complete
EN 549:1994 Rubber materials for seals and diaphragms for gas appliances and gas equipment
EN 681-1:1996 Elastomeric seals - Materials requirements for pipe joint seals used in water and drainage applications - Part 1: Vulcanized rubber
EN 681-1:1996/A1:1998 Elastomeric seals - Materials requirements for pipe joint seals used in water and drainage applications - Part 1: Vulcanized rubber
EN 681-1:1996/A2:2002 Elastomeric seals - Materials requirements for pipe joint seals used in water and drainage applications - Part 1: Vulcanized rubber
EN 681-1:1996/A3:2005 Elastomeric seals - Material requirements for pipe joint seals used in water and drainage applications - Part 1: Vulcanized rubber
EN 681-1:1996/AC:2002 Elastomeric seals - Materials requirements for pipe joint seals used in water and drainage applications - Part 1: Vulcanized rubber
EN 681-2:2000 Elastomeric Seals - Materials requirements for pipe joint seals used in water and drainage applications - Part 2: Thermoplastic elastomers
EN 681-2:2000/A1:2002 Elastomeric Seals - Materials requirements for pipe joint seals used in water and drainage applications - Part 2: Thermoplastic elastomers
EN 681-2:2000/A2:2005 Elastomeric seals - Material requirements for pipe joint seals used in water and drainage applications - Part 2: Thermoplastic elastomers
EN 681-3:2000 Elastomeric seals - Materials requirements for pipe joint seals used in water and drainage applications - Part 3: Cellular materials of vulcanized rubber
EN 681-3:2000/A1:2002 Elastomeric seals - Materials requirements for pipe joint seals used in water and drainage applications - Part 3: Cellular materials of vulcanized rubber
EN 681-3:2000/A2:2005 Elastomeric seals - Material requirements for pipe joint seals used in water and drainage applications - Part 3: Cellular materials of vulcanized rubber
EN 681-4:2000 Elastomeric seals - Materials requirements for pipe joint seals used in water and drainage applications - Part 4: Cast polyurethane sealing elements
EN 681-4:2000/A1:2002 Elastomeric seals - Materials requirements for pipe joint seals used in water and drainage applications - Part 4: Cast polyurethane sealing elements
EN 681-4:2000/A2:2005 Elastomeric seals - Material requirements for pipe joint seals used in water and drainage applications - 4: Cast polyurethane sealing elements
EN 682:2002 Elastomeric Seals - Materials requirements for seals used in pipes and fittings carrying gas and hydrocarbon fluids
EN 682:2002/A1:2005 Elastomeric seals - Materials requirements for seals used in pipes and fittings carrying gas and hydrocarbon fluids
or
