Thread: Frangible Joint
  1. Frangible Joint
    What is frangible joint ?? API 653 Says when frangible roof to shell joint.. What does it Mean ? What is frangible joint mean ??
  3. Re: Frangible Joint
    A frangible joint is a joint that's made intentionally weak. On a storage tank this is the joint between the roof and the tank walls. In the event of an internal explosion, the roof will lift off, but the walls will remain intact and contain the liquid and fire. This prevents the tank walls lifting from the floor and spilling the contents.
  1. Expansion Joint
    By Debelme in forum Mechanical Engineering
    Last Post: 09-02-2013, 03:52 PM
  2. Joint efficiency for 'No RT' case
    By wijeesh in forum Mechanical Engineering
    Last Post: 04-24-2013, 07:46 AM
  3. Swivel joint
    Last Post: 11-28-2011, 09:56 AM
  4. Welded Joint Design
    By Abdel fatah in forum Materials Science &Corrosion
    Last Post: 05-14-2011, 07:00 PM
  5. Swivel joint procurement
    Last Post: 05-09-2011, 08:18 AM
