Can anybody Share these OISD STANDARDS (JULY 2012)-latest
LIST OF OISD STANDARDS (JULY 2012)
1. OISD-STD-105 Work Permit System
2. OISD-STD-106 Pressure Relief & Disposal System
3. OISD-RP-108 Recommended Practices on Oil Storage and Handling
4. OISD-STD-109 Process Design and Operating philosophies on blow down and sewer system
5. OISD-STD-110 Recommended Practices on Static Electricity
6. OISD-STD-111 Process design and operating philosophies on fired process furnace
7. OISD-STD-112 Safe handling of air hydrocarbon mixtures and pyrophoric substances
8. OISD-STD-113 Classification of Area for electrical installations at Hydrocarbon processing and handling facilities
9. OISD-STD-114 Safe handling of Hazardous Chemicals
10. OISD-GDN-115 Guidelines on Fire Fighting Equipment and Appliances in Petroleum Industry
11. OISD-STD-116 Fire Protection facilities for Petroleum Refineries and Oil/Gas Processing Plants
12. OISD-STD-117 Fire Protection Facilities for Petroleum Depots, Terminals, PipelineInstallations and Lube Oil Installations
13. OISD-STD-118 Layouts for Oil and Gas Installations
14. OISD-STD-119 Selection, Operation and Maintenance of Pumps
15. OISD-STD-120 Selection, Operation and Maintenance of Compressors
16. OISD-STD-121 Selection, Operation, Inspection & Maintenance of Steam & Gas Turbines
17. OISD-RP-122 Selection, Operation and Maintenance of Fans, blowers, gear boxes, agitators & Mixers
18. OISD-RP-123 Selection, Operation and Maintenance of rotary equipment components
19. OISD-RP-124 Predictive Maintenance Practices
20. OISD-STD-125 Inspection and Maintenance of Mechanical Seals
21. OISD-RP-126 Specific practices for installation and maintenance of rotating equipment
22. OISD-STD-127 Selection operation inspection and maintenance of Diesel Engines
23. OISD-STD-128 Inspection of unfired pressure vessels
24. OISD-STD-129 Inspection of storage tanks
25. OISD-STD-130 Inspection of Piping Systems
26. OISD-STD-131 Inspection of Boilers
27. OISD-STD-132 Inspection of pressure relieving devices
28. OISD-STD-133 Inspection of fired heaters
29. OISD-STD-134 Inspection of heat exchangers
30. OISD-STD-135 Inspection of loading and unloading hoses for petroleum products
31. OISD-STD-137 Inspection of electrical equipment
32. OISD-STD-139 Inspection of pipelines Offshore
33. OISD-STD-140 Inspection of jetty pipelines
34. OISD-STD-141 Design and Construction requirements for cross country hydrocarbon pipelines
35. OISD-STD-142 Inspection of fire fighting equipments and systems
36. OISD-STD-144 Liquefied Petroleum Gas (LPG) Installations
37. OISD-GDN-145 Guidelines on Internal Safety Audits (Procedures and Checklist)
38. OISD-RP-146 Preservation of idle electrical equipment
39. OISD-RP-147 Inspection & safe practices during electrical installations
40. OISD-RP-148 Inspection & safe practices during overhauling electrical equipment
41. OISD-RP-149 Design aspects for safety in electrical systems
42. OISD-STD-150 Design and Safety Requirements For Liquefied Petroleum Gas Mounded Storage Facility
43. OISD-STD-151 Safety in Design, Fabrication and Fittings : Propane Tank Trucks
44. OISD-STD-152 Safety instrumentation for process system in hydrocarbon industry
45. OISD-STD-153 Maintenance & inspection of safety instrumentation in hydrocarbon industry
46. OISD-STD-154 Safety aspects in functional training
47. OISD-STD-155 (Part I) Personal Protective Equipment : Part I Non-respiratory equipment
OISD-STD-155 (Part II) Personal Protective Equipment : Part II Respiratory Equipment
48. OISD-STD-156 Fire Protection Facilities for Ports Handling Hydrocarbons
49. OISD-RP-157 Recommended Practice for Transportation of Bulk Petroleum Products
50. OISD-RP-158 Recommended Practices on Storage and Handling of Bulk Liquefied Petroleum Gas
51. OISD-STD-159 LPG Tank Trucks - Requirements of Safety on Design/Fabrication and Fittings
52. OISD-STD-160 Protection to fittings mounted on existing LPG tank trucks
53. OISD-GDN-161 LPG Tank Truck Incidents : Rescue & Relief Operations
54. OISD-STD-162 Safety in installation and maintenance of LPG Cylinders Manifold
55. OISD-STD-163 Process Control Room Safety
56. OISD-STD-164 Fire Proofing in Oil & Gas Industry
57. OISD-GDN-165 Guidelines for Rescue & Relief Operations for POL Tank Truck Accident
58. OISD-GDN-166 Guidelines for Occupational Health Monitoring in Oil and Gas Industry
59. OISD-RP-167 POL Tank lorry Design & Safety
60. OISD-GDN-168 Emergency Preparedness Plan for Marketing Locations of Oil Industry
61. OISD-GDN-169 OISD Guidelines on Small LPG Bottling Plants (Design and Fire Protection facilities)
62. OISD-STD-170 Inspection, Maintenance, Repairs and Rehabilitation of foundations and structures
63. OISD-STD-171 Preservation of Idle Static & Rotary Mechanical Equipments
64. OISD-STD-173 Fire Protection System for Electrical Installations
65. OISD-RP-174 Well Control
66. OISD-STD-175 Cementing Operations
67. OISD-STD-176 Safety Health & Environment Training For Exploration & Production (Upstream) Personnel
68. OISD-STD-177 Inspection & Maintenance of Thermal Insulation
69. OISD-GDN-178 Guidelines on Management Of Change
70. OISD-STD-179 Safety Requirements On Compression, Storage, Handling & Refueling Of Natural Gas For Use In Automotive Sector.
