Page 1 of 2 1 2 LastLast
Results 1 to 12 of 14
Thread: Fitness for Service
    Fitness for Service
    I am interested in conducting fitness-for-service assessments per API 579-1/ASME FFS-1. I would appreciate if any one has worked examples or copy of FFS-2 examples book.
    Thanks,
    Nabili
    Hi Nabili
    I was looking for this book as well, but looks like still none of our colleagues have had access to it yet.
    Also for me it is very important to find worked examples regarding fitness-for-service in pipeline.
    Thank you
    Please find the link for your request.
    Thank you!!!!
    IS THERE ANYONE WHO HAS THIS BOOK? PLEASE SHARE....
    Overview
    Based on some of his students most frequently asked questions, Antaki emphasizes the practical applications of this ASME recommended practice. With this book readers will understand and apply API 579 in their daily work. The material is based on the author’s course and presented in clear concise manor. The book demonstrates how the disciplines of stress analysis, materials engineering, and nondestructive inspection interact and apply to fitness-for-service assessment. These assessment methods apply to pressure vessels, piping, and tanks that are in service. This makes it the perfect companion book for Ellenberger’s, Pressure Vessels: ASME Code Simplified as well as Ellenberger’s Piping Systems and Pipeline: ASME B31 Code Simplified.
    Table of contents
    Chapter 1: Principles
    Chapter 2: Materials
    Chapter 3: Design
    Chapter 4: Fabrication
    Chapter 5: Degradation
    Chapter 6: Inspection
    Chapter 7: Thinning
    Chapter 8: Geometric Defects
    Chapter 9: -----s
    Chapter 10: Creep Damage
    Chapter 11: Overload
    Chapter 12: Failure Analysis
    Chapter 13: Repairs
    APPENDIX: WRC BULLETINS
    INDEX
    Biographical note
    George Antaki is a Fellow of the American Society of Mechanical Engineers. He is a member of the ASME B31 Mechanical Design Technical Committee, the ASME Post-Construction Subcommittee on Repairs and Testing, and the Joint API-ASME Task Group on Fitness-for-Service. Mr. Antaki has extensive field experience in design, inspection, integrity, and retrofit of vessels and piping systems and equipment. He resides in Aiken, South Carolina.
    Back cover copy
    Run-or-repair evaluations for tanks, vessels, piping, and pipelines
    ASME code for operating equipment and systems
    ASME and API rules for structural integrity of equipment and pipelines
    A Complete Guide to ASME Recommended Practices for Assessing, Monitoring, and Maintaining Pressure Vessels and Piping
    Fitness-for-Service and Integrity of Piping Vessels and Tanks provides instruction on the latest ASME recommended practices for inspecting, evaluating, and monitoring pressure vessels and Piping.
    This handy volume annotates and explains ASME code and API inspection and fitness-for-service practices. Presented in a clear, precise manner, this comprehensive guide meticulously explains how stress analysis, materials, engineering, and nondestructive inspection affect fitness-for-service.
    The tools needed to . . .
    Inspect and categorize damage, degradation, and corrosion mechanisms
    Evaluate wall thinning, pitting, -----ing, fatigue, mechanical damage, high-temperature corrosion, and creep
    Develop and implement programs for corrective and predictive maintenance of tanks, vessels, piping, and pipelines
    Select the right repair technique and avoid pitfalls in repair welding and joining
    A COMPREHENSIVE GUIDE TO ASME RECOMMENDED PRACTICES:
    What Causes Failures * Material Defects; Design Errors * Construction Flaws * Corrosion and Damage Mechanisms * Failures In-Service * Inspection Techniques; Maintenance and Risk-Based Inspection Strategies * Failure Margins and Prevention * Margins to Failure * Run-or-Repair Decisions * Repair Techniques
  10. Folks
    This is NOT the book we are looking for, however it is related to fitness-for-service and a very good reference too. I'm copying some download links for you
    Keith Escoe, "Piping and Pipelines Assessment Guide, Volume 1 "
    Gulf Professional Publishing | 2006 | ISBN: 0750678801 | 560 pages | PDF | 3,9 MB
    Whether it's called "fixed equipment" (at ExxonMobil), "stationary equipment" (at Shell), or "static equipment" (in Europe), this type of equipment is the bread and butter of any process plant. Used in the petrochemical industry, pharmaceutical industry, food processing industry, paper industry, and the manufacturing process industries, stationary equipment must be kept operational and reliable for companies to maintain production and for employees to be safe from accidents. This series, the most comprehensive of its kind, uses real-life examples and time-tested rules of thumb to guide the mechanical engineer through issues of reliability and fitness-for-service.
    This volume on piping and pipeline assessment is the only handbook that the mechanical or pipeline engineer needs to assess pipes and pipelines for reliability and fitness-for-service.
    * Provides essential insight to make informed decisions on when to run, alter, repair, monitor, or replace equipment
    * How to perform these type of assessments and calculations on pipelines is a 'hot' issue in the petrochemical industry at this time
    * There is very little information on the market right now for pipers and pipeliners with regard to pipe and pipeline fitness-for-service
    Download links:
    Keep on sharing !!!
    Thanks a lot for sharing this information. It is very useful.
    Thank you!!!
    Many thanks
  14. #11
    Quote Originally Posted by maskedsperm View Post
    Folks
    Download links:
    Maskedsperm, those links are already dead bro..please re-share it.thanks..
  16. Re: Fitness for Service
    All links deleted...please reupload....
  1. API 579 - Fitness-For-Service
    By Gasflo in forum Mechanical Engineering
    Last Post: 08-24-2018, 01:20 PM
  2. Fitness For Service
    Last Post: 10-13-2015, 01:00 PM
  3. API 579 Fitness for service
    By Jinny Varkey in forum Pipeline And Fluid Flow
    Last Post: 07-19-2011, 07:23 PM
  4. Fitness for service
    By cosili in forum Materials Science &Corrosion
    Last Post: 02-20-2010, 09:28 PM
