts (style 1) - Product grade C - Technical Corrigendum 1 (ISO 4034:2012/Cor 1:2013) - missing AC
    EN ISO 7094:2000/AC:2002 Plain washers - Extra large series - Product grade C (ISO 7094:2000/Cor.1:2000) - missing AC
    EN ISO 7719:2012/AC:2013 Prevailing torque type all-metal hexagon regular nuts - Property classes 5, 8 and 10 - Technical Corrigendum 1 (ISO 7719:2012/Cor 1:2013) - missing AC
    EN ISO 7721-2:1994 Countersunk flat head screws - Part 2: Penetration depth of cross recesses (ISO 7721-2:1990) - missing
    EN ISO 10664:2014 Hexalobular internal driving feature for bolts and screws (ISO 10664:2014) - missing
    Re: CEN standards collection 110/100: CEN TC 185 - Fasteners
    many thanks
    Thank you for this post but a lot of standards are DIN format and therefore in German. Could you share them in English and especially the ISO 898-1 ?
    I also prefer english version, but...this is what I have in this CEN sector....
    Re: CEN Standards Collection 110/300: CEN TC 185 - Fasteners
    small update:
    EN ISO 7094:2000/AC:2002 Plain washers - Extra large series - Product grade C (ISO 7094:2000/Cor.1:2000) - added AC 2002
    EN ISO 7719:2012 Prevailing torque type all-metal hexagon regular nuts - Property classes 5, 8 and 10 (ISO 7719:2012) - EN version
    EN ISO 10664:2014 Hexalobular internal driving feature for bolts and screws (ISO 10664:2014) - added missing standard
    or
    Aug 2015
    Dubai, UAE
    Blog Entries
    4
    Quote Originally Posted by agoede View Post
    here u go ISO 898-1
    Attached Files Attached Files
    update:
    EN ISO 2320:2015 Fasteners - Prevailing torque steel nuts - Functional properties (ISO 2320:2015) - added missing standard
    missing list:
    or
    Re: CEN Standards Collection 110/340: CEN TC 185 - Fasteners
    Update:
    EN version
    EN version
    EN version
    EN version
    EN version
    EN version
    EN version
    EN version
    EN version
    EN version
    EN version
    EN version
    EN version
    EN version
    EN version
    EN version
    EN version
    EN version
    EN version
    EN version
    EN version
    EN version
    EN version
    EN version
    EN version
    EN version
    EN version
    EN version
    EN version
    EN version
    EN version
    EN version
    EN version
    EN version
    EN version
    EN version
    EN version
    EN version
    update:
    EN 1661:1997/AC:1998 Hexagon nuts with flange (ISO/DIS 4161:1996, modified) - added missing AC
    EN 1662:1997/AC:2007 Hexagon bolts with flange - Small series (ISO/DIS 15071:1996, modified) - EN version
    missing list:
    EN ISO 4759-3:2016 Tolerances for fasteners - Part 3: Washers for bolts, screws and nuts - Product grades A, C and F (ISO 4759-3:2016)
    EN 15048-1:2016 Non-preloaded structural bolting assemblies - Part 1: General requirements
    EN 15048-2:2016 Non-preloaded structural bolting assemblies - Part 2: Suitability test
    links:
    or
    Re: CEN Standards Collection 110/350: CEN TC 185 - Fasteners
    update:
    EN ISO 4759-3:2016 Tolerances for fasteners - Part 3: Washers for bolts, screws and nuts - Product grades A, C and F (ISO 4759-3:2016) - added missing standard
    EN 15048-1:2016 Non-preloaded structural bolting assemblies - Part 1: General requirements - added missing standard
    EN 15048-2:2016 Non-preloaded structural bolting assemblies - Part 2: Suitability test - added missing standard
    missing list is:
    links:
    or
  14. #11
    Hello friends,
    Is anybody can share the standard EN 10269:2013 "Steels and nickel alloys for fasteners with specified elevated and/or low temperature properties" ?
    I have only the rev 1999...
    Thanks for your help.
  16. Re: CEN Standards Collection 110/350: CEN TC 185 - Fasteners
    Thanks a lot
  1. Replies: 2
    Last Post: 07-29-2017, 03:33 AM
  2. Replies: 0
    Last Post: 12-31-2016, 04:12 AM
  3. CEN Standards Collection
    By Sajid Ali Khan in forum Mechanical Engineering
    Last Post: 06-12-2016, 12:55 AM
  4. CEN Standards Collection
    Last Post: 03-25-2016, 10:08 PM
  5. EN 10269 - Steels and nickel alloys for fasteners
    By Tetraedar in forum Mechanical Engineering
    Last Post: 11-20-2013, 09:15 AM
