Thread: tube sealing leakage in shell & tube heat exchanger
  1. tube sealing leakage in shell & tube heat exchanger
    Following is the worst thing I faced last month in one Solvent extraction plant.
    There is one shell & tube heat exchanger (tubeside vegetable oil & shellside is steam @ 3 barg at operating condition). We hydrotested this vessel at 6 barg. This vessel is designed for 4 barg pressure both sides. For tubes to tubesheet joint, we done expansion of tubes which we do regularly. Tube material is SA249 TP304 ERW schedule 40, size: 1 1/2" OD (38mm). After 20 days of plant working, there is leakage from this tube to tubesheet joint. I am trying to figure out the reason why this happen.
    Please note that there is no seal welding.
  3. any guess?
  1. Tube to tubesheet leakage in shell & tube heat exchangers
    By amitss_sam in forum Mechanical Engineering
    Last Post: 03-16-2016, 08:10 AM
  2. SHELL AND TUBE HEAT EXCHANGER (Tube Sagging Problem)
    By hammad_nrl in forum Mechanical Engineering
    Last Post: 04-10-2013, 06:06 AM
  3. Design a Tube-shell heat exchanger.
    By haih5 in forum Oil And Gas Process
    Last Post: 04-08-2013, 02:11 AM
  4. Replies: 3
    Last Post: 04-03-2013, 07:00 AM
  5. Replies: 1
    Last Post: 12-11-2010, 11:36 PM
