Thread: Valve selection help request
  1. Valve selection help request
    Hello.
    I need a valve which will control the firewater pressure for the hyperbaric chamber fires. The valve will always provide the water pressure 5 bar over chamber pressure. Max. chamber pressure will be 7,5 bar.
    For example if the chamber is at atmospheric pressure the fire water will come with 5 bar. Or if the chamber is 4 bar at that moment valve will set the water to 9 bar.
    I'm waiting for your advises.
    Thanks in advance.
    Ozdemir
    Re: Valve selection help request
    Hi Coverall
    The valve should be designed for the bigger dP in this case 7.5 bar.
    You need look for pressure and temperature to avoid problems.
    Hi Coverall
  1. API RP 615 Valve Selection Guide - Request
    By shaggex in forum Oil And Gas Process
    Last Post: 09-05-2016, 08:59 PM
  2. I need help. Valve type selection.
    By coverall in forum Mechanical Engineering
    Last Post: 04-14-2014, 09:46 AM
  3. Valve Selection Handbook
    By Mohamed in forum Pipeline And Fluid Flow
    Last Post: 07-29-2013, 09:18 PM
  4. Solenoid valve selection sheet for cylinder op valve
    By sandeep_walunj@yahoo.com in forum Instrumentation & Control
    Last Post: 12-24-2011, 05:26 PM
  5. Valve Selection Handbook
    By mtt2005 in forum Instrumentation & Control
    Last Post: 11-26-2011, 06:21 AM
