Thread: Double acting actuator with spring
    Can a double acting actuator have a spring? If yes (for reaching the fail safe position), how is this construction better than single acting actuator?
  3. Generally double acting actuators don't have any spring for safety reason.these valve utilise with small air volume tank as power for fail safe position.normally the voulume calculate for 3 time open/close of the valves.
    kindly, the new double acting can assembly with spring for onside or both, you can found that on ROTOK actuator type
    regards
  1. Valve & Actuator Sizing
    By dsp151 in forum Instrumentation & Control
    Last Post: 07-07-2011, 05:34 AM
