Page 1 of 2 1 2 LastLast
Results 1 to 12 of 16
Thread: CEN Standards Collection 32/370: CEN TC 74 - Flanges And Their Joints
    3 standards missing...
    EN 1092-1:2007+A1:2013 Flanges and their joints - Circular flanges for pipes, valves, fittings and accessories, PN designated - Part 1: Steel flanges
    EN 1092-1:2007+A1:2013/AC:2014 Flanges and their joints - Circular flanges for pipes, valves, fittings and accessories, PN designated - Part 1: Steel flanges - missing
    EN 1092-2:1997 Flanges and their joints - Circular flanges for pipes, valves, fittings and accessories, PN designated - Part 2: Cast iron flanges
    EN 1092-3:2003 Flanges and their joints - Circular flanges for pipes, valves, fittings and accessories, PN designated - Part 3: Copper alloy flanges
    EN 1092-3:2003/AC:2007 Flanges and their joints - Circular flanges for pipes, valves, fittings and accessories, PN designated - Part 3: Copper alloy flanges
    EN 1092-4:2002 Flanges and their joints - Circular flanges for pipes, valves, fittings and accessories, PN designated - Part 4: Aluminium alloy flanges
    EN 1333:2006 Flanges and their joints - Pipework components - Definition and selection of PN
    EN 1514-1:1997 Flanges and their joints - Dimensions of gaskets for PN-designated flanges - Part 1: Non-metallic flat gaskets with or without inserts
    EN 1514-2:2014 Flanges and their joints - Gaskets for PN-designated flanges - Part 2: Spiral wound gaskets for use with steel flanges - missing VE
    EN 1514-3:1997 Flanges and their joints - Dimensions of gaskets for PN-designated flanges - Part 3: Non-metallic PTFE envelope gaskets
    EN 1514-4:1997 Flanges and their joints - Dimensions of gaskets for PN-designated flanges - Part 4: Corrugated, flat or grooved metallic and filled metallic gaskets for use with steel flanges
    EN 1514-6:2003 Flanges and their joints - Dimensions of gaskets for PN-designated flanges - Part 6: Covered serrated metal gaskets for use with steel flanges
    EN 1514-7:2004 Flanges and their joints - Gaskets for PN-designated flanges - Part 7: Covered metal jacketed gaskets for use with steel flanges
    EN 1514-8:2004 Flanges and their joints - Dimensions of gaskets for PN-designated flanges - Part 8: Polymeric O-Ring gaskets for grooved flanges
    EN 1515-1:1999 Flanges and their joints - Bolting - Part 1: Selection of bolting
    EN 1515-2:2001 Flanges and their joints - Bolting - Part 2: Classification of bolt materials for steel flanges, PN designated
    EN 1515-3:2005 Flanges and their joints - Bolting - Part 3: Classification of bolt materials for steel flanges, class designated
    EN 1515-4:2009 Flanges and their joints - Bolting - Part 4: Selection of bolting for equipment subject to the Pressure Equipment Directive 97/23/EC
    EN 1591-1:2013 Flanges and their joints - Design rules for gasketed circular flange connections - Part 1: Calculation
    EN 1591-2:2008 Flanges and their joints - Design rules for gasketed circular flange connections - Part 2: Gasket parameters
    CEN/TS 1591-3:2007 Flanges and their joints - Design rules for gasketed circular flange connections - Part 3: Calculation method for metal to metal contact type flanged joint
    EN 1591-4:2013 Flanges and their joints - Part 4: Qualification of personnel competency in the assembly of the bolted connections of critical service pressurized systems
    CEN/TR 1591-5:2012 Flanges and their joints - Design rules for gasketed circular flange connections - Part 5: Calculation method for full face gasketed joints
    EN 1759-1:2004 Flanges and their joint - Circular flanges for pipes, valves, fittings and accessories, Class designated - Part 1: Steel flanges, NPS 1/2 to 24
