Page 1 of 3 1 2 3 LastLast
Results 1 to 12 of 29
Thread: Oisd standards (july 2012)
    Can anybody Share these OISD STANDARDS (JULY 2012)-latest
    LIST OF OISD STANDARDS (JULY 2012)
    1. OISD-STD-105 Work Permit System
    2. OISD-STD-106 Pressure Relief & Disposal System
    3. OISD-RP-108 Recommended Practices on Oil Storage and Handling
    4. OISD-STD-109 Process Design and Operating philosophies on blow down and sewer system
    5. OISD-STD-110 Recommended Practices on Static Electricity
    6. OISD-STD-111 Process design and operating philosophies on fired process furnace
    7. OISD-STD-112 Safe handling of air hydrocarbon mixtures and pyrophoric substances
    8. OISD-STD-113 Classification of Area for electrical installations at Hydrocarbon processing and handling facilities
    9. OISD-STD-114 Safe handling of Hazardous Chemicals
    10. OISD-GDN-115 Guidelines on Fire Fighting Equipment and Appliances in Petroleum Industry
    11. OISD-STD-116 Fire Protection facilities for Petroleum Refineries and Oil/Gas Processing Plants
    12. OISD-STD-117 Fire Protection Facilities for Petroleum Depots, Terminals, PipelineInstallations and Lube Oil Installations
    13. OISD-STD-118 Layouts for Oil and Gas Installations
    14. OISD-STD-119 Selection, Operation and Maintenance of Pumps
    15. OISD-STD-120 Selection, Operation and Maintenance of Compressors
    16. OISD-STD-121 Selection, Operation, Inspection & Maintenance of Steam & Gas Turbines
    17. OISD-RP-122 Selection, Operation and Maintenance of Fans, blowers, gear boxes, agitators & Mixers
    18. OISD-RP-123 Selection, Operation and Maintenance of rotary equipment components
    19. OISD-RP-124 Predictive Maintenance Practices
    20. OISD-STD-125 Inspection and Maintenance of Mechanical Seals
    21. OISD-RP-126 Specific practices for installation and maintenance of rotating equipment
    22. OISD-STD-127 Selection operation inspection and maintenance of Diesel Engines
    23. OISD-STD-128 Inspection of unfired pressure vessels
    24. OISD-STD-129 Inspection of storage tanks
    25. OISD-STD-130 Inspection of Piping Systems
    26. OISD-STD-131 Inspection of Boilers
    27. OISD-STD-132 Inspection of pressure relieving devices
    28. OISD-STD-133 Inspection of fired heaters
    29. OISD-STD-134 Inspection of heat exchangers
    30. OISD-STD-135 Inspection of loading and unloading hoses for petroleum products
    31. OISD-STD-137 Inspection of electrical equipment
    32. OISD-STD-139 Inspection of pipelines Offshore
    33. OISD-STD-140 Inspection of jetty pipelines
    34. OISD-STD-141 Design and Construction requirements for cross country hydrocarbon pipelines
    35. OISD-STD-142 Inspection of fire fighting equipments and systems
    36. OISD-STD-144 Liquefied Petroleum Gas (LPG) Installations
    37. OISD-GDN-145 Guidelines on Internal Safety Audits (Procedures and Checklist)
    38. OISD-RP-146 Preservation of idle electrical equipment
    39. OISD-RP-147 Inspection & safe practices during electrical installations
    40. OISD-RP-148 Inspection & safe practices during overhauling electrical equipment
    41. OISD-RP-149 Design aspects for safety in electrical systems
    42. OISD-STD-150 Design and Safety Requirements For Liquefied Petroleum Gas Mounded Storage Facility
    43. OISD-STD-151 Safety in Design, Fabrication and Fittings : Propane Tank Trucks
    44. OISD-STD-152 Safety instrumentation for process system in hydrocarbon industry
    45. OISD-STD-153 Maintenance & inspection of safety instrumentation in hydrocarbon industry
    46. OISD-STD-154 Safety aspects in functional training
    47. OISD-STD-155 (Part I) Personal Protective Equipment : Part I Non-respiratory equipment
    OISD-STD-155 (Part II) Personal Protective Equipment : Part II Respiratory Equipment
    48. OISD-STD-156 Fire Protection Facilities for Ports Handling Hydrocarbons
    49. OISD-RP-157 Recommended Practice for Transportation of Bulk Petroleum Products
    50. OISD-RP-158 Recommended Practices on Storage and Handling of Bulk Liquefied Petroleum Gas
    51. OISD-STD-159 LPG Tank Trucks - Requirements of Safety on Design/Fabrication and Fittings
    52. OISD-STD-160 Protection to fittings mounted on existing LPG tank trucks
    53. OISD-GDN-161 LPG Tank Truck Incidents : Rescue & Relief Operations
    54. OISD-STD-162 Safety in installation and maintenance of LPG Cylinders Manifold
    55. OISD-STD-163 Process Control Room Safety
    56. OISD-STD-164 Fire Proofing in Oil & Gas Industry
    57. OISD-GDN-165 Guidelines for Rescue & Relief Operations for POL Tank Truck Accident
    58. OISD-GDN-166 Guidelines for Occupational Health Monitoring in Oil and Gas Industry
    59. OISD-RP-167 POL Tank lorry Design & Safety
    60. OISD-GDN-168 Emergency Preparedness Plan for Marketing Locations of Oil Industry
    61. OISD-GDN-169 OISD Guidelines on Small LPG Bottling Plants (Design and Fire Protection facilities)
    62. OISD-STD-170 Inspection, Maintenance, Repairs and Rehabilitation of foundations and structures
    63. OISD-STD-171 Preservation of Idle Static & Rotary Mechanical Equipments
    64. OISD-STD-173 Fire Protection System for Electrical Installations
    65. OISD-RP-174 Well Control
    66. OISD-STD-175 Cementing Operations
    67. OISD-STD-176 Safety Health & Environment Training For Exploration & Production (Upstream) Personnel
    68. OISD-STD-177 Inspection & Maintenance of Thermal Insulation
    69. OISD-GDN-178 Guidelines on Management Of Change
    70. OISD-STD-179 Safety Requirements On Compression, Storage, Handling & Refueling Of Natural Gas For Use In Automotive Sector.
