only one valie edition is missing...
EN 10017:2004 Steel rod for drawing and/or cold rolling - Dimensions and tolerances
EN 10108:2004 Round steel rod for cold heading and cold extrusion - Dimensions and tolerances
EN 10218-1:2012 Steel wire and wire products - General - Part 1: Test methods
EN 10218-2:2012 Steel wire and wire products - General - Part 2: Wire dimensions and tolerances
EN 10223-1:2012 Steel wire and wire products for fencing and netting - Part 1: Zinc and zinc-alloy coated steel barbed wire
EN 10223-2:2012 Steel wire and wire products for fencing and netting - Part 2: Hexagonal steel wire netting for agricultural, insulation and fencing purposes
EN 10223-3:2013 Steel wire and wire products for fencing and netting - Part 3: Hexagonal steel wire mesh products for civil engineering purposes
EN 10223-4:2012 Steel wire and wire products for fencing and netting - Part 4: Steel wire welded mesh fencing
EN 10223-5:2012 Steel wire and wire products for fencing and netting - Part 5: Steel wire woven hinged joint and knotted mesh fencing
EN 10223-6:2012 Steel wire and wire products for fencing and netting - Part 6: Steel wire chain link fencing
EN 10223-7:2012 Steel wire and wire products for fencing and netting - Part 7: Steel wire welded panels for fencing
EN 10223-8:2013 Steel wire and wire products for fencing and netting - Part 8: Welded mesh gabion products
EN 10230-1:1999 Steel wire nails - Part 1: Loose nails for general applications
EN 10244-1:2009 Steel wire and wire products - Non-ferrous metallic coatings on steel wire - Part 1: General principles
EN 10244-1:2009/AC:2011 Steel wire and wire products - Non-ferrous metallic coatings on steel wire - Part 1: General principles - missing
EN 10244-2:2009 Steel wire and wire products - Non-ferrous metallic coatings on steel wire - Part 2: Zinc or zinc alloy coatings
EN 10244-3:2001 Steel wire and wire products -Non-ferrous metallic coatings on steel wire - Part 3: Aluminium coatings
EN 10244-4:2001 Steel wire and wire products - Non-ferrous metallic coatings on steel wire - Part 4: Tin coatings
EN 10244-5:2001 Steel wire and wire products - Non-ferrous metallic coatings on steel wire - Part 5: Nickel coatings
EN 10244-6:2001 Steel wire and wire products - Non-ferrous metallic coatings on steel wire - Part 6: Copper, bronze or brass coatings
EN 10245-1:2011 Steel wire and wire products - Organic coatings on steel wire - Part 1: General rules
EN 10245-2:2011 Steel wire and wire products - Organic coatings on steel wire - Part 2: PVC finished wire
EN 10245-3:2011 Steel wire and wire products - Organic coatings on steel wire - Part 3: PE coated wire
EN 10245-4:2011 Steel wire and wire products - Organic coatings on steel wire - Part 4: Polyester coated wire
EN 10245-5:2011 Steel wire and wire products - Organic coatings on steel wire - Part 5: Polyamide coated wire
EN 10257-1:2011 Zinc or zinc alloy coated non-alloy steel wire for armouring either power cables or telecommunication cables - Part 1: Land cables
EN 10257-2:2011 Zinc or zinc alloy coated non-alloy steel wire for armouring either power cables or telecommunication cables - Part 2: Submarine cables
EN 10263-1:2001 Steel rod, bars and wire for cold heading and cold extrusion - Part 1: General technical delivery conditions
EN 10263-1:2001/AC:2002 Steel rod, bars and wire for cold heading and cold extrusion - Part 1: General technical delivery conditions
EN 10263-2:2001 Steel rod, bars and wire for cold heading and cold extrusion - Part 2: Technical delivery conditions for steels not intended for heat treatment after cold working
EN 10263-3:2001 Steel rod, bars and wire for cold heading and cold extrusion - Part 3: Technical delivery conditions for case hardening steels
EN 10263-4:2001 Steel rod, bars and wire for cold heading and cold extrusion - Part 4: Technical delivery conditions for steels for quenching and tempering
EN 10263-4:2001/AC:2002 Steel rod, bars and wire for cold heading and cold extrusion - Part 4: Technical delivery conditions for steels for quenching and tempering
EN 10263-5:2001 Steel rod, bars and steel wire for cold heading and cold extrusion - Part 5: Technical delivery conditions for stainless steels
EN 10264-1:2012 Steel wire and wire products - Steel wire for ropes - Part 1: General requirements
EN 10264-2:2012 Steel wire and wire products - Steel wire for ropes - Part 2: Cold drawn non alloy steel wire for ropes for general applications
EN 10264-3:2012 Steel wire and wire products - Steel wire for ropes - Part 3: Round and shaped non alloyed steel wire for high duty applications
EN 10264-4:2012 Steel wire and wire products - Steel wire for ropes - Part 4: Stainless steel wire
EN 10270-1:2011 Steel wire for mechanical springs - Part 1: Patented cold drawn unalloyed spring steel wire
EN 10270-2:2011 Steel wire for mechanical springs - Part 2: Oil hardened and tempered spring steel wire
EN 10270-3:2011 Steel wire for mechanical springs - Part 3: Stainless spring steel wire
EN 10323:2004 Steel wire and wire products - Bead wire
EN 10324:2004 Steel wire and wire products - Hose reinforcement wire
EN 10324:2004/AC:2008 Steel wire and wire products - Hose reinforcement wire
EN ISO 16120-1:2011 Non-alloy steel wire rod for conversion to wire - Part 1: General requirements (ISO 16120-1:2011)
EN ISO 16120-2:2011 Non-alloy steel wire rod for conversion to wire - Part 2: Specific requirements for general-purpose wire rod (ISO 16120-2:2011)
EN ISO 16120-3:2011 Non-alloy steel wire rod for conversion to wire - Part 3: Specific requirements for rimmed and rimmed substitute, low-carbon steel wire rod (ISO 16120-3:2011)
EN ISO 16120-4:2011 Non-alloy steel wire rod for conversion to wire - Part 4: Specific requirements for wire rod for special applications (ISO 16120-4:2011)
or
