Results 1 to 5 of 5
Thread: wthp keyword in eclipse
  1. wthp keyword in eclipse
    dear experts
    I generated few different model (included odeh one) by ecl 2004a
    I want well head pressure so i used wthp keyword
    but i always get a a Pwh=0 for all time
    i really need help
    i attached two of the my data files in this post
    thank you guys
    i
    Re: wthp keyword in eclipse
    Dear shantia762, you are getting WTHP = 0 since your model doesn't specify VFP tables. Take a look at the VFPPROD keyword (Schedule section). Without VFP tables the pressure drop along the producing tubing can't be calculated.
  5. Re: wthp keyword in eclipse
    that make sense
    thank u very much
    but this make a ? for me
    when we specify a rate in wconprod keyword
    this rate (for ex 5000 bbl) is the rate of liquid enter into the well or surface rate?
    As indicated in the Reference manual, items #4, #5, #6 and #7 of WCONPROD specify the oil, water, gas and liquid rates at standard conditions (i.e. surface conditions). However, item #8 specifies fluid volume rates at reservoir conditions (i.e. at the average reservoir pressure and temperature). In your case (run named "Odeh"), your control mode is ORAT with 20,000 stbo/d.
  7. Re: wthp keyword in eclipse
    Thank you very very much
    it's help alot
  1. looking for eclipse
    By anas1980 in forum Reservoir
    Last Post: 06-25-2013, 05:23 PM
  2. Need help in Eclipse
    By vijaysin2000 in forum Reservoir
    Last Post: 11-13-2012, 04:46 PM
