Results 1 to 9 of 9
Thread: pressure gradient
  1. pressure gradient
    Hello,
    please help me calculate the pressure gradient when we have MDT pressure data. is it like as below if not please correct?
    Pressure gradient = (P2-P1)/(D2-D1)*0.3048 = .... psi/ft
    If you have any excel sheet, please share.
    Thank you
    Nov 2008
    Australia
    Re: pressure gradient
    psi/ft is exactly that - a change in pressure per change in depth
    So, if you have depth in ft and pressure in psi, gradient = (P2 - P1)/(D2 - D1)
    If depth is in meters, then yes, multiply it by 0.3048
    As a quick check to make sure you've got it all right, fresh water gradients will be around 0.433 psi/ft, Gas from 0.01 to 0.25 psi/ft (depending on the pressure/temp) and oil around 0.3 psi/ft for your 47 API type crude.
  5. Re: pressure gradient
    Thanks .... vinomarky
    Another question when it is said "oil-wet" and "water-wet" core/reservoir, what does it actually mean, confuses me help ....?
  6. Re: pressure gradient
    Nov 2008
    Australia
    Oil Wet: Sand grains preferentially coat with oil, meaning high residual oil saturations and rapid water breakthrough
    Water wet: opposite
    Nov 2008
    Australia
    Water wet: opposite
  10. Re: pressure gradient
    thank you
    which porosity and permeability should one use when using MICP data for saturation height? Is it measured on end trims or come from routine core analysis plugs. If it is from routine core analysis, then there will be depth difference because mercury was done on end trims, please explain, many thanks
    Nov 2008
    Australia
    Whatever is representative to how you will be modelling it.
    Will you be populating the model based upon Petrophysically derived porosity and a poro perm relationship? Then you need to ensure that the RCA you use represents the same porosity average to that which your tool resolution would yield at that location. If your sat/height function relationships is in turn a function of permeability (ie simple J function), then what permeability are you using? Klinkenberg corrected air perm on cleaned core? Perm of core at residual saturation? It all matters. For perms of sub 1mD, actual permeability in presence of residual water can be 10-100x less than to that of air.
    You need to sit down and think it all through to ensure you are consistent, and that in the final analysis your Porosity x (1-Sw) yields appropriate hydrocarbon volumes, and that K x Kr yields appropriate productivity for your various phases under reservoir conditions.
  12. Re: pressure gradient
    Thanks you ....
    Last Post: 11-24-2013, 09:14 AM
  2. Article: pressure gradient
    By yasiobasio123 in forum Home Articles
    Last Post: 11-19-2013, 08:52 PM
  3. Article: pressure gradient
    Last Post: 11-15-2013, 07:51 AM
  4. pressure gradient
    By vergatario in forum Reservoir
    Last Post: 10-16-2013, 03:39 AM
  5. pressure gradient
    By yasiobasio123 in forum Reservoir
    Last Post: 09-30-2012, 12:16 AM
