Thread: Pressure Vessel Design - Consideration of Pressure Thrust
  1. Pressure Vessel Design - Consideration of Pressure Thrust
    Hello Everybody,
    Is it required to consider pressure thrust while analyzing a nozzle on pressure vessel for local loads (due to piping reactions) using rules of WRC 107 and or WRC 297 publications?
    AK
    Re: Pressure Vessel Design - Consideration of Pressure Thrust
    The phenomenon of pressure thrust is very complicated. It completely depends on the stiffness of the piping system attached to nozzle.
    If you client has specify the same in design specification then you can add pressure thrust in 107/297 analysis.
    If not, then do not use the same as applying the pressure thrust fully will be very conservative.
    Thanks.
  1. Guide To The Design Of Thrust Blocks For Buried Pressure Pipelines
    By selmagis in forum Pipeline And Fluid Flow
    Last Post: 04-30-2018, 07:04 AM
  2. Replies: 31
    Last Post: 08-04-2017, 07:00 PM
  3. Guide To The Design Of Thrust Blocks For Buried Pressure Pipelines
    By dinahajjar in forum Pipeline And Fluid Flow
    Last Post: 05-27-2013, 09:52 AM
  4. Replies: 0
    Last Post: 05-19-2013, 11:07 PM
  5. Replies: 3
    Last Post: 05-13-2013, 06:17 PM
