Results 1 to 5 of 5
Thread: ASME Standards-Fluid Flow Measurement
  1. Smile ASME Standards-Fluid Flow Measurement
    Hi....can anyone..share the following ASME Standards!!!!!!!!!
    ASME MFC- 10M: Method for Establishing Installation Effects on Flowmeters
    ASME MFC- 11M: Measurement of Fluid Flow by Means of Coriolis Mass Flowmeters
    ASME MFC- 14M: Measurement of Fluid Flow Using Small Bore Precision Orifice Meters
    ASME MFC- 16M: Measurement of Fluid Flow In Closed Conduits by Means of Electromagnetic Flowmeters
    ASME MFC- 18M: Measurement of Fluid Flow Using Variable Area Meters
    ASME MFC- 1M: Glossary of Terms Used in the Measurement of Fluid Flow in Pipes
    ASME MFC- 2M: Measurement Uncertainty for Fluid Flow in Closed Conduits
    ASME MFC- 3M: Measurement of Fluid Flow in Pipes Using Orifice, Nozzle, and Venturi-Date of Issuance: 8/15/2005
    ASME MFC- 4M: Measurement of Gas Flow by Turbine Meters
    ASME MFC- 5M: Measurement of Liquid Flow in Closed Conduits Using Transit-Time Ultrasonic Flowmeters
    ASME MFC- 6M: Measurement of Fluid Flow in Pipes Using Vortex Flowmeters
    ASME MFC- 7M: Measurement of Gas Flow by Means of Critical Flow Venturi Nozzles
    ASME MFC- 8M: Fluid Flow in Closed Conduits : Connections for Pressure Signal Transmissions Between Primary and Secondary Devices
    ASME MFC- 9M: Measurement of Liquid Flow in Closed Conduits by Weighing Methods-Errata - December 1989
    Here are all that I could find out there.. the ones you asked for plus 19G & 22
    Sep 2008
    Here only- EGPET
    Blog Entries
    5
    go through the post
    Nov 2009
    All over EGPET
    Blog Entries
    1
    Thanks for the share
    Thanks a lot. Good luck!!!
    Quote Originally Posted by amshah View Post
    go through the post
    thank u very much for referral
    Muhammad Khurram
  1. Asme measurement of fluid flow
    By Achmad Nur Eddin in forum Instrumentation & Control
    Last Post: 07-02-2019, 06:11 AM
  2. Fluid FLow Measurement Standards -BS 1042 / ISO 5167
    By instsuresh in forum Instrumentation & Control
    Last Post: 04-23-2016, 06:53 AM
  3. Fluid Flow Measurement
    By selmagis in forum Pipeline And Fluid Flow
    Last Post: 09-11-2014, 11:16 PM
  4. Fluid Flow Measurement
    By Mohamed in forum Pipeline And Fluid Flow
    Last Post: 05-01-2013, 12:10 AM
