Results 1 to 7 of 7
Thread: change flowrate with time in OLGA 7
    In pipeline how i can change flowrate with time in OLGA 7 , also if have pipeline and the production is shut-in after 30 hours and the pipeline is closed and after 50 hours the source is restarted. how i can define that in OLGA
    Sep 2011
    MedellÃ-n, Antioquia, Colombia
    Re: Article: change flowrate with time in OLGA 7
    buddy, if you need to know how can do the change on the flowrate, you have to go to the TRENDDATA And define what variables you want to see on the time or if you want to see at any time you must edit the PROFILEDATA and you must indicate the variable, and the pipeline is closed at any time, you must indicate to the valve each time shift (1- Oppened, 0- Closed).
    very thanks for your answer , but may be i can't clear my question what i need to now how i change flow rate with time in the source not in the result , for example the at 5 hr. the flow rate will be 2000 BPD and after 24 hr. the flow rate will incrase to be 5000 BPD , and so on
    Also in the attached picture for olga case , what mean data in properties window highlighted by yellow color
    Sep 2011
    Ok Mohamed, you need to change the flowrate on time, you must watch on panel when you put the massflow source, you can watch the properties there you watch a icon of a little clock , when you click it you can watch the parameters and you can edit the time and the Standar flowrate, there you must fill with the time and flowrate that you need...
    Quote Originally Posted by Arlen Zapata View Post
    Very thanks that what i search for
    Re: change flowrate with time in OLGA 7
    Muhamed, can you take a look on my case with olga. The simulations runs OK but I do not know where to see and how to plot the results..
    the thread is here: .egpet.net/vb/threads/58747-Help-with-OLGA
  10. Re: change flowrate with time in OLGA 7
    may be you can try to change flowrate with time like this:
    Time 0,5,6 min
    Source 600,600,700 mmscfd
  1. Article: change flowrate with time in OLGA 7
    By Mohamed in forum Home Articles
    Last Post: 02-02-2013, 08:58 PM
  2. Replies: 0
    Last Post: 11-01-2011, 09:33 PM
  3. Replies: 9
    Last Post: 03-21-2011, 05:21 PM
