Page 1 of 2 1 2 LastLast
Results 1 to 12 of 24
Thread: Need the OISD standards
    Dear Professionals,
    I need the following OISD standards
    Sr. No. STANDARD NAME
    1 Work Permit System OISD-STD-105
    2 Process design and operating philosophies on pressure relief and disposal system ISD-STD-106
    3 Recommended Practices on Oil Storage and Handling OISD-RP-108
    4 Process Design and Operating philosophies on blow down and sewer system OISD-STD-109
    5 Recommended Practices on Static Electricity OISD-STD-110
    6 Process design and operating philosophies on fired process furnace OISD-STD-111
    7 Safe handling of air hydrocarbon mixtures and pyrophoric substances OISD-STD-112
    8 Classification of Area for electrical installations at Hydrocarbon processing and handling facilities OISD-STD-113
    9 Hazardous Chemicals and their handling OISD-STD-114
    10 Guidelines on Fire Fighting Equipment and Appliances in Petroleum Industry OISD-GDN-115
    11 Fire Protection facilities for Petroleum Refineries and Oil/Gas Processing Plants OISD-STD-116
    12 Fire Protection Facilities for Petroleum Depots, Terminals, Pipeline Installations and Lube Oil Installations OISD-STD-117
    13 Layouts for Oil and Gas Installations OISD-STD-118
    14 Inspection of Pumps OISD-STD-119
    15 Inspection of Compressors OISD-STD-120
    16 Inspection of turbines and Diesel Engines OISD-STD-121
    17 Inspection of fans, blowers, gear boxes and agitators OISD-STD-122
    18 Inspection of rotating equipment components OISD-STD-123
    19 Predictive Maintenance Practices OISD-RP-124
    20 Inspection and Maintenance of Mechanical Seals OISD-STD-125
    21 Specific practices for installation and maintenance of rotating equipment OISD-RP-126
    22 Inspection of unfired pressure vessels OISD-STD-128
    23 Inspection of storage tanks OISD-STD-129
    24 Inspection pipes, valves and fittings OISD-STD-130
    25 Inspection of Boilers OISD-STD-131
    26 Inspection of pressure relieving devices OISD-STD-132
    27 Inspection of fired heaters OISD-STD-133
    28 Inspection of heat exchangers OISD-STD-134
    29 Inspection of loading and unloading hoses for petroleum products OISD-STD-135
    30 Inspection of electrical equipment OISD-STD-137
    31 Inspection of cross country pipelines -Onshore OISD-STD-138
    32 Inspection of pipelines - Offshore OISD-STD-139
    33 Inspection of jetty pipelines OISD-STD-140
    34 Design and Construction requirements for cross country hydrocarbon pipelines OISD-STD-141
    35 Inspection of Fire Fighting Equipments & Systems OISD-STD-142
    36 Liquefied Petroleum Gas (LPG) Installations OISD-STD-144
    37 Guidelines on Internal Safety Audits (Procedures and Checklist) OISD-GDN-145
    38 Preservation of idle electrical equipment OISD-RP-146
    39 Inspection & safe practices during electrical installations OISD-RP-147
    40 Inspection & safe practices during overhauling electrical equipment OISD-RP-148
    41 Design aspects for safety in electrical systems OISD-RP-149
    42 Design and Safety Requirements for Liquefied Petroleum Gas Mounded Storage Facility OISD-STD-150
    43 Safety in Design, Fabrication and Fittings: Propane Tank Trucks OISD-STD-151
    44 Safety instrumentation for process system in hydrocarbon industry OISD-STD-152
    45 Maintenance & inspection of safety instrumentation in ydrocarbon industry OISD-STD-153
    46 Safety aspects in functional training OISD-STD-154
    47 Personal Protective Equipment (Part I Non-respiratory equipment)
    Personal Protective Equipment (Part II Respiratory Equipment) OISD-STD-155(Part I)
    OISD-STD-155(Part II)
    48 Fire Protection Facilities for Ports Handling Hydrocarbons OISD-STD-156
    49 Recommended Practice for Transportation of Bulk Petroleum Products OISD-RP-157
    50 Recommended Practices on Storage and Handling of Bulk Liquefied Petroleum Gas OISD-RP-158
    51 LPG Tank Trucks - Requirements of Safety on Design/Fabrication and Fittings OISD-STD-159
    52 Protection to fittings mounted on existing LPG tank trucks OISD-STD-160
    53 LPG Tank Truck Incidents : Rescue & Relief Operations OISD-STD-161
    54 Safety in Installation & Maintenance of LPG Cylinders Manifold OISD-STD-162
    55 Process Control Room Safety OISD-STD-163
    56 Fire Proofing in Oil & Gas Industry OISD-STD-164
    57 Guidelines for Rescue & Relief Operations for POL Tank Truck Accidents OISD-STD-165
    58 Guidelines for Occupational Health Monitoring in Oil & Gas Industry OISD-STD-166
    59 POL Tank Lorry Design & Safety OISD-STD-167
    60 Emergency Preparedness Plan for Marketing Locations of Oil Industry OISD-STD-168
    61 Guidelines on Small LPG Bottling Plants (Design & Fire Protection facilities) OISD-STD-169
    62 Inspection, Maintenance, Repairs and Rehabilitation of Foundations & Structures OISD-STD-170
    63 Preservation of Idle Static & Rotary Mechanical Equipments OISD-STD-171
    64 Fire Protection System for Electrical Installations OISD-STD-173