71. OISD-GDN-180 Lightning Protection
72. OISD-STD-181 Geophysical Operations
73. OISD-GDN-182 Safe Practices for Workover & well Stimulation Operations
74. OISD-STD-183 Standard on Logging Operations
75. OISD-STD-184 Standard On Replacement Of Personal Protective Equipment And Life Saving Appliances
76. OISD-GDN-185 Wire Line Operations
77. OISD-GDN-186 Simultaneous Operations in Exploration & Production industry
78. OISD-STD-187 Care And Use Of Wire Rope
79. OISD-STD-188 Corrosion Monitoring Of Offshore & Onshore Pipelines
80. OISD-STD-189 Standard On Fire Fighting Equipment For Drilling Rigs, Work Over Rigs And Production Installations
81. OISD-STD-190 Derrick Floor Operations (Onshore Drilling / Workover Rigs)
82. OISD-STD-191 Oil Field Explosive Safety
83. OISD-GDN-192 Safety Practices During Construction
84. OISD-GDN-193 Guidelines for Gas Lift Operations and Maintenance
85. OISD-STD-194 Standard for Storage And Handling Of Liquefied Natural Gas (LNG)
86. OISD-STD-195 Safety in Design, Operation, Inspection and Maintenance of Hydrocarbon Gas Compressor Stations and Terminals
87. OISD-GDN-196 Guidelines for Seeking Environmental Clearance of Development Projects in Petroleum Industry
88. OISD-GDN-197 Guidelines for Environmental Impact Assessment
89. OISD-GDN-199 Guidelines For Conducting Environmental Audit In Upstream Petroleum Sector (Onland)
90. OISD-GDN-200 Guidelines For Preparation Of Oil Spill Response Contingency Plan
91. OISD-RP-201 Environment Management in Exploration & Production Sector
92. OISD-GDN-202 Inspection of Drilling and Workover Rig Mast / Sub-Structure
93. OISD-GDN-203 Operation, Maintenance & Inspection Of Hoisting Equipment
94. OISD-GDN-204 Medical Requirements, Emergency Evacuation And Facilities (For Upstream)
95. OISD-RP-205 Crane Operation, Maintenance and Testing (For upstream)
96. OISD-GDN-206 Guidelines on Safety Management System in Petroleum Industry
97. OISD-GDN-207 Contractor Safety
98. OISD-STD-210 Storage, Handling and Refuelling of LPG for automotive use
99. OISD-GDN-211 Safety in Petroleum Laboratories
100. OISD-GDN-212 Guidelines on Environmental Audit in Downstream Petroleum Sector
101. OISD-STD-214 Cross Country LPG Pipelines
102. OISD-STD-216 Electrical Safety In Onshore Drilling And Workover Rigs
103. OISD-GDN-218 Guidelines For Safe Rig- Up And Rig- Down Of Drilling And Work Over Rigs
104. OISD-GDN-219 Guidelines on Field Inspection, Handling and Testing of Casing Pipe & Tubing
105. OISD-GDN-224 Monitoring & Control of Volatile Organic Compounds Emission
106. OISD-STD-225 Storage, Handling & Dispensing at Petroleum Retail Outlets
107. OISD-STD-226 Natural Gas Transmission Pipelines and City Gas Distribution Networks
108. OISD-GDN-227 Emergency Response and Preparedness in E&P Industry
109. OISD-GDN-228 Selection, Training & Placement of Fire Operators in Hydrocarbon & Petroleum Industry
110. OISD-STD-230 Unlined Underground Rock Cavern Storage for Petroleum Liquefied Petroleum Gas
111. OISD-STD-231 Sucker Rod Pumping Units
