Page 1 of 2 1 2 LastLast
Results 1 to 12 of 18
Thread: Software Etank2000 or Coade Tank 3.5
  1. Software Etank2000 or Coade Tank 3.5
    Please share Etank2000 or Coade Tank 3.5 software with key!
    Oct 2008
    The Netherlands
    Blog Entries
    14
    Re: Software Etank2000 or Coade Tank 3.5
    In my opinion:
    Etank is good, because it shows the steps and the formula
    Tank on the other side is easy to use ..but confusing when using wind (up lift wind) and earthquake
    Both softwares are not 100% ok ..when designing roofs..this part must be treated by hand calcs or STAAD or other software for structural
    at least my experience..a bit subjective..
    Nov 2010
    Algiers, ALGERIA
    Quote Originally Posted by jslppetroleum View Post
    Here Etank2000.
    If you download and find it useful, just click on Thanks button !
    Visit and become a member of
    Welding Engineering & Inspection group
    Here:
  6. Re: Software Etank2000 or Coade Tank 3.5
    Thank you very much for your kindness!
  7. Re: Software Etank2000 or Coade Tank 3.5
    I have used Etank2000 (be carefull because Etank as the codes outdated, but recommend very much the software from Innovative Tank Solutions.
    Much easier to use, with SI units, reports much nicer and easy to understand, and the Codes are up to date. The software as already API650 12th edition.
    Ask for a demo and try.
    Kind Regards
    P_alex
    May 2009
    Jubail Saudi Arabia
    Quote Originally Posted by p_alex View Post
    Kind Regards
    P_alex
    Alex,
    What about roof structure design and calculations in Etank 2000, It is available? It is possible.,
    Please let me know..
    duazo2009
    Dear duazo2009,
    E-tank and Tank can do what API 650 considers as formulas.
    API 650 does not introduce formulas for roof calculation, except self-sustained roofs. Or, better said, there are in API 650 few formulas referring to plates thickness but not for beams which sustain the plates.
    E-tank additionally introduced column sustained roof formulas from books- so using them it would be the question of validation of such approach. I mean that calculation is OK but it isn't really an API calculation.
    No chance to calculate by such software a more complicated roof structure, let's say a dome structure.
    May 2009
    Jubail Saudi Arabia
    Quote Originally Posted by marian_g View Post
    Dear duazo2009,
    What about floating roof? It is capable?
  12. Re: Software Etank2000 or Coade Tank 3.5
    The calculations on ETANK are in Imperial units only (input, output and calculations). There are only an utility from Etank Programmers to conver the Output in SI units.
    For roofs, they have the self supporting dommes, umbrellas, conical, and also open tanks. Does not have external floating roofs calcs, neither ITS or Tank from Intergraph.
    For structure supported roofs, Etank as only for the conical roofs. The calculation model is based in the Brownell and Young method, please see attached file.
    But, generally, as already said in here, it is better to design the structure in a separated structural program, for example, Robot or SAP, generally because of the local regulations. Here in Europe we have Eurocodes and this tipe of structures as to be design according this Eurocodes.
    From what book was this pdf extracted?
  14. Re: Software Etank2000 or Coade Tank 3.5
    georg22,
    the book is “Process Equipment Design” from Brownell & Young’s. I only have this extract of this book.
    Palex
  16. #12
    May 2009
    Jubail Saudi Arabia
    Quote Originally Posted by gerge22 View Post
    It was extracted from
    Process Equipment Design by: LLoyd D. Brownell & Edwin H. Young, 1959, Chapter 4
    Cheers,
    duazo2009
  1. Floating Roof Tank with COADE Tank
    By bowosumarwo in forum Mechanical Engineering
    Last Post: 05-25-2019, 01:37 PM
