Hi VictorM , Sambun and Shabbir2009
Followings are the links you requested. Be freely download and enjoy it.
ASME MEASUREMENT OF FLUID FLOW IN CLOSED CONDUIT
No ASME No Title
1 MFC-1M Glossary of Terms Used in the Measurement of Fluid Flow in Pipes
2 MFC-2M Measurement Uncertainty for Fluid Flow in Closed Conduits
3 MFC-3M Measurement of Fluid Flow in Pipes Using Orifice, Nozzle, and Venturi Errata - September 1990
4 MFC-4M Measurement of Gas Flow by Turbine Meters
5 MFC-5M Measurement of Liquid Flow in Closed Conduits Using Transit-Time Ultrasonic Flowmeters
6 MFC-6M Measurement of Fluid Flow in Pipes Using Vortex Flowmeters
7 MFC-7M Measurement of Gas Flow by Means of Critical Flow Venturi Nozzles
8 MFC-8M Fluid Flow in Closed Conduits : Connections for Pressure Signal Transmissions Between Primary and Secondary Devices
9 MFC-9M Measurement of Liquid Flow in Closed Conduits by Weighing Methods Errata - December 1989
10 MFC-10M Method for Establishing Installation Effects on Flowmeters
11 MFC-11M Measurement of Fluid Flow by Means of Coriolis Mass Flowmeters
12 MFC-14M Measurement of Fluid Flow Using Small Bore Precision Orifice Meters
13 MFC-16M Measurement of Fluid Flow In Closed Conduits by Means of Electromagnetic Flowmeters
14 MFC-18M Measurement of Fluid Flow Using Variable Area Meters
1. MFC-1M-2003.pdf 1.868 MB[link Point to another website Only the registered members can access]
2 MFC-2M-1983.pdf 2.487 MB [link Point to another website Only the registered members can access]
3. MFC-3M-1995.pdf 2.746 MB [link Point to another website Only the registered members can access]
4. MFC-4M-1986.pdf 0.953 MB [link Point to another website Only the registered members can access]
5. MFC-5M-1985.pdf 0.775 MB [link Point to another website Only the registered members can access]
6. MFC-6M-1998.pdf 0.600 MB [link Point to another website Only the registered members can access]
7. MFC-7M-1987.pdf 1.204 MB [link Point to another website Only the registered members can access]
8. MFC-8M-2001.pdf 6.809 MB [link Point to another website Only the registered members can access]
9. MFC-9M-1988.pdf 1.022 MB [link Point to another website Only the registered members can access]
10. MFC-10M-2000.pdf 6.715 MB [link Point to another website Only the registered members can access]
11 MFC-11M-2003.pdf 2.656 MB[link Point to another website Only the registered members can access]
12 MFC-14M-2003.pdf 1.178 MB [link Point to another website Only the registered members can access]
13 MFC-16M-1995.pdf 0.807 MB [link Point to another website Only the registered members can access]
14. MFC-18M-2001.pdf 0.485 MB [link Point to another website Only the registered members can access]
I do not have the following standard as stated below. In order to complete this ASME MFC standard, please somebody can upload and sharing it to us.
ASME MFC 12M Measurement of Fluid Flow in Closed Conduits Using Multiport Averaging Pitot Primary Elements
ASME MFC 13M Measurement of Fluid Flow in Closed Conduits: Tracer Methods
ASME MFC 15M Withdrawn ?
ASME MFC 17M Withdrawn ?
ASME MFC 19M Not available ?
