You can view the page at[link Point to another website Only the registered members can access]
buddy, if you need to know how can do the change on the flowrate, you have to go to the TRENDDATA And define what variables you want to see on the time or if you want to see at any time you must edit the PROFILEDATA and you must indicate the variable, and the pipeline is closed at any time, you must indicate to the valve each time shift (1- Oppened, 0- Closed).
very thanks for your answer , but may be i can't clear my question what i need to now how i change flow rate with time in the source not in the result , for example the at 5 hr. the flow rate will be 2000 BPD and after 24 hr. the flow rate will incrase to be 5000 BPD , and so on
Also in the attached picture for olga case , what mean data in properties window highlighted by yellow color
Ok Mohamed, you need to change the flowrate on time, you must watch on panel when you put the massflow source, you can watch the properties there you watch a icon of a little clock , when you click it you can watch the parameters and you can edit the time and the Standar flowrate, there you must fill with the time and flowrate that you need...
Very thanks that what i search forOriginally Posted by Arlen Zapata
