Thread: ANSI B16.9 with wall thikness of fittings
  1. ANSI B16.9 with wall thikness of fittings
    I really do need a standard in which wall thikness of the fittings exist. In ANSI 16.9 does not exist. Thank you!
  3. Re: ANSI B16.9 with wall thikness of fittings
    [link Point to another website Only the registered members can access] If youre conviced, got get an engineering license, and get ASME B36.10/.19
  5. Re: ANSI B16.9 with wall thikness of fittings
    Thank you for the answer. I have ASME B36.10/.19, but there is the thickness of the pipe, not the thickness of the fitting (e.g. an 90 degree elbow). Should I understand that the thickness of the pipe is the same with the thickness of the fitting?
  6. Re: ANSI B16.9 with wall thikness of fittings
    Yes, see ASME B16.9 2009 para 1.4
  1. Mss-sp valves and fittings
    By Achmad Nur Eddin in forum Mechanical Engineering
    Last Post: 05-31-2019, 04:22 AM
  2. Ansi/hi 9.6.7, 2004" or "ansi/hi 9.6.7, 2010
    By chemengseliem in forum Petroleum Refining
    Last Post: 12-18-2011, 09:51 AM
  3. Replies: 0
    Last Post: 09-16-2010, 09:16 PM
  4. Design of Water wall (Membrane wall) in waste heat boiler
    By srvinay2010 in forum Mechanical Engineering
    Last Post: 09-16-2010, 07:55 PM
  5. Requirement of ISO 22000:2005, ANSI Z10, ANSI 490.1
    By mgkirupa in forum Safety And Environment
    Last Post: 06-04-2009, 04:08 PM
