Page 1 of 11 1 2 3 ... LastLast
Results 1 to 12 of 121
Thread: Mss-sp valves and fittings
    Wink Mss-sp valves and fittings
    Hi Guys,
    The following links are the Manufacturer Standardization Society (MSS) of Valve and Fittings standards.. Please be hurry before the links are death.
    Enjoy it
    1. MSS SP-6 - Standard finishes of contact faces of pipe flange & connecting of valves -2007.pdf 0.195 MB
    [link Point to another website Only the registered members can access] 2. MSS SP-25 - Marking System-1997.pdf 1.881 MB
    [link Point to another website Only the registered members can access] 3. MSS SP-43 - Wrought stainless steel buttwelding fitting 2001.pdf 0.581 MB
    [link Point to another website Only the registered members can access] 4. MSS SP-44 - Steel Pipeline Flange-2001.pdf 1.449 MB
    [link Point to another website Only the registered members can access] 5. MSS SP-45 - By Pass Connection and Drain-1998.pdf 0.479 MB
    [link Point to another website Only the registered members can access] 6. MSS SP-53 - Magnetic Particle Examination Method 1990.pdf 0.321 MB
    [link Point to another website Only the registered members can access] 7. MSS SP-54 - Radiographic Examination Method 1995.pdf 0.346 MB
    [link Point to another website Only the registered members can access] 8. MSS SP-55 - Visual Method for Evaluation of Surface Irregularities -2001.pdf 13.306 MB
    [link Point to another website Only the registered members can access] 9. Mss SP-58 - Pipe Hangers And Supports - Materials, Design, And Manufacture 2002.pdf 1.803 MB
    [link Point to another website Only the registered members can access] 10. MSS SP-61- Pressure Testing of steel valves 1999.pdf 0.467 MB
    [link Point to another website Only the registered members can access] 11. MSS SP-67 - Butterfly Valves 2002a.pdf 0.887 MB
    [link Point to another website Only the registered members can access] 12 MSS SP-68 - High Pressure Butterfly wih offset design 1997.pdf 0.462 MB
    [link Point to another website Only the registered members can access] 13 MSS SP-69 - Pipe Hangers and Supports - Selection and Application 2003.pdf 1.346 MB
    [link Point to another website Only the registered members can access] 14 MSS SP-70 - Cast Iron Gate Valve 1984.pdf 0.766 MB
    [link Point to another website Only the registered members can access] 15. MSS SP-71 - Cast Iron Swing Check Valve 1984.pdf 0.567 MB
    [link Point to another website Only the registered members can access] 16 MSS SP-72 - BALL VALVES WITH FLANGED OR BUTT-WELDING ENDS FOR GENERAL SERVICE 1999..pdf 0.643 MB
    [link Point to another website Only the registered members can access] 17 MSS SP-73 - Brazing Joints for copper and copper alloy 2003.pdf 0.181 MB
    [link Point to another website Only the registered members can access] 18. MSS SP-75 - Specification High Test of Weldings -1998.pdf 0.877 MB
    [link Point to another website Only the registered members can access] 19. MSS SP-79- Socket Welding Reducer Inserts 2004.pdf 0.604 MB
    [link Point to another website Only the registered members can access] 20 MSS SP-80 - Bronze Gate,Globe,Angle, Check Valve-1997.pdf 1.381 MB
    [link Point to another website Only the registered members can access] 21 MSS SP-83 - Class 3000 Steel pipe unions socket welding and threaded 2006.pdf 0.857 MB
    [link Point to another website Only the registered members can access] 22. MSS SP-85 - GRAY IRON GLOBE &ANGLE VALVES FLANGED AND THREADED ENDS 2002.pdf 0.847 MB
    [link Point to another website Only the registered members can access] 23 MSS SP-89 - Pipe Hangars and Supports - Fabrication and Installation Practices 2003.pdf 1.547 MB
    [link Point to another website Only the registered members can access] 24 MSS SP-90 - Guideline terminology of pipe hanger and support 2000.pdf 1.181 MB
    [link Point to another website Only the registered members can access] 25 MSS SP-91 - Guideline for Manual Operation of Valves 1996.pdf 0.475 MB