    71. OISD-GDN-180 Lightning Protection
    72. OISD-STD-181 Geophysical Operations
    73. OISD-GDN-182 Safe Practices for Workover & well Stimulation Operations
    74. OISD-STD-183 Standard on Logging Operations
    75. OISD-STD-184 Standard On Replacement Of Personal Protective Equipment And Life Saving Appliances
    76. OISD-GDN-185 Wire Line Operations
    77. OISD-GDN-186 Simultaneous Operations in Exploration & Production industry
    78. OISD-STD-187 Care And Use Of Wire Rope
    79. OISD-STD-188 Corrosion Monitoring Of Offshore & Onshore Pipelines
    80. OISD-STD-189 Standard On Fire Fighting Equipment For Drilling Rigs, Work Over Rigs And Production Installations
    81. OISD-STD-190 Derrick Floor Operations (Onshore Drilling / Workover Rigs)
    82. OISD-STD-191 Oil Field Explosive Safety
    83. OISD-GDN-192 Safety Practices During Construction
    84. OISD-GDN-193 Guidelines for Gas Lift Operations and Maintenance
    85. OISD-STD-194 Standard for Storage And Handling Of Liquefied Natural Gas (LNG)
    86. OISD-STD-195 Safety in Design, Operation, Inspection and Maintenance of Hydrocarbon Gas Compressor Stations and Terminals
    87. OISD-GDN-196 Guidelines for Seeking Environmental Clearance of Development Projects in Petroleum Industry
    88. OISD-GDN-197 Guidelines for Environmental Impact Assessment
    89. OISD-GDN-199 Guidelines For Conducting Environmental Audit In Upstream Petroleum Sector (Onland)
    90. OISD-GDN-200 Guidelines For Preparation Of Oil Spill Response Contingency Plan
    91. OISD-RP-201 Environment Management in Exploration & Production Sector
    92. OISD-GDN-202 Inspection of Drilling and Workover Rig Mast / Sub-Structure
    93. OISD-GDN-203 Operation, Maintenance & Inspection Of Hoisting Equipment
    94. OISD-GDN-204 Medical Requirements, Emergency Evacuation And Facilities (For Upstream)
    95. OISD-RP-205 Crane Operation, Maintenance and Testing (For upstream)
    96. OISD-GDN-206 Guidelines on Safety Management System in Petroleum Industry
    97. OISD-GDN-207 Contractor Safety
    98. OISD-STD-210 Storage, Handling and Refuelling of LPG for automotive use
    99. OISD-GDN-211 Safety in Petroleum Laboratories
    100. OISD-GDN-212 Guidelines on Environmental Audit in Downstream Petroleum Sector
    101. OISD-STD-214 Cross Country LPG Pipelines
    102. OISD-STD-216 Electrical Safety In Onshore Drilling And Workover Rigs
    103. OISD-GDN-218 Guidelines For Safe Rig- Up And Rig- Down Of Drilling And Work Over Rigs
    104. OISD-GDN-219 Guidelines on Field Inspection, Handling and Testing of Casing Pipe & Tubing
    105. OISD-GDN-224 Monitoring & Control of Volatile Organic Compounds Emission
    106. OISD-STD-225 Storage, Handling & Dispensing at Petroleum Retail Outlets
    107. OISD-STD-226 Natural Gas Transmission Pipelines and City Gas Distribution Networks
    108. OISD-GDN-227 Emergency Response and Preparedness in E&P Industry
    109. OISD-GDN-228 Selection, Training & Placement of Fire Operators in Hydrocarbon & Petroleum Industry
    110. OISD-STD-230 Unlined Underground Rock Cavern Storage for Petroleum Liquefied Petroleum Gas
    111. OISD-STD-231 Sucker Rod Pumping Units
  3. Re: Oisd standards (july 2012)
    I have all those that you want...plz. mail me your email id at "finiteinjustice@gmail.com".....i will mail you one by one.....
    "jmd"
    pl send to this ID
    kanil009@yahoo.co.in
    Much better if you´d share them with everybody. Please post them.
    Quote Originally Posted by finiteinjustice View Post
    "jmd"
    "jmd"
  9. Re: Oisd standards (july 2012)
    Check this link below.....
  10. Re: Oisd standards (july 2012)
    Sorry It is Ok
    Thanks.
    finiteinjustice, that´s the way to do it. I knew you were going to post. Well done!
  14. #11
  16. #12
    Well, somehow my last 2 post have been duplicated.
  1. Need OISD Standards
    By SA_FETY in forum Safety And Environment
    Last Post: 03-06-2025, 01:59 PM
  2. Need the OISD standards
    Last Post: 05-20-2017, 09:05 PM
  3. OISD(Oil Industry Safety Directive) standards
    By instsuresh in forum Electrical & Power Engineering
    Last Post: 04-01-2015, 09:06 AM
  4. OISD(Oil Industry Safety Directive) standards
    By instsuresh in forum Instrumentation & Control
    Last Post: 11-07-2013, 07:03 PM
  5. Oisd standards (july 2012)
    By kanil in forum Mechanical Engineering
    Last Post: 10-13-2013, 12:51 PM
