[h=Selecting pipe wall thickness]2[/h]The fluid flow equations and formulas presented thus far enable the engineer to initiate the design of a piping or pipeline system, where the pressure drop available governs the selection of pipe size. (In addition, there may be velocity constraints that might dictate a larger pipe diameter. This is discussed below in the section on velocity considerations for pipelines.
Once the inner diameter (ID) of the piping segment has been determined, the pipe wall thickness must be calculated. There are many factors that affect the pipe-wall-thickness requirement, which include:
- The maximum and working pressures
- Maximum and working temperatures
- Chemical properties of the fluid
- The fluid velocity
- The pipe material and grade
- The safety factor or code design application
If there are no codes or standards that specifically apply to the oil and gas production facilities, the design engineer may select one of the industry codes or standards as the basis of design. The design and operation of gathering, transmission, and distribution pipeline systems are usually governed by codes, standards, and regulations. The design engineer must verify whether the particular country in which the project is located has regulations, codes, and standards that apply to facilities and/or pipelines.
The basic formula for determining pipe wall thickness is the general hoop stress formula for thin-wall cylinders, which is stated as
(Eq. 1)
where
[h=Piping codes]3[/h]The following standards from the American Natl. Standards Inst. (ANSI) and the American Soc. of Mechanical Engineers (ASME) specify wall-thickness requirements.
HS = hoop stress in pipe wall, psi, t = pipe wall thickness, in., L = length of pipe, ft, P = internal pressure of the pipe, psi, and dO = outside diameter of pipe, in.
- ANSI/ASME Standard B31.1, Power Piping. This standard applies to steam piping systems.
- ANSI/ASME Standard B31.3, Chemical Plant and Petroleum Refinery Piping. This standard applies to major facilities onshore and offshore worldwide.
- ANSI/ASME Standard B31.4, Liquid Transportation Systems for Hydrocarbons, Liquid Petroleum Gas, Anhydrous Ammonia, and Alcohols.
- ANSI/ASME Standard B31.8, Gas Transmission and Distribution Piping Systems. This standard applies to gas transmission, gathering, and distribution pipelines onshore.
In the U.S, piping on offshore facilities is mandated by regulation to be done in accordance with ANSI/ASME Standard B31.3. Most onshore facilities are designed in accordance with ANSI/ASME Standard B31.4 or B31.8, depending on whether it is an oil or gas facility. respectively. Some companies use the more stringent ANSI/ASME Standard B31.3 for onshore facilities.
In other countries, similar standards apply with minor variations. For simplicity, we will discuss only the U.S. standards in this chapter. The engineer should check to see if there are different standards that must be applied in the specific location of the design.
[h=Pipe materials - basics]3[/h]There are some applications where plastic, concrete, or other piping materials are both desirable and acceptable. Utility systems such as those for water, sanitary or storm water, air, draining or low-pressure oil or gas service applications often use the nonsteel piping material systems. However, for the vast majority of the “pressure” piping systems encountered, steel pipe is required.
For petroleum applications, pipe materials that meet American Petroleum Inst. (API), American Soc. for Testing and Materials (ASTM), ASME, and ANSI standards are used most often. All of these standards have very rigid design, specification, chemistry, and testing standardization and manufacturing requirements. Modern steel pipe manufactured to these exacting standards assures both high quality and safety in design.
Steel pipe is available in a variety of commercial sizes ranging from nominal 1/8 up to 60 in. or greater. Table 1 illustrates a number ANSI pipe schedules, for reference. The “nominal” commercial pipe sizes from 1/8 through 12 in. refer to the approximate ID measurement of Schedule 40 or “standard” wall, whereas nominal 14 in. and larger sizes refer to the outside diameter. A variety of steel pipe sizes, wall thicknesses, and material grades are available for petroleum piping and pipeline applications.
Table 1[link Point to another website Only the registered members can access]
Please note that the allowable internal pressure is the maximum pressure to which the piping system can be subjected. This could be significantly higher than the flowing pressure of the fluid in the pipe.
