Thread: Swivel joint
    Jul 2010
    Bangladesh
    Blog Entries
    2
    Lightbulb Swivel joint
    Swivel joints are used in the roof drain line of the floating roof tank. In our refinery we usually replace these during repair work of the tank. In that case the life of the joints are about 10-15 years. But I want to use these joints again. There is no testing facility of these joints. It is mentionable that there are 20 swivel joints in each tank so a good amount of money is required to replace these. My questions are:
    1. Is it a good decision to replace the joints after 10-15 years?
    2. How to test the joints if I want to use again?
    I don't think you need swivel joints testing again, cause can be reused after seal replacement:
    [link Point to another website Only the registered members can access] See suppliers recommendation.
    Articulated swivel joints are leak prone... If cost is not an issue, install Pivot Master or equivalent flexible joint technologies..
  1. Swivel
    By vitor_vs in forum Drilling And Workover
    Last Post: 05-17-2014, 08:01 PM
  2. Frangible Joint
    By scherjeal in forum Oil And Gas Process
    Last Post: 01-09-2014, 01:41 AM
  3. Expansion Joint
    By Debelme in forum Mechanical Engineering
    Last Post: 09-02-2013, 03:52 PM
  4. Specification of swivel joint
    Last Post: 07-26-2011, 10:50 AM
  5. Swivel joint procurement
    Last Post: 05-09-2011, 08:18 AM
