API 579-1 Fitness-For-Service calcs, Excel, Part 2
Thank you for the post.
Are these sheets OK to use or should I cross check before use?
Thanks a lot
Lets try all of them
They have been created from the worked examples given in API 579-2, Example Problem Manual, sections 5.5 and 13.1 and I have used them to generate FFS reports. I would recommend cross checking the 5.4 excel file posted in an earlier thread if a new set of data is input, as the spreadsheet is extremely complicated.
Thanks a lot!
Thanks,
Amit
Thanks,
Amit
many thanks
thanks for sharing
