Thread: Pipe and tube/ Sheet and Plate
    can anyone explain the difference between sheet/plate and pipe/tube. i'v gone through several materials, but didn't get a satisfactory answer....
    Pipe is only for mass transfer.
    Tube is for heat and mass transfer e.g. boiler tube.
    Sheet: Thickness upto 3mm or less then 3mm
    Plate: Beyond 3 mm thk. is refd. as plate.
  1. tube to tube sheet joint positon
    By son77jai in forum Mechanical Engineering
    Last Post: 03-13-2012, 03:04 AM
  2. Tube to tube sheet joint in ASME III
    By abc123 in forum Mechanical Engineering
    Last Post: 03-12-2012, 09:55 AM
  3. Tube to Tube sheet joint
    By Muhammad Ramzan in forum Mechanical Engineering
    Last Post: 03-12-2010, 07:19 PM
