Thread: The Way To Use PVELITE 2013 ON Window 7- 64bit
  1. The Way To Use PVELITE 2013 ON Window 7- 64bit
    Dear My Friend
    I've Installed PVELITE 2013 On Windows 7 64bit and it is working perfect.
    Here Is The Procedure :
    1- Download installer file from
    [link Point to another website Only the registered members can access] 2- Install Microsoft Virtual PC on your device.It's available for Both 32 and 64 version. Absolutely you use 64 bit
    3- Install Windows XP mode on your PC
    4-Run Windows XP mode
    5-In windows Xp mode find your download folder and copy it on your xp mode desktop
    6-now Install Pvelite 2008 With Green ESl and ----- it
    7-Install Pvelite 2013 With Green ESl and ----- it
    8-If you have face error with ESl and your program doesn't run well don't worry. Re-Install "Install.bat" file again.
    9-Don't Forget restart your PC in each step especially when you run "install.bat" file.
    10-Enjoy It.
    If you find it useful, Please just click Thanks. !
  3. Re: The Way To Use PVELITE 2013 ON Window 7- 64bit
    Thanks, I will try it.
  6. Re: The Way To Use PVELITE 2013 ON Window 7- 64bit
    Dear m.boka,
    Thanks for your valuable procedure. I tried to install XP mode in window 7 64 bit home premium. But it failed. Is there any other solution, please share it....
  1. PVElite 2013
    By lubl in forum Mechanical Engineering
    Last Post: 02-10-2015, 05:31 AM
  2. PVElite 2013
    By cadcae in forum Mechanical Engineering
    Last Post: 12-10-2013, 05:59 AM
