What should be the gas, oil and water gradients obtained from depth-pressure cross-plot? thanks
You should get three different straight lines with different slopes in presence of three phases: Gas, Oil and Water
1- 0.08 psi/ft for Gas
2- 0.35 psi/ft for Oil
3- 0.45 psi/ft for Water
The inflection point corresponds to whether it is WOC or GOC from water line or gas line respectively.
Those numbers are reasonable approximations, but they will alll vary of course.
Gas will vary most of all as a function of pressure / temp & composition
My ResToolbox app calculates the expected gradients
