Results 1 to 11 of 11
Thread: C950-13 Fiberglass Pressure Pipe
    I am in urgent need of following stds.
    1. C950-13 Fiberglass Pressure Pipe
    2. D100-11 Welded Carbon Steel Tanks for Water Storage
    3. D102-11 Coating Steel Water-Storage Tanks
    4. D120-09 Thermosetting Fiberglass-Reinforced Plastic Tanks
    5. D121-12 Bolted Aboveground Thermosetting Fiberglass-Reinforced Plastic Panel-Type Tanks for Water Storage
    I am very thankful for the usual help provided by forum members.
  3. Re: C950-13 Fiberglass Pressure Pipe
    Please see attachments
    Greetings
    Abo Khaled
    Attached Files Attached Files
    Nov 2010
    Algiers, ALGERIA
    Abo Khaled
    Do you have?
    AWWA C104 Cement Mortar Lining for Ductile Iron Pipe and Fittings for Water.
    Thanks in advance
    If you download and find it useful, just click on Thanks button !
    Visit and become a member of
    Welding Engineering & Inspection group
    Here:
  6. Re: C950-13 Fiberglass Pressure Pipe
    Please see this link for AWWA D100-2005
    Greetings
    Abo Khaled
    Nov 2010
    Algiers, ALGERIA
    Quote Originally Posted by Abo Khaled View Post
    Greetings
    Abo Khaled
    Thanks a lot
    Here:
    Quote Originally Posted by acier58 View Post
    Thanks a lot
    Dear Acer
    I am also attaching a AWWA code related to same. Hope you will find it useful.
    Dears,
    kindly find below link for AWWA D100 2011 Edition
    I have Also D102 2014 Edition, I'll upload it later
    AWWA D102 2014 Edition
  13. Re: C950-13 Fiberglass Pressure Pipe
    Please see this link for AWWA D121
    Greetings
    Abo Khaled
  14. Re: C950-13 Fiberglass Pressure Pipe
    1. AWWA-C950-13 Fiberglass Pressure Pipe
  1. Fiberglass Reinforced Pipe - Stress Analysis
    By shanikka in forum Petrochemical
    Last Post: 01-20-2014, 07:33 AM
  2. pressure drop in a pipe
    By halcyon304 in forum Pipeline And Fluid Flow
    Last Post: 10-03-2013, 01:00 PM
  3. Pressure drop in pipe
    By javad64 in forum Pipeline And Fluid Flow
    Last Post: 02-14-2012, 08:33 PM
  4. API 12P Fiberglass Reinforced PlasticTanks
    Last Post: 05-27-2011, 05:06 PM
