Friction
ISO 22:1991 Belt drives -- Flat transmission belts and corresponding pulleys -- Dimensions and tolerances
ISO 155:1998 Belt drives -- Pulleys -- Limiting values for adjustment of centres
ISO 254:2011 Belt drives -- Pulleys -- Quality* finish and balance
ISO 255:1990 Belt drives -- Pulleys for V-belts (system based on datum width) -- Geometrical inspection of grooves
ISO 1081:2013 Belt drives -- V-belts and V-ribbed belts* and corresponding grooved pulleys -- Vocabulary
ISO 1604:1989 Belt drives -- Endless wide V-belts for industrial speed-changers and groove profiles for corresponding pulleys
ISO 1813:2014 Belt drives -- V-ribbed belts* joined V-belts and V-belts including wide section belts and hexagonal belts -- Electrical conductivity of antistatic belts: Characteristics and methods of test
ISO 2790:2004 Belt drives -- V-belts for the automotive industry and corresponding pulleys -- Dimensions
ISO 3410:1989 Agricultural machinery -- Endless variable-speed V-belts and groove sections of corresponding pulleys
ISO 4183:1995 Belt drives -- Classical and narrow V-belts -- Grooved pulleys (system based on datum width)
ISO 4184:1992 Belt drives -- Classical and narrow V-belts -- Lengths in datum system
ISO 5287:2003 Belt drives -- Narrow V-belts for the automotive industry -- Fatigue test
ISO 5289:1992 Agricultural machinery -- Endless hexagonal belts and groove sections of corresponding pulleys
ISO 5290:2001 Belt drives -- Grooved pulleys for joined narrow V-belts -- Groove sections 9N/J* 15N/J and 25N/J (effective system)
ISO 5291:2011 Belt drives -- Grooved pulleys for joined classical V-belts -- Groove sections AJ* BJ* CJ and DJ (effective system)
ISO 5292:1995 Belt drives -- V-belts and V-ribbed belts -- Calculation of power ratings
ISO 8370-1:1993 Belt drives -- Dynamic test to determine pitch zone location -- Part 1: V-belts
ISO 8370-2:1993 Belt drives -- Dynamic test to determine pitch zone location -- Part 2: V-ribbed belts
ISO 8419:2003 Belt drives -- Narrow V-belts -- Sections 9N/J* 15N/J and 25N/J (lengths in the effective system)
ISO 9608:1994 V-belts -- Uniformity of belts -- Test method for determination of centre distance variation
ISO 9980:2012 Belt drives -- Grooved pulleys for V-belts (system based on effective width) -- Geometrical inspection of grooves
ISO 9981:1998 Belt drives -- Pulleys and V-ribbed belts for the automotive industry -- PK profile: Dimensions
ISO 9982:1998 Belt drives -- Pulleys and V-ribbed belts for industrial applications -- PH* PJ* PK* PL and PM profiles: dimensions
ISO 11749:2014 Belt drive -- V-ribbed belts for the automotive industry -- Fatigue test
ISO 24035:2014 Belt drives -- V-belts and the corresponding pulleys for agricultural machineries -- Dimensions
Conveyor belts
ISO 251:2012 Conveyor belts with textile carcass -- Widths and lengths
ISO 252:2007 Conveyor belts -- Adhesion between constitutive elements -- Test methods
ISO 282:1992 Conveyor belts -- Sampling
ISO 283:2015 Textile conveyor belts -- Full thickness tensile strength* elongation at break and elongation at the reference load -- Test method
ISO 284:2012 Conveyor belts -- Electrical conductivity -- Specification and test method
ISO 340:2013 Conveyor belts -- Laboratory scale flammability characteristics -- Requirements and test method
ISO 433:1991 Conveyor belts -- Marking
ISO 433:1991/Amd 1:2006 Conveyor belts -- Marking
ISO 505:1999 Conveyor belts -- Method for the determination of the tear propagation resistance of textile conveyor belts
ISO 583:2007 Conveyor belts with a textile carcass -- Total belt thickness and thickness of constitutive elements -- Test methods
ISO 703:2007 Conveyor belts -- Transverse flexibility (troughability) -- Test method
ISO 1120:2012 Conveyor belts -- Determination of strength of mechanical fastenings -- Static test method
ISO 3684:1990 Conveyor belts -- Determination of minimum pulley diameters
ISO 3684:1990/Amd 1:2006 Conveyor belts -- Determination of minimum pulley diameters
