Installer of:
Tomorrow SP2
Installer of:
Tomorrow SP2
CCCP they have deleted it. Pl upload somewhere else. There is no ver available after 2008. pl reupload
pls upload again....
PV Elite® 2013
New Features
PV Elite® is a Windows (XP/Vista/7) based program. This version has been developed and tested on Windows 7, Windows XP and Windows Vista. PV Elite 2013 has not been tested under Windows 8.
NOTES:
Launching the program PVE.EXE starts PV Elite. This program’s internal version is: 15.00.00.000.
Below is a listing of the new features in this year’s version. Many of the new features and improvements come directly from your comments. There have also been a number of new features that have been included in builds to the 2012 version during the last year which are now in this version.
Code Updates and Analysis changes:
• Some new Code updates are incorporated in this version. The updates includes:
1. PD 5500 2012 Edition Incorporated.
2. Tema 9th Edition
3. API-579 2007 Edition, General Metal Loss
Internationalization
• PV Elite® can now work in multiple languages including:
1. English
2. French
3. Spanish
4. Portuguese
5. Italian
• The AS/NZ 2011 Wind Code was updated.
Productivity Enhancements
• All new Updated User Interface.
1. Ribbon Style
2. All new Icons (Large or Small)
3. Different color Themes
4. All programs revised for this change
• Quick calculation Screen
1. Text Highlight
2. Search
3. Select all and Copy all
• Output Processor
1. Report List Coloring
2. Search and Highlight
4. DXF and Rigging result directly available from the output program
5. Drag and drop of reports in the report list
• PV Elite now supports project templates.
• CodeCalc has been completely re-written into a modern style application.
• Graphics
1. Color code by thickness, material, temperature etc.
2. Lock Axis rotation
3. 2D and 3D screen now separated
• Printing
1. Print directly to PDF
2. Available in Input, Output, CodeCalc, Material Editor etc.
• Material Databases can be sorted by column
• New Analysis Features
1. Integrated API 579 Part 4 General Metal Loss
2. ASME VIII-1 Material Data 1943 through 1974
3. PD 5500 Jacket Analysis
4. PD 5500 Limpet Coil Analysis
5. EN 13445 Limpet Coil Analysis
6. ASME VIII-1 Fatigue Analysis updated (from latest Div. 2)
7. PV Elite 2012 R1 Features included
8. EN-13445 Exp Joints
9. European Structural Steel
10. EN-13445 Local Stress Analysis
11. Improved Metric defaults
12. Japanese Wind Code
13. European Nozzle Load table
14. ASME Stainless Steel MDMTs computed
15. Complete Exchanger MDMTs Computed (tubesheets)
16. MDMT table sorted for Shell side and Tube side results
17. Use differential pressure for tube design
18. Indian Earthquake Code, vertical acceleration component added
19. Updated EN-13445 Materials Added
QA/Validation and Verification
• We continue to add new QA problems to the benchmark solution set.
Please note that periodically fixes to the software will be posted to the web site at the location sited below. If you are having trouble with a particular calculation, check the Intergraph web site to see if there is a later version available that may fix your problem (also available from the PV Elite® help menu). You should always run the latest version of the software.
I am also interested
Where we can find PVElite working without key![]()
CAN ANYONE TELL ME HOW TO PVELITE 2008 OR 2010 WORK ON WIN7 SP1 64BIT?
MRBEEN
mrbeen789@gmila.com
