Results 1 to 6 of 6
Thread: heat exchanger tube plugging
  1. Post heat exchanger tube plugging
    hi friends.i'm searching about plug sizing for heat exchanger tubes.can anyone give me a useful table for plug dimension calculation included :d,D,L ?
  3. i too needed it pl. upload
    Well there is no hard and fast rule for the design of tubes plug. Being a maintenance engineer i know few things about it;
    1. Length of Plug length is usually 38mm.
    2. Taper in plug is 5 degree.
    3. Minor Dia of plug is less than ID of tube.
    4. Plug material is same as of Tube material.
    5. In case of -----s during welding of plug with tubesheeet, a hole is drilled on plug's major dia side at its centre to cater expansion effect. Such type of plugs are known as Johnsons Plug.
  6. Dear AAQE
    Very thanks for your usefull information.
    I shall like to add in point (5) that Johnson plugs are also used where the operating temperature differences are huge in tube & shell side. It is to give the plug required elasticity against thermal stresses.
    Best regards,
    Thanx Nasir for adding such a conducive information.
  9. nice stuff keep on giving these kind of data's so that v can gain knowlegde.
  1. SHELL AND TUBE HEAT EXCHANGER (Tube Sagging Problem)
    By hammad_nrl in forum Mechanical Engineering
    Last Post: 04-10-2013, 06:06 AM
  2. Replies: 3
    Last Post: 04-03-2013, 07:00 AM
  3. Tube Stress for heat exchanger.
    By morest in forum Pipeline And Fluid Flow
    Last Post: 12-03-2011, 07:58 PM
  4. Heat Exchanger Tubeside Repair by Plugging
    By daveodc in forum Mechanical Engineering
    Last Post: 01-27-2011, 01:21 PM
  5. tube sealing leakage in shell & tube heat exchanger
    By amitss_sam in forum Pipeline And Fluid Flow
    Last Post: 12-10-2010, 03:38 PM