ISO 4195:2012 Conveyor belts with heat-resistant rubber covers -- Heat resistance of covers -- Requirements and test methods
ISO 5284:1986 Conveyor belts -- List of equivalent terms
ISO 5284:1986/Cor 1:2005 Conveyor belts -- List of equivalent terms
ISO 5285:2012 Conveyor belts -- Guidelines for storage and handling
ISO 5293:2004 Conveyor belts -- Determination of minimum transition distance on three idler rollers
ISO 5293:2004/Cor 1:2008 Conveyor belts -- Determination of minimum transition distance on three idler rollers
ISO 7590:2009 Steel cord conveyor belts -- Methods for the determination of total thickness and cover thickness
ISO 7622-1:2013 Steel cord conveyor belts -- Longitudinal traction test -- Part 1: Measurement of elongation
ISO 7622-2:2015 Steel cord conveyor belts -- Longitudinal traction test -- Part 2: Measurement of tensile strength
ISO 7623:2015 Steel cord conveyor belts -- Cord-to-coating bond test -- Initial test and after thermal treatment
ISO 8094:2013 Steel cord conveyor belts -- Adhesion strength test of the cover to the core layer
ISO 9856:2016 Conveyor belts -- Determination of elastic and permanent elongation and calculation of elastic modulus
ISO 10247:1990 Conveyor belts -- Characteristics of covers -- Classification
ISO 10247:1990/Amd 1:2006 Conveyor belts -- Characteristics of covers -- Classification
ISO 14890:2013 Conveyor belts -- Specification for rubber- or plastics-covered conveyor belts of textile construction for general use
ISO 15147:2012 Light conveyor belts -- Tolerances on widths and lengths of cut light conveyor belts
ISO 15236-1:2016 Steel cord conveyor belts -- Part 1: Design* dimensions and mechanical requirements for conveyor belts for general use
ISO 15236-2:2004 Steel cord conveyor belts -- Part 2: Preferred belt types
ISO 15236-3:2007 Steel cord conveyor belts -- Part 3: Special safety requirements for belts for use in underground installations
ISO 15236-4:2004 Steel cord conveyor belts -- Part 4: Vulcanized belt joints
ISO 16851:2012 Textile conveyor belts -- Determination of the net length of an endless (spliced) conveyor belt
ISO 18573:2012 Conveyor belts -- Test atmospheres and conditioning periods
ISO 21178:2013 Light conveyor belts -- Determination of electrical resistances
ISO 21179:2013 Light conveyor belts -- Determination of the electrostatic field generated by a running light conveyor belt
ISO 21180:2013 Light conveyor belts -- Determination of the maximum tensile strength
ISO 21181:2013 Light conveyor belts -- Determination of the relaxed elastic modulus
ISO 21182:2013 Light conveyor belts -- Determination of the coefficient of friction
ISO 21183-1:2005 Light conveyor belts -- Part 1: Principal characteristics and applications
ISO 21183-2:2005 Light conveyor belts -- Part 2: List of equivalent terms
ISO 22721:2007 Conveyor belts -- Specification for rubber- or plastics-covered conveyor belts of textile construction for underground mining
Synchronous belt drives
ISO 5288:2001 Synchronous belt drives -- Vocabulary
ISO 5294:2012 Synchronous belt drives -- Pulleys
ISO 5295:1987 Synchronous belts -- Calculation of power rating and drive centre distance
ISO 5296:2012 Synchronous belt drives -- Belts with pitch codes MXL* XXL* XL* L* H* XH and XXH -- Metric and inch dimensions
ISO 9010:1997 Synchronous belt drives -- Automotive belts
ISO 9011:1997 Synchronous belt drives -- Automotive pulleys
ISO 9563:2015 Belt drives -- Electrical conductivity of antistatic endless synchronous belts -- Characteristics and test method
ISO 12046:2012 Synchronous belt drives -- Automotive belts -- Determination of physical properties
ISO 13050:2014 Synchronous belt drives -- Metric pitch* curvilinear profile systems G* H* R and S* belts and pulleys
ISO 17396:2014 Synchronous belt drives -- Metric pitch* trapezoidal profile systems T and AT* belts and pulleys
ISO 19347:2015 Synchronous belt drives -- Imperial pitch trapezoidal profile system -- Belts and pulleys
missing are:
links:
or
