Thread: Solid fugacity ( multiphase equilibria ) in Properties
    I am evaluating the solid fugacity model available in Pro de Properties for multiphase equilibria,
    my field of application would be mixtures of hydrocarbons with CO2, H2S etc.
    I need to estimate freezing points (or, in general, problematic conditions),
    which are the main limits (which I should care of) for this model ?
    Re: Solid fugacity ( multiphase equilibria ) in Properties
    depending from the version of Prode Properties you may select different models for solid fugacity,
    the base version includes the SSM (Simplified Solid Model) model for solid fugacity,
    SSM gives reasonable estimates with hydrocarbons, for example I have verified CO2 solid formation with GPSA tables and values are very close.
    Similar behaviour with H2S ad hydrocarbons.
    With presence of very non-ideal fluids as water you should validate the results or use different models (you may contact Prode for information)
  1. Replies: 3
    Last Post: 06-23-2013, 04:50 PM
  2. Replies: 7
    Last Post: 12-16-2011, 10:51 AM
