Page 1 of 2 1 2 LastLast
Results 1 to 12 of 18
Thread: Weld Metal calculation
    Hi everybody,
    I am looking for weld metal(weight) calculation for pipe welding.anybody having any excel work sheet or worked out method ,please share it over here or send to my e-mail address mentioned below.I have to order electrodes for production welding. Following is the dimensions of the joint .Thickness of pipe 18 mm, 70 Degree angle single V-Groove,1 mm root face,1.5 mm root opening. I have calculated total volume of joint all around pipe.then divided it by density of weld metal(mild steel) to get mass of the weld metal required to fill the groove. But the result is not correct due to some unit conversion mistake.I am looking for help from all the members over here interested in this subject.I am new in welding engineering and don't have much idea about this .Expecting help from my seniors and friends.
    Thank you in advance
  3. Quote Originally Posted by inconel View Post
    Hi everybody,
    My e-mail sunilkmani@gmail.com
    Sunil K. Mani
    I also need it too,... how to calculate time of welding? consumeable flux? for spiral weld and or long seam weld or circum weld?...
    please give me the formulas or ebook for basic welding calculation.
    thanks ....
    Taqobalallohu minna waminkum
    Happy Id'l Fitri
    Arrow
    you may refer following sites
    Enjoy........................
  6. There is any data available please upload man
    Hi, I heard that Lincoln electric & ESAB distributing excel sheet for weld metal calculation.If any one have that ,pls share it over here
    Hi,
    Nobody here to help me out...........
  10. Dear Friends,
    Please look into this Bohler Guide
    Section-4.2 is regarding "Consumable Consumption
    and Welding Time
    It may be of help to you.
    Thanks & Best Regards,
  11. guys,
    I found this site,.. there is software to calculate the welding and can estimated both on consumable that we need and also for all cost.
    if anybody in this forum has this software, please kindly share this the good one.
    thank you very much,.. i would be pleasure to wait this respond.
    here is the site :
    and
    Nasir, thanks for the information
  13. Mr Nasir,
    Link "Bohler Guide
    [link Point to another website Only the registered members can access] and Welding Time". [/B] is not working.
    kindly can u please do something for this?
  14. #11
    Hai friends...
    I think the following link will serve your Purpose....
  16. Weld metal calculation
    Hi alls,
    I have a document of boehler-welding can share for all.
  1. WELD METAL CALCULATION - Advance X'mas&New Year Bonanza !!!
    By inconel in forum Materials Science &Corrosion
    Last Post: 12-03-2012, 07:43 PM
  2. Replies: 1
    Last Post: 06-27-2011, 08:14 AM
  3. Flat face flanges with metal-to-metal contact beyond the bolt circle
    By sanjaysy in forum Mechanical Engineering
    Last Post: 01-03-2011, 03:59 PM
  4. Map Weld
    By Alejandro in forum Mechanical Engineering
    Last Post: 11-11-2010, 06:51 AM
