Thread: Tube pipe Conveyor
  1. Tube pipe Conveyor
    Hi guys
    Now I am have small problems and need your help!
    We'll design one ash handling system use tube pipe conveyor.
    Pls. share me some standard, technical calculation document (e.g. CEMA).
    Thanks in advance
    May 2009
    Jubail Saudi Arabia
    Re: Tube pipe Conveyor
    Quote Originally Posted by dungnqgl View Post
    Hi guys
    Thanks in advance
    Please use the ash screw conveyor design, this is the technical term being use and not tube pipe conveyor..you can search this in the net.
    Cheers,
    Duazo2009
  5. Re: Tube pipe Conveyor
    Thanks for your reply.
    I have detail:
    We consider applied screw conveyor or scraper conveyor for bottom ash handling in Boiler island only.
    For plant ash (bed ash and fly ash) handling system, we must convey ash to pond by trucks.
    Now this way was being high cost (maintenance and operation cost) so we want to use tube pipe conveyor but
    1. We do not understand calculation way
    2. The temperature of ash is 150oC, is it Ok for tube's material (Fabric).
    Pls. help me? any expert guys?
    I recommend a screw conveyor, I have experience in transportation of ash from incinerators.
    Basics;
    Mechanical Design: C4 bearings should use intrinsic tolerance, also mounts bearings at the ends of the conveyor can not be secured axially by expansion, but must allow for elongation of this, if length dimensions give me I can say that undergoes expansion the shaft, too need the exactly EN Material (Werkstoff Nr.)(X.XXXX, example: 1.4307), or ASTM material specification.
    To calculate the ideal diameter and power needed, I need the following information:
    1. - Flow or volume flow rate to carry on (m³ / h).
    2. - In case you want the flow or volume flow rate should provide me the following information to calculate it, outer diameter of the screw (~= inside diameter of housing body) and inside diameter of the screw (= outside diameter of propshaft), angular velocity (rpm), the screw pitch (m).
    3. - Bulk density or specific weight (Kg / m³) (For ash is usually: 600 Kg / m³).
    4. - Angle of internal friction of the product (Angle of repose of the product) (For ash is usually 40 (gr.360)).
    5. - Angle of friction against the walls of the product and the helix (For ash is usually 40 (gr.360)).
    6. - The angle of inclination of the screw conveyor to the horizontal, (If completely horizontal is 0 (gr.360), if it is completely vertical is 90 (gr.360)) (depend on the implementation of the team).
    7. - Material of construction of this transporter (1.4307, 1.4404, 1.0425, etc.) in any case whether it is carbon steel or stainless steel.
    Best Regards,
  1. AWS D10.8-RP for welding of Cr-Mo steel pipe and tube
    By cpchonburi in forum Mechanical Engineering
    Last Post: 12-15-2017, 12:11 PM
  2. Difference between pipe & tube
    By jumbodumbo in forum Pipeline And Fluid Flow
    Last Post: 09-23-2013, 01:16 AM
  3. Tube and Pipe Handbook
    By Mr Welder in forum Pipeline And Fluid Flow
    Last Post: 08-01-2013, 07:47 PM
  4. Pipe and tube/ Sheet and Plate
    By hakr5 in forum Mechanical Engineering
    Last Post: 12-01-2009, 09:44 PM
  5. pipe or tube
    By a_m_shiha in forum Instrumentation & Control
    Last Post: 04-25-2009, 06:14 PM
