Thread: I need help. Valve type selection.
  1. I need help. Valve type selection.
    Dear fellows
    I'm searching for a valve for a specific duty. The valve must stop the flow if the pressure rises over the required pressure.
    I mean I will set the valve to 5 bar. When it's over 5 bar it will stop. The medium is pressurized air.
    Thanks for your help
  3. Re: I need help. Valve type selection.
    By the sounds of it you simply need a pressure regulator valve. Any will do.
    However, if overpressure of the downstream system is a process safety issue then the valve will need to be an emergency shutdown valve. These valves are typically actuated quarter-turn ball valves.
  5. Re: I need help. Valve type selection.
    Thanks for yor reply.
    I forgot to mention the main point. Thats why the question is not so easy. The tank will work at 7.5 bar. There will be two types of manometer. Firts one will measure up to 2 bar. Second one will measure up to 7.5 bar. The valve that I'm trying to find will be used for protecting the 2 bar manometer. I think a seleoid valve can be used.
    This manometers will be used on a hyperbaric chamber.
    Still waiting replies.
    Thanks in advance.
  6. Re: I need help. Valve type selection.
    Thanks in advance.
  1. Valve Selection Handbook
    By mkhurram79 in forum Pipeline And Fluid Flow
    Last Post: 07-27-2017, 08:38 PM
  2. Valve Type Selection for multiphase pipeline
    By dhayes in forum Pipeline And Fluid Flow
    Last Post: 10-24-2013, 04:36 PM
  3. Valve type
    By Ahmed gamal in forum Mechanical Engineering
    Last Post: 07-25-2013, 01:04 PM
  4. Solenoid valve selection sheet for cylinder op valve
    By sandeep_walunj@yahoo.com in forum Instrumentation & Control
    Last Post: 12-24-2011, 05:26 PM