[h=Wall thickness calculations - using B31.3 Code]3[/h]ANSI/ASME Standard B31.3 is a very stringent code with a high safety margin. The B31.3 wall-thickness calculation formula is stated as
(Eq. 2)
where
t = minimum design wall thickness, in., te = corrosion allowance, in., tth = thread or groove depth, in. (Table 2), P = allowable internal pressure in pipe, psi, dO = outside diameter of pipe, in., S = allowable stress for pipe, psi (Tables 3 and 4), E = longitudinal weld-joint factor [1.0 seamless, 0.95 electric fusion weld, double butt, straight or spiral seam APL 5L, 0.85 electric resistance weld (ERW), 0.60 furnace butt weld], Y = derating factor (0.4 for ferrous materials operating below 900°F), and Tol = manufacturers allowable tolerance, % (12.5 pipe up to 20 in.-OD, 10 pipe > 20 in. OD, API 5L).
Table 2[link Point to another website Only the registered members can access]
Table 3[link Point to another website Only the registered members can access]
Table 4[link Point to another website Only the registered members can access]
Under ANSI/ASME Standard B31.3, the allowable pressure can be increased for certain instances. The conditions for the permissible increases in allowable pressure, according to Standard B31.3, are given next.
- When the variation lasts no more than 10 hours at any one time and not more than 100 hours per year, it is permissible to exceed the pressure rating or the allowable stress for pressure design at the temperature of the increased condition by no more than 33%.
- When the variation lasts no more than 50 hours at any one time and not more than 500 hours per year, it is permissible to exceed the pressure rating or the allowable stress for pressure design at the temperature of the increased condition by not more than 20%.
[h=Wall thickness calculations - using B31.4 Code]3[/h]The ANSI/ASME Standard B31.4 code is somewhat less stringent than that of Standard B31.3 because of the lower levels of hazard associated with liquid pipelines. The code for Standard B31.4 is used often as the standard of design for crude-oil piping systems in facilities, such as pump stations, pigging facilities, measurement and regulation stations, and tank farms. The wall-thickness formula for Standard B31.4 is stated as
(Eq. 3)
where
t = minimum design wall thickness, in., P = internal pressure in pipe, psi, dO = OD of pipe, in., SY = minimum yield stress for pipe, psi ( Table 5 ), F = derating factor, 0.72 for all locations, and E = longitudinal weld-joint factor [1.0 seamless, ERW, double submerged arc weld and flash weld; 0.80 electric fusion (arc) weld and electric fusion weld, 0.60 furnace butt weld].
Table 5[link Point to another website Only the registered members can access]
Table 5 (Cont'd)[link Point to another website Only the registered members can access]
[h=Wall thickness calculations - using B31.8 code]3[/h]The ANSI/ASME Standard B31.8 code is less stringent than that of Standard B31.3, but more stringent than that of Standard B13.4. The B31.8 code is often used as the standard of design for natural-gas piping systems in facilities, such as compressor stations, gas-treatment facilities, measurement and regulation stations, and tank farms. The B31.8 wall-thickness formula is stated as
(Eq. 4)
where
t = minimum design wall thickness, in., P = internal pressure in pipe, psi, dO = OD of pipe, in., SY = minimum yield stress for pipe, psi (Table 6), F = design factor (see Table 7 and discussion that follows), E = longitudinal weld-joint factor (Table 8), and T = temperature derating factor (Table 9).
Table 6[link Point to another website Only the registered members can access]
Table 6 (Cont'd)[link Point to another website Only the registered members can access]
Table 7[link Point to another website Only the registered members can access]
Table 8[link Point to another website Only the registered members can access]
Table 9[link Point to another website Only the registered members can access]
The design factor, F, for steel pipe is a construction derating factor dependent upon the location class unit, which is an area that extends 220 yards on either side of the centerline of any continuous 1-mile length of pipeline. Each separate dwelling unit in a multiple-dwelling-unit building is counted as a separate building intended for human occupancy.