    [link Point to another website Only the registered members can access] 26 MSS SP-93 - Liquid Penetrant Examination Method 1999.pdf 0.315 MB
    [link Point to another website Only the registered members can access] 27 MSS SP-97 - Integrally Reinforced Forged Branch Outlet Fittings–2006.pdf 0.153 MB
    [link Point to another website Only the registered members can access] 28 MSS SP-99 - Instrument Valves 1994.pdf 0.326 MB
    [link Point to another website Only the registered members can access] 29 MSS SP-105 - Instrument Valves for Code Applications 1996(R2005).pdf 0.501 MB
    [link Point to another website Only the registered members can access] 30 MSS SP-110 - Ball valve threaded, socket etc 1996.pdf 0.613 MB
    [link Point to another website Only the registered members can access] 31 MSS SP-114 - Corrosion Resistant Pipe Fittings Threaded And Socket Welding Class 150 and 1000 2007.pdf 0.781 MB
    [link Point to another website Only the registered members can access] 32 MSS SP-117 - Bellows Seals for Globe and Gate Valves 2006.pdf 0.146 MB
    [link Point to another website Only the registered members can access] 33 MSS SP-118 - Compact Steel Globe and Check Valve 2007.pdf 0.702 MB
    [link Point to another website Only the registered members can access] 34 MSS SP-120 - Flexible Graphite Packing System for Rising Stem Steel Valves - Design Requirements 2006.pdf 0.399 MB
    [link Point to another website Only the registered members can access] 35 MSS SP-121 - Qualification Testing Methods for Stem Packing for Rising Stem Steel Valves -2006.pdf 0.110 MB
    [link Point to another website Only the registered members can access] 36 MSS SP-126 - Steel In-Line Spring-Assisted Center Guided Check Valves -2007.pdf 0.227 MB
    [link Point to another website Only the registered members can access] 37 MSS SP-136 - Ductile Iron Swing Check Valves -2007.pdf 0.173 MB
    BONUS :
    38 API STD 600 12th Ed 2009.pdf 0.628 MB
    [link Point to another website Only the registered members can access] Steel Gate Valves—Flanged and Butt-welding Ends, Bolted Bonnets
    39 API STD 608 4th Ed 2009.pdf 0.706 MB
    [link Point to another website Only the registered members can access] Metal Ball Valves—Flanged, Threaded and Welding Ends
    The following Standard is missing. Please somebody upload the Standard below to complete the MSS-SP Standard, pleaaaseee
    MSS SP – 9 MSS SP – 100 MSS SP – 122
    MSS SP – 42 MSS SP – 101 MSS SP – 123
    MSS SP – 51 MSS SP – 102 MSS SP – 124
    MSS SP – 60 MSS SP – 104 MSS SP – 125
    MSS SP – 77 MSS SP – 106 MSS SP – 127
    MSS SP – 78 MSS SP – 108 MSS SP – 129
    MSS SP – 81 MSS SP – 109 MSS SP – 130
    MSS SP – 86 MSS SP – 111 MSS SP – 131
    MSS SP – 88 MSS SP – 112 MSS SP – 132
    MSS SP – 94 MSS SP – 113 MSS SP – 133
    MSS SP – 95 MSS SP – 115 MSS SP – 135
    MSS SP – 96 MSS SP – 116
    MSS SP – 98 MSS SP – 119
    Thankx a lot
  5. thanks for the collection friend
    MSS SP – 51 (
    MSS SP-81-2001 mihd.net/qz6f4h
    I have found the following:
    Cast Iron Plug Valves Flanged and Threaded End MSS-SP-78 1998
    Stainless Steel, Bonnetless, Flanged, Knife Gate Valves MSS-SP-81 2001
    Dear Colleagues
    Thank you very much for your posts.
  11. thank you
  13. thanks a lot. It's very useful
  14. good collection bro...
    but i need MSS SP 75 2004 or latest version...
    can any one give me link for same
    thanks....for great collection.
  16. thanq very much brother. also upload the missing ones
  1. Replies: 59
    Last Post: 12-15-2018, 11:37 AM
  2. Crane TP-410. "Flow of Fluids through valves, fittings, and pipes
    By nocion_2h in forum Pipeline And Fluid Flow
    Last Post: 05-20-2018, 09:32 PM
  3. Crane - Flow of Fluids Through Valves, Fittings, and Pipe
    Last Post: 05-20-2018, 09:23 PM
  4. Replies: 0
    Last Post: 05-18-2013, 06:36 PM
  5. Flow of Fluids Through Valves, Fittings, and Pipe
    By azheee in forum Pipeline And Fluid Flow
    Last Post: 04-19-2011, 05:04 AM
