Results 1 to 9 of 9
Thread: HYSYS 3.2 vs CHEMCAD vs SimSci PRO II
  1. HYSYS 3.2 vs CHEMCAD vs SimSci PRO II
    I need to learn how to use simulation software within 1 month (full time) to do my final college project about gas processing, specifically a Dew Point Plant - DDP. The project subject is to simulate a chiller to refill the propane refrigeration system. I'll have to simulate a Stabilization Tower with a Reboiler, a Compressor (already in process), an extra Chiller to recuperate propane and a Biphasic Separator. I just want to do some few simple analyses like: basically mass balance. Possibly energy balance and economics as secondary objectives.
    I found out 3 most common software’s.: HYSYS 3.2 vs CHEMCAD vs SimSci PRO II.
    I found on the net the following training material available:
    HYSYS 3.2 : a lot of manuals and examples.
    CHEMCAD: few manuals and examples.
    SimSci PRO II: 1 manual and no examples.
    I would like to know under my situation (1 month and gas processing) what would be the easier/quicker to learn, use, simulate.....
    Do you have some experience on the software’s mentioned? Any sugestion?
    Thiago Coelho de Souza
    souza.eq@gmail.com
    Does your college provide any simulation software?
    Do they allow to use pirated software?
  5. softwares
    They don't provide any software, but I already have DESIGN PRO II, WINSIM, CHEMCAD, HYSYS. Which dou you recomend to I start to learn? The easier/quiker?
    Of the lot, CHEMCAD is the easiest to use.
    Make sure that the software you use is legal.
  7. Lightbulb All of them are alike
    I think that all of the simulation packages are alike in their use , so if you knew how to use one of them , then you will learn the differences between them easily.
    for ur purpose i think hysys will perfectly fit bec. its tut. contains a gas processing plant (steady state and dynamics)
    finally , i advise you to look at different softwares after learning hysys
    hysys is better
    I would suggest you go hysys. It is very comprehensive.
    Please i will be glad if you can share with me the hysys software you have thru my email: chukkyslexo@yahoo.com. The one i have does not install. Or give me the link to obtain it. Am honestly in need of it. Thanks
  10. I would suggest Hysis too. Its the best process simulator I have ever worked with. Chemcad maybe the simplest, but not the most powerful and thats a pity, because I now use Aspen Plus in my current job and I think its the worse process simulator I have ever worked with. Everything is so damn archaic and user unfriendly.
  11. The best simulator for your purpose:
    Aspen Hysys v7 or Hysys 3.2 (new and old versions)
    Quote Originally Posted by coelhothiago View Post
    souza.eq@gmail.com
  12. My friend use all three simulator and then review all their outputs and compare, after all you chose the best values acording to your requirements. However, PRO/II is more used for this process.
    I am learnig about these simulations if you want, we can to talk by chat, add me: ajcp_26@hotmail.com
  1. Article: Hysys Vs ChemCad Vs Aspen plus Vs ProII
    By mkhurram79 in forum Home Articles
    Last Post: 09-20-2011, 09:25 AM
  2. Article: Hysys Vs ChemCad Vs Aspen plus Vs ProII
    Last Post: 04-18-2011, 09:08 PM