    EN 1759-3:2003 Flanges and their joints - Circular flanges for pipes, valves, fittings and accessories, Class designated - Part 3: Copper alloy flanges
    EN 1759-3:2003/AC:2004 Flanges and their joints - Circular flanges for pipes, valves, fittings and accessories, Class designated - Part 3: Copper alloy flanges
    EN 1759-4:2003 Flanges and their joint - Circular flanges for pipes, valves, fittings and accessories, class designated - Part 4: Aluminium alloy flanges
    EN ISO 6708:1995 Pipework components - Definition and selection of DN (nominal size) (ISO 6708:1995)
    EN 12560-1:2001 Flanges and their joints - Gaskets for Class-designated flanges - Part 1: Non-metallic flat gaskets with or without inserts
    EN 12560-2:2013 Flanges and their joints - Dimensions of gaskets for Class-designated flanges - Part 2: Spiral wound gaskets for use with steel flanges
    EN 12560-3:2001 Flanges and their joints - Gaskets for Class-designated flanges - Part 3: Non-metallic PTFE envelope gaskets
    EN 12560-4:2001 Flanges and their joints - Gaskets for Class-designated flantes - Part 4: Corrugated, flat or grooved metallic and filled metallic gaskets for use with steel flanges
    EN 12560-5:2001 Flanges and their joints - Gaskets for Class-designated flanes - Part 5: Metallic ring joint gaskets for use with steel flanges
    EN 12560-6:2003 Flanges and their joints - Gaskets for Class-designated flanges - Part 6: Covered serrated metal gaskets for use with steel flanges
    EN 12560-7:2004 Flanges and their joints - Gaskets for Class-designated flanges - Part 7: Covered metal jacketed gaskets for use with steel flanges
    EN 13555:2014 Flanges and their joints - Gasket parameters and test procedures relevant to the design rules for gasketed circular flange connection
    CR 13642:1999 Flanges and their joints - Design rules for gasketed circular flange connections - Background information - missing
    EN 14772:2005 Flanges and their joints - Quality assurance inspection and testing of gaskets in accordance with the series of standards EN 1514 and EN 12560
    or
    Re: CEN standards collection 32/100: CEN TC 74 - Flanges And Their Joints
    Dear Borntosin,
    many thanks for your valuable share.
    find below addition two standard, it may help.
    thanx
    updated with one missing...full list:
    we still missing:
    updated with some missing standards, and some better quality standards...we missing now only:
    Re: CEN Standards Collection 32/300: CEN TC 74 - Flanges And Their Joints
    still missing same standard...
    here are the fresh links:
    or
    still missing same one:
    fresh links:
    or
    no changes, missing standards is still:
    fresh links:
    Re: CEN Standards Collection 32/340: CEN TC 74 - Flanges And Their Joints
    still missing:
    new links:
    or
  14. Re: CEN Standards Collection 32/300: CEN TC 74 - Flanges And Their Joints
    Thank you! You are awesome!
  16. #12
    Re: CEN Standards Collection 32/370: CEN TC 74 - Flanges And Their Joints
    update:
    EN 1514-1:1997 Flanges and their joints - Dimensions of gaskets for PN-designated flanges - Part 1: Non-metallic flat gaskets with or without inserts - better quality
    EN 1514-4:1997 Flanges and their joints - Dimensions of gaskets for PN-designated flanges - Part 4: Corrugated* flat or grooved metallic and filled metallic gaskets for use with steel flanges
    still missing:
    new link:
  1. Replies: 6
    Last Post: 11-25-2017, 02:43 AM
  2. Replies: 4
    Last Post: 07-11-2017, 09:02 AM
  3. Replies: 0
    Last Post: 12-31-2016, 04:12 AM
  4. Replies: 0
    Last Post: 02-15-2014, 08:03 AM
  5. DIN flanges STANDARDs
    By Tarek Farah in forum Pipeline And Fluid Flow
    Last Post: 07-16-2013, 05:14 PM
