Thread: Double jeopardy
    Double jeopardy
    Dear members,
    I need your advise for below case:
    1. System is isolated from well by a single valve during preservation. Hence, valve can be opened inadvertently due to human error.
    2. A associated system (diesel) is connect to well at that time. Only one check valve is installed to prevent back flow.
    Question:
    1. Do we need to provide a PSV for back flow if it consider human error and check valve failure/leakage?
    2. Is that double jeopardy if both human error and check valve failure are considered in this case?
    See sketch.
    Attached Files Attached Files
  3. Re: Double jeopardy
    Dear Sir* API 521 states:
    4.2.3 Double Jeopardy
    The causes of overpressure are considered to be unrelated (i.e. independent) if no process or mechanical or
    electrical linkages exist among them or if the length of time that elapses between possible successive occurrences of
    these causes is sufficient to make their classification unrelated. The simultaneous occurrence of two or more
    unrelated causes of overpressure (also known as double or multiple jeopardy) is not a basis for design.
    Examples of
    double jeopardy scenarios are fire exposure simultaneous with exchanger internal tube failure* fire exposure
    simultaneous with failure of administrative controls to drain and depressure isolated equipment* or operator error that
    leads to a blocked outlet coincident with a power failure.
    On the other hand* instrument air failure during fire exposure
    may be considered single jeopardy if the fire exposure causes local air line failures. See 4.2.6 for additional guidance.
    This standard describes single jeopardy scenarios that should be considered as a basis for design. The user may
    choose to go beyond these practices and assess multiple jeopardy scenarios* particularly for severe consequence
    events. Because such assessments are outside the basis for design* the user is not required to meet accumulations
    allowed by the pressure design code for these scenarios. Acceptance criteria are the sole responsibility of the user.
  1. double jeopardy in hazop and what if
    By ameer in forum Safety And Environment
    Last Post: 03-16-2014, 03:22 PM
  2. Double a a4 80 gsm (500’s)
    By jivent in forum Computer & Internet
    Last Post: 01-18-2012, 03:27 PM
  3. Double acting actuator with spring
    By YSH in forum Instrumentation & Control
    Last Post: 07-13-2011, 08:36 PM
  4. Double Jeopardy in HAZOP study
    By bkay in forum Safety And Environment
    Last Post: 12-12-2009, 02:35 PM