To determine the number of buildings intended for human occupancy for an onshore pipeline, lay out a zone 1/4-mile wide along the route of the pipeline with the pipeline on the centerline of this zone, and divide the pipeline into random sections 1 mile in length such that the individual lengths will include the maximum number of buildings intended for human occupancy. Count the number of buildings intended for human occupancy within each 1-mile zone. For this purpose, each separate dwelling unit in a multiple-dwelling-unit building is to be counted as a separate building intended for human occupancy.
It is not intended here that a full mile of lower-stress pipeline shall be installed if there are physical barriers or other factors that will limit the further expansion of the more densely populated area to a total distance of less than 1 mile. It is intended, however, that where no such barriers exist, ample allowance shall be made in determining the limits of the lower stress design to provide for probable further development in the area.
When a cluster of buildings intended for human occupancy indicates that a basic mile of pipeline should be identified as a Location Class 2 or Location Class 3, the Location Class 2 or Location Class 3 may be terminated 660 ft from the nearest building in the cluster. For pipelines shorter than 1 mile in length, a location class shall be assigned that is typical of the location class that would be required for 1 mile of pipeline traversing the area.
[h=Location Classes for Design and Construction]3[/h][h=Class 1 location]4[/h]A Class 1 location is any 1-mile section of pipeline that has 10 or fewer buildings intended for human occupancy. This includes areas such as: • Wastelands • Deserts • Rugged mountains • Grazing land • Farmland • Sparsely populated areas
[h=Class 1, division 1 location]4[/h]This is a Class 1 location where the design factor, F, of the pipe is greater than 0.72 but equal to or less than 0.80 and which has been hydrostatically tested to 1.25 times the maximum operating pressure. (See Table 9.13 for exceptions to design factor.)
[h=Class 1, division 2 location]4[/h]This is a Class 1 location where the design factor, F, of the pipe is equal to or less than 0.72, and which has been tested to 1.1 times the maximum operating pressure.
[h=Class 2 location]4[/h]This is any 1-mile section of pipeline that has more than 10 but fewer than 46 buildings intended for human occupancy. This includes fringe areas around cities and towns, industrial areas, and ranch or country estates.
[h=Class 3 location]4[/h]This is any 1-mile section of pipeline that has 46 or more buildings intended for human occupancy except when a Class 4 Location prevails. This includes: • Suburban housing developments • Shopping centers • Residential areas • Industrial areas • Other populated areas not meeting Class 4 Location requirements
[h=Class 4 location]4[/h]This is any 1-mile section of pipeline where multistory buildings are prevalent, traffic is heavy or dense, and where there may be numerous other utilities underground. Multistory means four or more floors above ground including the first, or ground, floor. The depth of basements or number of basement floors is immaterial.
[h=Comparions of the different classes]4[/h]In addition to the criteria previously presented, additional consideration must be given to the possible consequences of a failure near a concentration of people, such as that found in a church, school, multiple-dwelling unit, hospital, or recreational area of an organized character in a Class 1 or 2 location. If the facility is used infrequently, the requirements of the following paragraph need not be applied.
Pipelines near places of public assembly or concentrations of people such as churches, schools, multiple-dwelling-unit buildings, hospitals, or recreational areas of an organized nature in Class 1 and 2 locations shall meet requirements for the Class 3 location.
The concentration of people previously referred to is not intended to include groups fewer than 20 people per instance or location but is intended to cover people in an outside area as well as in a building.
It should be emphasized that location class (1, 2, 3, or 4), as previously described, is the general description of a geographic area having certain characteristics as a basis for prescribing the types of design, construction, and methods of testing to be used in those locations or in areas that are respectively comparable. A numbered location class, such as Location Class 1, refers only to the geography of that location or a similar area and does not necessarily indicate that a design factor of 0.72 will suffice for all construction in that particular location or area (e.g., in Location Class 1, all crossings without casings require a design factor, F, of 0.60).
When classifying locations for the purpose of determining the design factor, F, for the pipeline construction and testing that should be prescribed, due consideration shall be given to the possibility of future development of the area. If at the time of planning a new pipeline this future development appears likely to be sufficient to change the class location, this should be taken into consideration in the design and testing of the proposed pipeline.