    65 Well Control OISD-STD-174
    66 Cementing Operations OISD-STD-175
    67 Safety Health & Environment Training For Exploration & Production (Upstream) Personnel OISD-STD-176
    68 Inspection & Maintenance of Thermal Insulations OISD-STD-177
    69 Guidelines on Management of Change OISD-STD-178
    70 Safety Requirements On Compression, Storage, Handling & Refueling Of Natural Gas For Use In Automotive Sector OISD-STD-179
    71 Lightning Protection OISD-STD-180
    72 Geophysical Operations OISD-STD-181
    73 Recommended Safe Procedures & Guidelines For Work over & Well Stimulation Operations OISD-STD-182
    74 Standard on Logging Operations OISD-STD-183
    75 Standard on Replacement Of Personal Protective Equipment & Life Saving Appliances OISD-STD-184
    76 Wire Line Operations OISD-STD-185
    77 Combined Operations OISD-STD-186
    78 Care & Use Of Wire Rope OISD-STD-187
    79 Corrosion Monitoring Of Offshore & Onshore Pipelines OISD-STD-188
    80 Standard On Fire Fighting Equipment For Drilling Rigs, Work Over Rigs And Production Installations OISD-STD-189
    81 Derrick Floor Operations (Onshore Drilling / Work over Rigs) OISD-STD-190
    82 Oil Field Explosive Safety OISD-STD-191
    83 Safety Practices During Construction OISD-STD-192
    84 Guidelines for Gas Lift Operations & Maintenance OISD-STD-193
    85 Guidelines for Gas Lift Operations & Maintenance OISD-STD-194
    86 Safety in Design, Operation, Inspection and Maintenance of Hydrocarbon Gas Compressor Stations and Terminals OISD-STD-195
    87 Guidelines for Seeking Environmental Clearance of Development Projects in Petroleum Industry OISD-STD-196
    88 Guidelines for Environmental Impact Assessment OISD-STD-197
    89 Guidelines For Conducting Environmental Audit In Upstream Petroleum Sector (On-and) OISD-STD-199
    90 Guidelines For Preparation Of Oil Spill Response Contingency Plan OISD-STD-200
    91 Recommended Practices for Environment Protection in Upstream Petroleum Sector (On-land Facilities) OISD-STD-201
    92 Inspection of Drilling & Work over Rig Mast / Sub-Structure OISD-STD-202
    93 Operation, Maintenance & Inspection Of Hoisting Equipment OISD-STD-203
    94 Medical Requirements, Emergency Evacuation And Facilities (For Upstream) OISD-STD-204
    95 Crane Operation, Maintenance and Testing (For upstream) OISD-STD-205
    96 Guidelines on Safety Management System in Petroleum Industry OISD-STD-206
    97 Contractor Safety OISD-STD-207
    98 Storage, Handling and Refueling of LPG for automotive use OISD-STD-210
    99 Safety in Petroleum Laboratories OISD-STD-211
    100 Guidelines on Environmental Audit in Downstream Petroleum Sector OISD-STD-212
    101 Cross Country LPG Pipelines OISD-STD-214
    102 Electrical Safety in Onshore Drilling and Workover Rigs OISD-STD-216
    103 Formulation Of Environment Management Plan For Drilling Operations OISD-STD-217
    104 Guidelines For Safe Rig- Up And Rig- Down Of Drilling And Work-Over Rigs OISD-STD-218
    105 Guidelines on Field Inspection, Handling and Testing of Casing Pipe & Tubing OISD-STD-219
    106 Distribution of Piped Natural Gas OISD-STD-220
    107 Monitoring & control of VOC Emission and LDAR Programme OISD-STD-224
    108 Storage, Handling & Dispensing at Petroleum Retail Outlets OISD-STD-225
    109 Natural Gas Pipelines and City Gas Distribution Networks OISD-STD-226
    110 Emergency Response Preparedness in E&P industry OISD-STD-227
    111 Selection, Training and Placement of Fire Operators in Oil & Gas Industry OISD-STD-228
    I also Required.
    RKD
    Thumbs up Oisd
    Here you go--------------->
    Enjoy!
    Quote Originally Posted by deepsee View Post
    Enjoy!
    thanks my friend....
    Thanks.
    Mar 2010
    Seoul, Korea, South Korea
    Thanks!
    deepsee, thanks a lot.
    Great job! Many thank's
  13. Dear friend can you upload any of the standards if u have,
    This will great helpful for me,
    OISD-STD-203,
    OISD-STD-211,
    OISD-STD-214,
    OISD-STD-215,
    OISD-STD-216,
    OISD-STD-217,
    OISD-STD-218,
    OISD-STD-219,
    OISD-STD-220,
    OISD-STD-224,
    OISD-STD-225,
    OISD-STD-226,
    OISD-STD-227,
    OISD-STD-228
    N.NAGARATHINAM
  14. The earlier posts are much more helpful for me.
    Thanks,
    N.NAGARATHINAM
  16. #12
    Sep 2008
    Here only- EGPET
    Blog Entries
    5
    Thanks deepsee
  1. Need OISD Standards
    By SA_FETY in forum Safety And Environment
    Last Post: 03-06-2025, 01:59 PM
  2. Oisd standards (july 2012)
    By kanil in forum Safety And Environment
    Last Post: 03-05-2025, 08:14 AM
  3. OISD(Oil Industry Safety Directive) standards
    By instsuresh in forum Electrical & Power Engineering
    Last Post: 04-01-2015, 09:06 AM
  4. OISD(Oil Industry Safety Directive) standards
    By instsuresh in forum Instrumentation & Control
    Last Post: 11-07-2013, 07:03 PM
  5. Oisd standards (july 2012)
    By kanil in forum Mechanical Engineering
    Last Post: 10-13-2013, 12:51 PM
